Topic: Linksys + dd-wrt + arduino (Read 13705 times) previous topic - next topic
igorreal
  • http://www.ostrosoft.com/oswinsck.asp
  • http://www.codeproject.com/KB/IP/MinimalisticTelnet.aspx
You can download an example excel from my blog http://real2electronics.blogspot.com/2009/10/linksys-arduino.html
Erac
#16
Dec 17, 2010, 10:21 am Last Edit: Dec 17, 2010, 10:30 am by Erac Reason: 1
Hi Igor,
My router firmware is White Russian 0.9 ( open WRT) , and my problem now is[glow] I can't access Telnet[/glow] so I can transfer the sensor feedback to visual basic..
Any suggestions? Or Will I have to change my firmware to dd-wrt?
Regards :-[
martin_bg
would this work if lets say i would like to upload a sketch to a remotely located arduino?
igorreal
I suppuse that you can activate to load telnet service again when the router starts..... I'm not a linux expert, but I can't believe that you can't activate it...
http://ram.squat.net/tech/openwrt/whiterussian_client_setup.html
(here you can see how the telnet service is disable)
If you don't have telnet, I imagine that you have ssh, which it's more safe. I've never checked if there are free ActiveX ssh clients.....
Erac
Hi Igor,
Do you know the code in Visual Basic 6.0 or Excell that will get the data via SSH? When I try Winsock the access is denied, maybe because it gets data via telnet? which is problematic for my firmware
Regards :-/
igorreal
#20
Dec 19, 2010, 12:56 am Last Edit: Dec 19, 2010, 12:57 am by igorreal Reason: 1
Look at this method..... it´s nice. You can download ser2net
http://www.andrewhazelden.com/blog/2010/01/how-to-use-the-serial-ports-on-a-linksys-wrt54gs-with-dd-wrt-v24/
http://todbot.com/blog/2010/12/16/wifi-for-arduino-with-asus-wl-520gu/
And use a virtual serial port:
http://www.hw-group.com/products/hw_vsp/index_en.html
mrmeval
http://www.dailywireless.org/2009/02/24/marvells-99-wall-wart-computer/
I've not seen this disassembled but it is Arm based and 99 dollars.
