Topic: Debouncing a potentiometer (Read 1 time) previous topic - next topic
kustom
Potentiometers in my project send MIDI data, therefore I need 7-bit resolution. Here is how my current debouncing algorithm works:
First I'm setting the active input on 4051 multiplexers on which potentiometers are connected:
Code: [Select]
void setMuxOutput() {
    //reset the variable to 0 after its value reaches 8 using masking
    muxInput &= 7;
    //switch to next mux input
    PORTC = muxInput << 2;
After that I'm reading the pots:
Code: [Select]
void readPots() {
    //check analogue inputs from 2 4051 analogue multiplexers
    for (int i=0; i<NUMBER_OF_MUX; i++) {
            //calculate pot number
            uint8_t potNumber = (i*8) + muxInput;
            //read analogue value from mux
    //we need 7-bit value for MIDI message
            int8_t tempValue = analogRead(analogueInputArray[i]) >> 3;
//if new reading is stable send new MIDI message
if (potValueStable(tempValue, lastAnalogueValue[potNumber], analogueValueTimer[potNumber])) {
//debugging
Serial.print("Pot number: ");
Serial.println(potNumber);
Serial.print("Value: ");
Serial.println(tempValue);
Serial.print("Current time: ");
Serial.println(millis());
      //increment mux input for next loop iteration
      muxInput++;
potValueStable is a function which returns true if pot value passes through a series of conditions:
Code: [Select]
potValueStable(int16_t currentValue, int16_t previousValue, uint32_t analogueValueTimer) {
//calculate difference between current and previous reading
int16_t analogueDiff = currentValue - previousValue;
if (analogueDiff < 0) analogueDiff *= -1;
When value from pot hasn't changed for more than ANALOGUE_TIMEOUT_MAX value (time in ms), pot must
exceed FILTER_AMOUNT (2) value. If the value has changed during ANALOGUE_TIMEOUT_MAX, it must be
different from previous reading (analogueDiff > 0). If any condition is true, analogueValue timer
is updated. If there is some difference between the two readings and change occurred in less
than ANALOGUE_TIMEOUT_MIN ignore the reading.
if
(analogueDiff >= ANALOGUE_THRESHOLD) ||
(analogueDiff > 0) &&
((millis() - analogueValueTimer) < ANALOGUE_TIMEOUT_MAX)
&& ((millis() - analogueValueTimer) > ANALOGUE_TIMEOUT_MIN)
//reset timer on each new value
analogueValueTimer = millis();
//update previous pot value
previousValue = currentValue;
return true;
return false;
ANALOGUE_TIMEOUT_MAX is set to 200ms and ANALOGUE_TIMEOUT_MIN is set to 5ms.
So, this is how the regular readings look like:
Quote
Pot number: 8
Value: 73
Current time: 115934
Pot number: 8
Value: 74
Current time: 115944
Pot number: 8
Value: 75
Current time: 115960
Pot number: 8
Value: 76
Current time: 115979
Now I waited a couple of seconds and then continued to move the pot:
Quote
Pot number: 8
Value: 78
Current time: 118244
Pot number: 8
Value: 79
Current time: 118280
Pot number: 8
Value: 80
Current time: 118349
So, if you get stable reading from pot and then you don't move it for longer than ANALOGUE_TIMEOUT_MAX (200ms) the difference between last and current reading must be ANALOGUE_THRESHOLD, which is 2. All fine so far, but there is still a case when values start jumping and this is the part I'm struggling to solve (note that I moved the pot only first time, the rest of values were jumping without any touching of pot):
Quote
Pot number: 8
Value: 100
Current time: 190818
Pot number: 8
Value: 101
Current time: 190830
Pot number: 8
Value: 100
Current time: 190907
Pot number: 8
Value: 101
Current time: 190919
Pot number: 8
Value: 100
Current time: 190982
Pot number: 8
Value: 101
Current time: 190993
Pot number: 8
Value: 100
Current time: 191011
Time difference between those values is less than I defined with ANALOGUE_TIMEOUT_MAX and more than ANALOGUE_TIMEOUT_MIN, so they're right in the range when it's actually possible to move the pot at that speed.  So, what are your suggestions for this problem? I would appreciate any advice.
Robin2
What happens if you take a few readings and average them? 4 or 8 readings makes the averaging easier.
Is the impedance of the pot 10k or less?
I presume you know to allow a settling time when you change to reading a different pot.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
kustom
...R
In between setMuxOutput and readPots functions is function which reads 4x5 button matrix and handles few LEDs, so I pressumed that time needed for that is enough to allow some settling of pins. The pots are 10k yes, linear. I haven't tried averaging the pots yet, I'll try.
kustom
Wrong presumption. Time difference was less than 1 ms, so I added a new variable, uint32_t muxSettleTime, so now setMuxOutput looks like this:
Code: [Select]
   if (!muxSettleTime) {
   muxInput &= 7;
muxSettleTime = millis();
And readPots() is also slighty modified:
Code: [Select]
void readPots() {
if ((millis() - muxSettleTime) > 3) {
muxSettleTime = 0;
muxInput++;
Due to 3 ms delay between seting pins and reading the values, I also removed the following check from potValueStable function:
Code: [Select]
So far, the values aren't jumping but I'll play around with pots for some more time and report back here.
