Topic: Arduino easy ESC programming Tutorial (Read 16600 times) previous topic - next topic
diiaf
Hey, I made my first tutorial on instructables.com . It is made for programming ESC's for controlling Brushlessmotors with the Arduino. It is my first one, i hope it corresponds the usual standarts.
greetings from Germany!   :)
diiaf
Execuse me, here is the URL: :D
http://www.instructables.com/id/ESC-Programming-on-Arduino-Hobbyking-ESC/
Ziyanfly
Hi, Thank you so much for the tutorial.
I'm working on a project using this ESC. (Hobbyking 20A UBEC)
I wander if this ESC could have the motor direction changed? What I mean by that is that could I rotate it clockwise and then counterclockwise?
I have tried to control the BLDC with the servo library and it looks like i can only control the throttle of it.
In my project, I will need to control the BLDC in both direction. Do I need to get another ESC or can I program the ESC in someway to achieve that goal?
Best Regards
Zapro
You can only change the rotation by swapping any of the two wires on the ESC, unless it's an car-ESC that supports brake and reverse. If it's not intended for a car, you cannot change the direction of the motor by means of the servo control signal.
// Per.
