Topic: proximity controlled servo!! help please soo close! (Read 1 time) previous topic - next topic
coltrain87
hello,
i am trying to create a  vilros sg90 servo controlled by a hc-sr04 ultrasonic sensor on my arduino uno.
i dont understand what I am doing wrong? I want at a certain distance, the servo begins to rotate, and follow your proximity via the angle of the servo.  can someone overlook the code?
#define trigPin 3
#define echoPin 2
#include <Servo.h>
Servo myservo;
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);[/img]
  myservo.attach(9);
  int duration, distance;
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(1000);
  digitalWrite(trigPin, LOW);
  duration = pulseIn(echoPin, HIGH);
  distance = (duration/2);            //defines ping sensor
  int val = digitalRead(distance);    //tells ardiuno to read distance as val
  val = map(val, 300, 500, 0, 179);   //define the value of distance to angle of servo arm
  myservo.write(val);                 //servo functions based off of val
  delay(15);
  Serial.print(distance);
  Serial.print("  ");
wildbill
Something went very wrong here:
Code: [Select]
digitalRead returns zero or one. What values are you getting for distance? If it's 300 to 500, you're asking the Arduino what it has on pins in that range - not likely to work well.
Drop the digitalRead. I'd imagine the map was supposed to be:
Code: [Select]
val = map(distance, 300, 500, 0, 179);   //define the value of distance to angle of servo arm
gghull
That seems to work, but be sure to declare    "int val;"    before the line
BTW - I had better luck with a shorter range of distance - 30 cm to 300 cm rather than 300 - 500
gghull
Here's what I came up with - I hope it helps
#include<Servo.h>
Servo myservo;
#define trigPin 3
#define echoPin 2
myservo.attach(9);
  Serial.begin (9600);
  pinMode (trigPin, OUTPUT);
  pinMode (echoPin, INPUT);
  int val;  //  declared the int "val"
  delayMicroseconds(100);
  distance = (duration/2) / 29.1;
  val = map(distance, 30, 150, 0, 179);   // as per wildbill's suggestion
  myservo.write(val);
  delay(150);
  Serial.print("cm");
amatic
I would add this line to limit distance:
Code: [Select]
val = constrain (val, 300,500);
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
