Topic: FTDI 3.3v verses 5v (Read 1 time) previous topic - next topic
blah44
Taking a look at this guy -
https://www.sparkfun.com/products/9873
The 5v version says it can "become" a 3.3v one, by cutting a trace or installing a jumper. The 3.3v does NOT say the same, but the comments lead one to believe it is a possibility. Anyone have direct experience with the 3.3v unit and able to confirm it can "become" a 5v part?
Also, using a logic level converter, is it possible to to by one FTDI board and use it with both 3.3v and 5v targets?
Thanks!
blah44
Thanks!
tsunamy_boy
With a knife scratch that connection and solder the other like you see in the picture it'll work just fine.
I would recommend you to use 3 pins soldered to that areas and a jumper too, then you can always choose which one you want to use :)
fungus
The ones you get on eBay have a little jumper on them to select the voltage:
http://www.ebay.com/sch/i.html?_nkw=usb+ftdi+arduino+3.3v
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
blah44
Sparkfun customer service says the two parts are complementary; the 3.3v can do 5v, AND the 5v can do 3.3v, depending on jumper/solder configuration.
I do not have either yet, but no reason not to believe them.
blah44
Awesome! Thanks for the nice diagram too.
