Topic: Arduino IDE not starting (Windows) (Read 1 time) previous topic - next topic
Mo0z3d
When I try to open the Arduino IDE, it shows the splash screen but stops after that without any error.
"arduino.exe" shows up in the task manager for a brief moment but dissapears again.
I found many "solutions" for this problem, but none of them work.
I'm using Windows 7 ultimate (64bit) sp1, Java version 1.7.0_51 and arduino-1.0.5-r2.
I already tried the following things:
-removing and reinstalling the latest Java version.
-removing and reinstalling the latest Arduino IDE
(The standalone version used to work. I tried both the installer and the standalone version but none of them work)
-Running arduino.exe from the command line with "--l4j-debug".
(It doesn't create the log file, so I'm not sure what I'm doing wrong here)
-Running arduino.exe as an administrator in compatibility mode and/or with visual themes disabled.
-Installing the Arduino Enhanced Release 1.0.5 for Windows.
(Same problem as with the regular version)
-removing java and arduino IDE, running Ccleaner to clean up the registry and some files, reinstalling java and the IDE.
So it probably is a problem with Java, but I can't figure out what I'm doing wrong. Any ideas?
Thanks
n46130
Try the suggestion of renaming the data file it worked for me  For info on the solution.
mtifall09.wordpress.com/2009/12/05/launch4j-error-corrected/?
It involved renaming the data file.
There have been so many people having this issue, I wonder why the compiler isn't fixed. Is this a bug in the compiler
Mo0z3d
I can't seem to find the arduino data folder, I guess it's not there because the IDE didn't make one yet.
Also, I don't get any errors (launch4j in this case) so I don't think it will fix my problem.
spycatcher2k
Remove the Arduino folder from your my documents. See if this helps.
http://www.uk-pcb.co.uk - UK Based PCB Fab Company
I will code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
