Topic: building a digitally controlled variable capacitor (Read 3570 times) previous topic - next topic
mightyruler
the digitally controlled variable capacitor  I was looking at getting is still listed on digikey, but is no longer manufactured. so, looking at the data sheet, it looks simple to build. the question i have, is what is the control circuit called? it has something to do with a single in controlling transistors that connect/disconnect about 5 capacitors. It is a simple circuit, and seems that there should be lots of option already designed and tested.
CrossRoads
mightyruler
http://www.intersil.com/content/dam/Intersil/documents/fn81/fn8156.pdf
CrossRoads
Looks like plenty available at Mouser
http://www.mouser.com/Search/Refine.aspx?Keyword=x90100
"New At Mouser" hardly seems to indicate discontinued.
mightyruler
thank you. if i can get it, then it will be the easy way and i was looking forward to building a bulky circuit.
runaway_pancake
7.5 - 14.5 pF
How about "Fun WIth Varactor Diodes"?
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
Paul__B
Perhaps you should remind us of what it is you propose to do with this digitally controlled variable capacitor.
If it is in regard to controlling the frequency of an oscillator as you have previously implied, then it is almost certainly an inappropriate approach as direct digital synthesis (of sinewaves, no less) is much more effectively and reliably performed, for which ICs are readily available.
mightyruler
Paul__B
nilton61
This can be done with a 4066 quad analog switch and some capacitors
