Loading...
Pages: [1]   Go Down
Author Topic: Ardu motor shield Doesnt Work without cable connec  (Read 256 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hello, I am using a ardumoto, and have the program from sparkfun.
The program downloads using a serial cable, but it will not run without the serial cable being plugged in. I have a lithium backpack attached to it. I am using the Arduino Duemilanove. Please help. The code I am using is below:
//int pwm_a = 10; //PWM control for motor outputs 1 and 2 is on digital pin 10
int pwm_a = 3; //PWM control for motor outputs 1 and 2 is on digital pin 3
int pwm_b = 11; //PWM control for motor outputs 3 and 4 is on digital pin 11
int dir_a = 12; //direction control for motor outputs 1 and 2 is on digital pin 12
int dir_b = 13; //direction control for motor outputs 3 and 4 is on digital pin 13
pinMode(pwm_a, OUTPUT); //Set control pins to be outputs
pinMode(pwm_b, OUTPUT);
pinMode(dir_a, OUTPUT);
pinMode(dir_b, OUTPUT);
analogWrite(pwm_a, 100); //set both motors to run at (100/255 = 39)% duty cycle (slow)
analogWrite(pwm_b, 100);
digitalWrite(dir_a, LOW); //Set motor direction, 1 low, 2 high
digitalWrite(dir_b, LOW); //Set motor direction, 3 high, 4 low
analogWrite(pwm_a, 255); //set both motors to run at 100% duty cycle (fast)
analogWrite(pwm_b, 255);
digitalWrite(dir_a, HIGH); //Reverse motor direction, 1 high, 2 low
digitalWrite(dir_b, HIGH); //Reverse motor direction, 3 low, 4 high
Logged
Hyderabad , India
Offline Offline
God Member
can't help not to think arduinaizing something !
View Profile
WWW
Quote
if by download you mean run's using a serial cable then it should be runnng when powered from a backpack as well just check your battery( i.e if its dead) continuity of the wire polarity Etc..
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Even though this isn't a code issue, when posting code please press the button in the editor.
How are you connecting the battery pack to the Arduino?  What is the Nominal Voltage of the battery pack?  What is the voltage while connected?  (The 2nd question is important because "unloaded" measurements of a battery's voltage are usually meaningless.)
« Last Edit: December 17, 2010, 12:21:11 am by cmiyc » Logged
www.cmiyc.com - A guide to being an Enginerd
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
So there is a jumper next to the USB socket that controls if the power is taken from the USB lead or the on board regulator. Have you changed that over?
« Last Edit: December 17, 2010, 04:27:17 am by Grumpy_Mike » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Not on any of my Duemilanoves, there isn't. That jumper was replaced with an auto-selection capability.
Logged
Pages: [1]   Go Up
Print
Jump to:
