Topic: Connecting Arduino to iPhone/iPod serial (Read 36659 times) previous topic - next topic
Easty
pjamestx, I'm using the 168 and Rosie's issue could be the same reason I'm having some odd behaviour! I'll keep you posted but to be honest I'm trying but I'm getting to the edge of my knowledge with all this!  Turning LEDs on and off is one thing but serial comms isn't something I've attempted before, nothing like keeping it simple! ::)
My next thought is to get an LCD display hooked up so I can check what's being sent (the project will need one in the end anyway)
I've ordered the correct connector now so I won't have to use the one I've recycled from an old Firewire cable (the connections are a nightmare to solder to as they've been cut off and are about 0.5mm!)
Easty
Success!
I've managed to get the Arduino and iPod communicating and can play/pause, skip forward and back, move forward and back through tacks and change the volume (iPod mode 2),
This is the code I'm using, a bit scruffy, sorry!
Code: [Select]
Controls an iPod through the dock connector's serial interface.
Tx (output 1) ---[1k]-------------iPod pin13 Rx
                        |   -----iPod pin21 Accessory
                        2k  1m
Gnd-------------------------------iPod pin11 Ground
                       +5v
                       2k2
analog inputs 0-4 --------------/switch/--- 0v
v0.3 - Added switches code
v0.2 - Added DEBUG mode
Added the DEBUG switch to be able to read the output without having an iPod connected.
v0.1 - Initial code
iPod mode 2 (simple iPod remote) only.
Resources used:
http://www.rosiedaniel.com/search/label/ipod
http://stud3.tuwien.ac.at/~e0026607/ipod_remote/ipod_ap.html
     http://instruct1.cit.cornell.edu/courses/ee476/FinalProjects/s2007/awr8_asl45/awr8_asl45/index.html
     http://ipodlinux.org/wiki/Apple_Accessory_Protocol
     http://pinouts.ru/Devices/ipod_pinout.shtml
Mode 2 Commands
Command             |Purpose
0x00 0x00            |Button Released
0x00 0x01            |Play
0x00 0x02            |Vol+
0x00 0x04            |Vol-
0x00 0x08            |Skip>
0x00 0x10            |Skip<
0x00 0x20            |Next Album
0x00 0x40            |Previous Album
0x00 0x80            |Stop
//Debug switch
//boolean DEBUG = true;                             //Send serial output in HEX with other formatting
boolean DEBUG = false;                          //Send serial output in BYTE for iPod connection
//Variables for the buttons
int buttonPins[] = {14, 15, 16, 17, 18};          //Array containing the pins the buttons are connected to
int numberOfButtons = 5;                          //The number of buttons connected
boolean buttonStates[]={false,false,false,false,false};    //Arrays for storing button information in
int buttonPresent[]={HIGH,HIGH,HIGH,HIGH,HIGH};    //Arrays for storing buttons states in
int buttonPrevious[]={HIGH,HIGH,HIGH,HIGH,HIGH};       // "
long time;                                        //To keep track of the time for debouncing
int debounce = 200;                               //The debounce delay (from the last button push to the next)
//Define commands for iPod mode 2
byte switchMode2[] =             {0xFF, 0x55, 0x03, 0x00, 0x01, 0x02, 0xFA};
byte buttonRelease =             0x00;
byte PlayPause2 =            0x01;
byte VolUp2 =                  0x02;
byte VolDown2 =                  0x04;
byte SkipForward2 =            0x08;
byte SkipBack2 =            0x10;
byte NextAlbum2 =            0x20;
byte PreviousAlbum2 =            0x40;
byte Stop2 =                    0x80;
void setup ()
 //Start the serial connection
 beginSerial(19200);
 //Setup the buttons
 for (int i=0; i<numberOfButtons; i++)
   pinMode(buttonPins[i], INPUT);
 //Switch to mode 2 (simple ipod remote mode)
 if (DEBUG){Serial.print("Mode 2: ");}
 for (int i = 0; i < 7; i++) {
   if (DEBUG)
     Serial.print(switchMode2[i],HEX);
     Serial.print(" ");
   }else{
     Serial.print(switchMode2[i],BYTE);
 if (DEBUG){Serial.println();}
void loop ()
 //Loop through the amount of buttons
 for (int button=0; button<numberOfButtons; button++)
   //Update the present state of the button
   buttonPresent[button] = digitalRead(buttonPins[button]);
   //If the button state has changed and the debounce duration has passed
   //The debounce period will work for all buttons. This means it will stop different buttons being pressed
   // within the debounce period but this shouldn't be too much of an issue.
   if (buttonPresent[button] != buttonPrevious[button] && millis() - time > debounce)
     //If the button is pressed...
     if (buttonPresent[button] == LOW)
       //Update the button's state in the array
       buttonStates[button] = true;
       if (DEBUG){Serial.print("Button: ");Serial.print(button);Serial.print("  Pressed   ");}
       //Update the time the last button was pressed
       time = millis();
       //Depending on what buttons been pressed send a command
       switch (button)
       case 0:
         sendCommand(VolDown2);
       case 1:
         sendCommand(VolUp2);
       case 2:
         sendCommand(SkipBack2);
       case 3:
         sendCommand(PlayPause2);
       case 4:
         sendCommand(SkipForward2);
     //If the button is not pressed...
     }else{
       buttonStates[button] = false;
       if (DEBUG){Serial.print("Button: ");Serial.print(button);Serial.print("  Released  ");}
       //Send the button release command
       sendCommand(buttonRelease);
     //Update the button's previous state in the array
     buttonPrevious[button] = buttonPresent[button];
void sendCommand(byte cmd)
 //Create a checksum for the command
 byte cs = checkSum(0x03, 0x02, 0x00, cmd, 0x00);
 //Create a bytes to be sent array
 byte bytes[] = {0xFF, 0x55, 0x03, 0x02, 0x00, cmd, cs};
 if (DEBUG){Serial.print("Command: ");Serial.print(cmd, HEX);Serial.print("  ");}
 //Send the bytes
   if (DEBUG)
     Serial.print(bytes[i], HEX);
     Serial.print(" ");
   }else{
     Serial.print(bytes[i], BYTE);
 if (DEBUG){Serial.println("");}
int checkSum(byte len, byte mode, byte command1, byte command2, byte parameter)
 byte checksum = 0x100 - ((len + mode + command1 + command2 + parameter) & 0xFF);
 return checksum;
I've made some advances with Advanced iPod Remote mode (mode 4) as well but no luck in getting text returned as yet. There's also no volume control that I can find in mode 4 which would mean I'd need some more circuitry...
gto
Hi, what model ipod are you controlling with this. thanks
Easty
I've used a 5th generation (the one with video).
I've lent my girlfriend's 3rd generation to a friend but will test that when it gets back!
gto
just finished building it, works perfect with ipod 6G Classic
Cybot_Rules
what did you use to connect to the ipod did you use the one that comes with it when you buy it?
Easty
I bought a couple of connectors from here:
http://home.swipnet.se/ridax/connector.htm
With my eyesight and fat soldering iron they are tough to solder to, I should have gone with the breakout board seeedstudio recommended earlier in the thread to start with! ;)
gto
i used a cheap 99p ipod cable, they only come with 4 pins for usb charging. but you can easily pull the pins and move them.
Easty
Sounds interesting... and cheap!
Where did you get that from?
gto
there from the 99p shop. they have similar ones on ebay very cheap.
Cybot_Rules
Ive seen them in Nsw for about $10 AU might try that one
willems.stijn
#26
Nov 17, 2008, 03:14 pm Last Edit: Nov 17, 2008, 03:15 pm by willems.stijn Reason: 1
Hei,
Just like to point out there is a complete tutorial and code that can be found on http://labs.ideo.com for interfacing and Arduino with a Nokia Tablet not really the same thing but it could get you started.
Cybot_Rules
This reminds me has anyone done this for a Fujitsu tablet pc?
thx in advance
DaveAK
I don't know how much iPhone/Arduino stuff has been mentioned here, but from what I understand OS 3.0 will allow access to the serial connections through the SDK.  I downloaded it last night to try out, but I need to get myself a Touch for development and install OS 3.0 Beta.  Hopefully by the end of the week I'll be able to have some working code.
If anyone's interested send me a PM with ideas.  When I get started I'll open up another thread.
paasselin
