Topic: Ucglib: Color OLED and TFT Library... (Read 40286 times) previous topic - next topic
olikraus
Quote
Has any further progress been made with the ILI9325C? Particularly using in SPI mode?
A display with such configuration has arrived, but i did not found time to work on this until now
Oliver
I was working for several hours on the ILI9325C with SW SPI.
Good news is, it should already work with:
Code: [Select]
Ucglib4WireSWSPI ucg(ucg_dev_ili9325_18x240x320_itdb02, ucg_ext_ili9325_18, /*sclk=*/ 13, /*data=*/ 11, /*cd=*/ 9 , /*cs=*/ 10, /*reset=*/ 8)
If the ILI9325C is put into
IM0=1, IM1=1, IM2=1, IM3=0
mode.
But somehow it does not work. Any ideas?
Oliver
jemson
Hi Oliver,
I did play around with this as well as something similar in below, but could not get this working either.
Code: [Select]
Ucglib4WireSWSPI ucg(ucg_dev_ic_ili9325_18, ucg_ext_ili9325_18, /*scl=*/ 15, /*sda=*/ 14, /*cd=*/ 16, /*cs=*/ 13, /*reset=*/ 12);
I see in the below thread bauderline posted a video that is supposed to show this display working, but unfortunatly has not include any sample code. I have tried to raise him via email and on the forum but have yet to receive a response.
http://forum.arduino.cc/index.php/topic,210474.0.html
olikraus
Somehow this display does not respond in SPI mode with IM0=1, IM1=1, IM2=1 and IM3=0 at all. Probably i have to rewire all and test with a different SPI mode.
Oliver
tjpeden
Hey, I love U8glib and I'm really excited to see Ucglib as well. I wanted to mention that the C++ interface doesn't seem to have a method for getting the font line spacing as in U8glib.
Also, I was wondering what the best method of rendering a full screen of changing stuff on the SSD1351 would be without a tone of flickering? I'm trying to build a really nice display for a reverse geocaching box so the screen needs to update at least once a second.
olikraus
Hi tjpeden
hmmm... line spacing i did not add as of now. It could be easily derived by from ascent - decent value of the current font.
Flickering will be there with ucglib. I t can not be avoided. U8glib does not have this flickering, but requires the more complicated "picture loop".
Both libs support the SSD1351...
Oliver
tjpeden
What about sleep mode for the SSD1351. The datasheet says the commands are AE for sleep on and AF for sleep off, it doesn't look like you've implemented the sleep functions yet. I'm not sure how to go about it since there aren't even functions for it yet.
olikraus
Thanks, i have added issue 27 for this.
Oliver
tjpeden
2 more questions:
First, is there any chance of 1.01 (issue 27) being released before June 15? I have a project that I'm deploying that could really benefit from the power reduction that enhancement would gain me.
Second, what do you think about parsing the string passed to print for '\n' and setting the print position to "x position from last setPrintPos call, y position from last setPrintPos call + 'font line spacing'"? Hope that makes sense. Not a big deal, just something I have wanted to ask for a while.
Lastly, I really enjoyed working with Ucglib (and U8glib), great work! I really appreciate the work you've put into your libraries :-)
TJ
olikraus
Unfortunately i will not be able to do this that fast. Job and family do have higher priority. And currently not much time is left.
I think it should be possible to do this outside of ucglib. But i just notice that drawGlyph is missing as a function (at least it is not described). Added one more issue to ucglib.
Thanks for your remarks and enhacement requests.
Oliver
micol
Hello,
Congratulation for you library. I load it on yesterday. I tried the programm hello world with a mega2560 and SWD SPI  (HWD gives only a white screen).
I change some lines so as to test functions and had a surprise : when using setRotate(270), it rotate text of 270° but rotate background color of another angle.
Here is my code :
Code: [Select]
void loop(void)
  ucg.setRotate90();
  ucg.setFont(ucg_font_ncenB24r);
  ucg.setColor(1, 255, 255, 255);   //  text background color
  ucg.setColor(255, 0, 0);    //  red
  ucg.setPrintPos(0,25);
  ucg.print("Hello World!");
  ucg.setRotate270();
  ucg.setColor(0, 0, 255);   //  blue
  ucg.setPrintPos(0, 75);
and here is the result :
*** Micol *** Les talibans du politiquement correct ont encore frappé. En 2017, la dernière victime est TEX.
olikraus
Great. Excellent error description. I will create an issue for this.
Meanwhile, UCG_FONT_MODE_TRANSPARENT could be used as a workaround.
K+
Oliver
micol
Hello,
I tried other examples. All work with SWD spi only.
Scale runs since yesterday. It tells now 12982  12983 ...
I stop it à 13000.
micol
To get rid of 4050 or resistors, I ordered ProMini 3.3Volts.
Now, all works fine (HwdSpi and SwdSpi).
I had a surprise with GraphicsTest.ino whose texts are upside down.
olikraus
Hi
Looks odd. What is the constructor call you use? Do you have a datasheet of this device?
Will UTFT work with your TFT?
Oliver
micol
My constructors are either
Ucglib_ILI9341_18x240x320_SWSPI ucg(/*sclk=*/ 13, /*data=*/ 11, /*cd=*/ 9 , /*cs=*/ 10, /*reset=*/ 8 ) ;
or
Ucglib_ILI9341_18x240x320_HWSPI ucg(/*cd=*/ 9 , /*cs=*/ 10, /*reset=*/ 8 );
Now, it works well though I have not changed anything to wiring. I only tried and played other example programs.
I have not installed UTFT library.
Before your library, I tried 2 Adafruit libraries (9340 then 9341) and their examples. Some worked, other not, but I use ProMini 3.3V only today.
My TFT is a low cost ILI9341 one withour any datasheet.
