SurferTim:
I used this in w5100.h. I commented out all the old code and used digitalWrite() instead. Worked great on my Mega. Give it a try.
I tried digitalWrite() but it didn't work for me. If I used pin 10 with digitalWrite() it would work. When i changed to pin 8 it didn't work. I also tried pin 9 and 7, they didn't work either. When I change the pin number, I moved the wire on the Arduino to that pin. So when I tried digitalWrite with pin 8, the jumper was connected from Arduino pin 8 to Ethernet shield pin 10,
BTW - I'm using Arduino IDE ver 1.05 on a Mac. My Arduino is a Duemilanove with Adafrut's adaboot boot loader.
SurferTim:
I have since modified that to select the slave select through an Ethernet library call so I can access two ethernet shields in the same sketch code.
Would you mind sharing your modified libraries?
ScottG:
OK. They are attached. These are from IDE v1.0.5, but should also work with IDE v1.5.x also. I tested it with v1.5.5.
To select the slave select, use
Ethernet.select(10);
Bear in mind if you are also using the SD card, you must disable the w5100 slave select also.
No guarantees, but if you have a problem, let me know.
edit: Use code in reply #21.
Thanks! I'll let you know how it works out. I'm not using the SD card.
It isn't working. It has problems with dhcp. I'm working on it now.
edit: I found the problem. I'm testing it now. If it works ok in the morning, I'll post the new code.
OK. It works now. The new files are attached. I tried most of the sketches I have and all are running ok.
It should be compatible with older sketches now. If you do not call Ethernet.select(), it uses D10 by default.
Here is the DhcpAddressPrinter sketch from the ethernet library examples modified for D9 as the w5100 slave select. I bent D10 on the shield so it wouldn't insert into my Mega, then jumpered D10 and D9 on the shield.
DHCP-based IP printer
This sketch uses the DHCP extensions to the Ethernet library
to get an IP address via DHCP and print the address obtained.
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 12 April 2011
by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
int freeRam() {
extern int __heap_start,*__brkval;
int v;
return (int)&v - (__brkval == 0 ? (int)&__heap_start : (int) __brkval);
// start the serial library:
pinMode(4,OUTPUT);
digitalWrite(4,HIGH);
Serial.print(F("SRAM left: "));
Serial.println(freeRam());
// start the Ethernet connection:
Ethernet.select(9);
Serial.println("Starting ethernet");
while (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
delay(5000);
Serial.println("trying DHCP again");
// print your local IP address:
Serial.print("My IP address: ");
for (byte thisByte = 0; thisByte < 4; thisByte++) {
// print the value of each byte of the IP address:
Serial.print(Ethernet.localIP()[thisByte], DEC);
Serial.print(".");
Serial.println();
byte updateVal = Ethernet.maintain();
if(updateVal) {
Serial.print(F("DHCP maintain..."));
switch(updateVal) {
case 0: Serial.println(F("no action"));
break;
case 1: Serial.println(F("renew failed"));
break;
case 2: Serial.println(F("renew success"));
break;
case 3: Serial.println(F("rebind failed"));
break;
case 4: Serial.println(F("rebind success"));
break;
default: Serial.println(F("unknown"));
edit: Use the files in reply #21.
SurferTim,
I'm trying your modified files, but I'm having some trouble getting it to compile. I put the 4 files (Ethernet.h/cpp, w5100.h/cpp) in the same directory as my INO file; so in the Arduino IDE (1.05 on Mac) they show up as tabs. When I use the sketch you posted, I get this error:
error: 'class EthernetClass' has no member named 'select'
I'm including the library with <> like this:
So I assume the sketch us using the built-in Ethernet.h library and not the modified one in my INO directory . So I changed the syntax to:
#include "Ethernet.h"
So now I think it's using your version that's in my sketch directory, but I'm getting tons of multiple definition errors.
I'd prefer to leave the original Ethernet.h and w5100.h files alone. What's the right way to do this?
If you do not want to replace the files in the ethernet library with my files, then you are dead in the water.
I recommend renaming your original w5100 and Ethernet files before replacing them. That is what I did.
I renamed:
w5100.h to w5100.h.orig
w5100.cpp to w5100.cpp.orig
Ethernet.h to Ethernet.h.orig
Ethernet.cpp to Ethernet.cpp.orig
Then I moved my files into those directories. If all goes bad, remove my files and rename those .orig files back to the original filenames.
SurferTim:
I renamed:
Okay, I'll try it that way. I was hoping to avoid doing that because I use several computers to program my Arduinos. So I have to change it everywhere. Also, when I upgrade the IDE, I have to remember to change the files again. How come the header guards don't solve the multiple definition problem?
#ifndef ethernet_h
#define ethernet_h
I don't know about the multiple definition part. I think it is the difference between the way sketches are compiled into the code versus the libraries.
But on the "several computers" part, I can sympathize with you. I even have computers with multiple IDE versions that I must change the files on each version. It is a pain in the backside, but if you want the movable slave select pin, it is part of it.
Surfer Tim,
Using you modified library for slave select, I can't create an Ethernet connection using the static IP method, like this:
IPAddress ip(192,168,216,40);
Ethernet.begin(mac, ip);
It works fine if I use DHCP method:
Ethernet.begin(mac);
The static method does work if my slave select pin is 10, but if it's something else, the sketch doesn't set the IP address. Instead of the IP I'm trying to set, I get 255,255,255,255
A big advantage to static IP is it uses a lot less memory, so I'd like to get this working. Any ideas on how to fix it?
Are you bending the D10 pin on the ethernet shield so it doesn't insert into the Arduino?
Are you jumpering the D10 pin on the shield to the new slave select?
Are you calling Ethernet.select() before Ethernet.begin() to select the new slave select? I just changed mine to D8 and this worked.
Ethernet.select(8);
The Ethernet shield is not stacked on the Arduino, I'm using jumpers for everything. I connecting D9 on the Arduino to D10 on the Ethernet shield. I'm also trying it with a WIZ811 module and for that I have a PCB I made. On that sketch I think I'm using D7 on the Arduino going to WIZ811 SS pin.
I've got the Ethernet.Select(9) statement before Ethernet.begin().
Everything works fine if I connect with DHCP, so I don't think I've got anything wired wrong or it wouldn't work at all.
I just tried a static IP and dhcp. Both worked.
Hmm. I guess I'll have to do some more tinkering. Which model Arduino are you using?
I'm using a Mega 2560, but that shouldn't make a difference if the DHCP sketch is working for you.
I figured out why the static IP wasn't working. Above the Ethernet.select() statement, I need to use pinMode() to define the SS pin as an output. If I don't do that, DHCP works, but static doesn't. Also, if the pin happens to be the standard SS pin (53 for the mega), then I don't need pinMode().
Thanks Scott. Do you mean the new SS pin (D8), or the default SS pin (D10) must be set to OUTPUT?
edit: You should not have to set the default SS to OUTPUT and HIGH. That is done when the Ethernet.begin() function calls W5100.init(), which calls SPI.begin(). The SPI.begin() function sets the default SS pin to OUTPUT and HIGH.
You must mean the new slave select pin. The files I posted earlier are missing that update. My newer updated code does that for you. I attached the new files to this post just to insure all my recent changes are included.
For anyone else wanting to try this, insure you rename your original w5100.h, w5100.cpp, Ethernet.h, and Ethernet.cpp files before overwriting them with these. That way if all goes wrong, you have your old code to fall back on.
w5100.h (14.3 KB)
w5100.cpp (4.09 KB)
Ethernet.h (1.21 KB)
Ethernet.cpp (3.46 KB)
SurferTim:
I meant the new SS pin (like D8) should be set to OUTPUT. I didn't set it HIGH or LOW, just made it an output. Thanks for attaching the latest update.
SurferTim,
Would you be able to make the same slave select changes to the files that come with Arduino IDE 1.5.8? I've attached the 1.5.8 versions of w5100.h/cpp and Ethernet.h/cpp. Ethernet.h is unchanged. I also used diffchecker.com to show the differences between the 1.0.5 and 1.5.8 versions of these files. I made permanent diffchecker links for each:
w5100.h Saved diff th85o2pf - Diff Checker
w5100.cpp Saved diff f4kd9wp2 - Diff Checker
Ethernet.h Saved diff ku1uuhck - Diff Checker
Ethernet.cpp Saved diff o0y6nmzd - Diff Checker
Arduino_1_5_8_Files.zip (6.73 KB)
