Topic: help to build an ir transmitter (Read 3386 times) previous topic - next topic
arvindpandi6
guys,
i am new to arduino,
i working with tsop and ir leds to build a remote
i have wrote a basic code to transmit a nec code in hex"1FE50AF"
the code i wrote is
#include <CppList.h>
#include <IRremote.h>
#include <IRremoteInt.h>
IRsend irsend;
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn();
  irsend.sendNEC(0x1FE50AFUL,32);
  Serial.print("Sent NEC ");
  irrecv.decode(&results) ;
    Serial.println(results.value);
    irrecv.resume(); // Receive the next value
my leds is illuminating but i am not receiveing in tsop..can you guys help me
AnalysIR
Couple of things
You need to place your code in code tags (the # button on top when editing) otherwise too hard to read your code.
You cannot send and receive at the same time using IRremote - as it doesnt make sense. You need to have 2 different Arduino systems to test one a sender and one a receiver.
Normally people use an existing remote control to test receiving and a TV to test sending - thus no need for 2 Arduinos.
Drew Davis
This should help you out...
https://learn.sparkfun.com/tutorials/ir-control-kit-hookup-guide
