Topic: Can't upload on Leonardo board (Read 930 times) previous topic - next topic
iuhsgd5477
Hello,
I can't upload anything on my arduino leonardo board anymore, everything was working well before i started using my ICSP pins to connect a TFT screen, using the schematics here : http://arduino.cc/en/Guide/TFTtoBoards
I'm using :
win 7 , 64 bit
Arduino IDE 1.5.5
I tried to upload the basic "blink" code, with everything disconnected on the board, pluged in USB, i see Arduino Leonardo ( COM5) on the device manager, start to upload, then get stuck at this stage :
Sketch uses 4,554 bytes (15%) of program storage space. Maximum is 28,672 bytes.
Global variables use 151 bytes (5%) of dynamic memory, leaving 2,409 bytes for local variables. Maximum is 2,560 bytes.
Forcing reset using 1200bps open/close on port COM5
A few seconds later, the IDE crash, with the following error :
Problem signature:
  Problem Event Name:   BEX
  Application Name:   javaw.exe
  Application Version:   7.0.400.43
  Application Timestamp:   521c3bf4
  Fault Module Name:   rxtxSerial.dll
  Fault Module Version:   0.0.0.0
  Fault Module Timestamp:   512e3235
  Exception Offset:   000071fd
  Exception Code:   c0000409
  Exception Data:   00000000
  OS Version:   6.1.7601.2.1.0.256.1
  Locale ID:   1036
  Additional Information 1:   352d
  Additional Information 2:   352da0ff9a3b580819eae3912b99e95b
  Additional Information 3:   4369
  Additional Information 4:   436992e3719683e73f58f30fc672099f
Thanks for your help...
iuhsgd5477
Problem solved.
I used the wrong setup code, wich messed up my bootloader, and made arduino IDE crash.
kulk
Hi , I am facing same problem.
Could you kindly elaborate how did you solve this.
Thanks
iuhsgd5477
I used Netbeans to fix it. You could read this : http://playground.arduino.cc/Code/Netbeans
or search for Netbeans - Arduino programming.
Then when you set up netbeans, open a "blink" example project, push on the reset button on the board and upload you project at the same time... then release the button. This worked for me.
