Topic: SPI Interface: Wifi Shield and Arduino Robot (Read 5634 times) previous topic - next topic
stefanmarggraff
Hi, I have problems connecting the Wifi Shield (http://arduino.cc/en/Main/ArduinoWiFiShield) to the Arduino Robot (http://arduino.cc/en/Guide/Robot).  What I have done is, I have connected the components via the ICSP port and the SS pin for the shield to TKD3 on the robot; the 'Handshake' pin, pin 7, to TKD5 on the robot; and the LED pin, pin 9 to TKD4 on the robot.  I  had to use these pins on the robot, because the designated pins are occupied by the LCD.  I changed the pin definitions in the WIFI Library file as follows:
Code: [Select]
#define DATAOUT 10 // MOSI (was pin 11; changed to pin 10)
#define DATAIN  11 // MISO (was pin 12; changed to pin 11)
#define SPICLOCK  9  // sck (was pin 13; changed to pin 9)
#define SLAVESELECT TKD3 // ss (was pin 10; changed to pin TKD3)
#define SLAVEREADY TKD5  // handshake pin (was pin 7; changed to pin TKD5)
#define WIFILED TKD4  // led on wifi shield (was pin 9; changed to pin TKD4)
Following this, I tried to load one of the Wifi example codes and adapted it to work for the robot as follows:
Code: [Select]
This example  prints the Wifi shield's MAC address, and
scans for available Wifi networks using the Wifi shield.
Every ten seconds, it scans again. It doesn't actually
connect to any network, so no encryption scheme is specified.
Circuit:
* WiFi shield attached
created 13 July 2010
by dlf (Metodo2 srl)
modified 21 Junn 2012
by Tom Igoe and Jaymes Dec
#include <ArduinoRobot.h>
#include <SPI.h>
#include <WiFi.h>
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue:
    while(true);
  Robot.begin();
  Robot.beginTFT();
  Robot.beginSD();
  SPI.begin();
  // Print WiFi MAC address:
  printMacAddress();
  // scan for existing networks:
  Robot.println("Scanning available networks...");
  listNetworks();
  delay(10000);
  listNetworks();
void printMacAddress() {
  // the MAC address of your Wifi shield
  byte mac[6];
  // print your MAC address:
  WiFi.macAddress(mac);
  Robot.print("MAC: ");
  Robot.print(mac[5],HEX);
  Robot.print(":");
  Robot.print(mac[4],HEX);
  Robot.print(":");
  Robot.print(mac[3],HEX);
  Robot.print(":");
  Robot.print(mac[2],HEX);
  Robot.print(":");
  Robot.print(mac[1],HEX);
  Robot.print(":");
  Robot.println(mac[0],HEX);
void listNetworks() {
  // scan for nearby networks:
  Robot.println("** Scan Networks **");
  int numSsid = WiFi.scanNetworks();
  if (numSsid == -1)
    Robot.println("Couldn't get a wifi connection");
    while(true);
  // print the list of networks seen:
  Robot.print("number of available networks:");
  Robot.print(numSsid);
  // print the network number and name for each network found:
  for (int thisNet = 0; thisNet<numSsid; thisNet++) {
    Robot.print(thisNet);
    Robot.print(") ");
    Robot.print(WiFi.SSID(thisNet));
    Robot.print("\tSignal: ");
    Robot.print(WiFi.RSSI(thisNet));
    Robot.print(" dBm");
    Robot.print("\tEncryption: ");
    printEncryptionType(WiFi.encryptionType(thisNet));
void printEncryptionType(int thisType) {
  // read the encryption type and print out the name:
  switch (thisType) {
  case ENC_TYPE_WEP:
    Robot.println("WEP");
  case ENC_TYPE_TKIP:
    Robot.println("WPA");
  case ENC_TYPE_CCMP:
    Robot.println("WPA2");
  case ENC_TYPE_NONE:
    Robot.println("None");
  case ENC_TYPE_AUTO:
    Robot.println("Auto");
However, when compiling, I get the following error:
Quote
SPI\SPI.cpp.o: In function `SPIClass::end()':
C:\Users\...\arduino-1.0.5\libraries\SPI/SPI.cpp:44: multiple definition of `SPIClass::end()'
Robot_Control\SPI.cpp.o:C:\Users\...\arduino-1.0.5\libraries\Robot_Control/SPI.cpp:44: first defined here
SPI\SPI.cpp.o: In function `SPIClass::setBitOrder(unsigned char)':
C:\Users\...\arduino-1.0.5\libraries\SPI/SPI.cpp:49: multiple definition of `SPIClass::setBitOrder(unsigned char)'
Robot_Control\SPI.cpp.o:C:\Users\...\arduino-1.0.5\libraries\Robot_Control/SPI.cpp:49: first defined here
SPI\SPI.cpp.o: In function `SPIClass::setDataMode(unsigned char)':
C:\Users\...\arduino-1.0.5\libraries\SPI/SPI.cpp:58: multiple definition of `SPIClass::setDataMode(unsigned char)'
Robot_Control\SPI.cpp.o:C:\Users\...\arduino-1.0.5\libraries\Robot_Control/SPI.cpp:58: first defined here
SPI\SPI.cpp.o: In function `SPIClass::setClockDivider(unsigned char)':
C:\Users\...\arduino-1.0.5\libraries\SPI/SPI.cpp:63: multiple definition of `SPIClass::setClockDivider(unsigned char)'
Robot_Control\SPI.cpp.o:C:\Users\...\arduino-1.0.5\libraries\Robot_Control/SPI.cpp:63: first defined here
SPI\SPI.cpp.o: In function `SPIClass::begin()':
C:\Users\...\arduino-1.0.5\libraries\SPI/SPI.cpp:19: multiple definition of `SPIClass::begin()'
Robot_Control\SPI.cpp.o:C:\Users\...\arduino-1.0.5\libraries\Robot_Control/SPI.cpp:19: first defined here
SPI\SPI.cpp.o:C:\Users\...\arduino-1.0.5\libraries\SPI/SPI.cpp:44: multiple definition of `SPI'
Robot_Control\SPI.cpp.o:C:\...e\arduino-1.0.5\libraries\Robot_Control/SPI.cpp:44: first defined here
I guess that I have to change the SPI Library, according to how the Wifi Shield operates; i.e. change the following functions:
Code: [Select]
void SPIClass::end() {
  SPCR &= ~_BV(SPE);
void SPIClass::setBitOrder(uint8_t bitOrder)
  if(bitOrder == LSBFIRST) {
    SPCR |= _BV(DORD);
    SPCR &= ~(_BV(DORD));
void SPIClass::setDataMode(uint8_t mode)
  SPCR = (SPCR & ~SPI_MODE_MASK) | mode;
void SPIClass::setClockDivider(uint8_t rate)
  SPCR = (SPCR & ~SPI_CLOCK_MASK) | (rate & SPI_CLOCK_MASK);
  SPSR = (SPSR & ~SPI_2XCLOCK_MASK) | ((rate >> 2) & SPI_2XCLOCK_MASK);
...But how, and what exactly?
I would really appreciate your help.
Thank you.
Kind regards
Stefan
Coding Badly
Do not cross-post.  Other topic deleted.  Replies go here.
stefanmarggraff
SurferTim
I wouldn't change the SPI library. I would remove those functions from the robot library. Those are functions already in the SPI library.
stefanmarggraff
The functions I displayed above are from the SPI library.  Which functions exactly are you saying I should remove?
SurferTim
There are duplicate functions in your "/libraries/Robot_Control/SPI.cpp" that are also in "/libraries/SPI/SPI.cpp". That is what is generating the error. I would try removing the SPI files from "/libraries/Robot_Control". The ethernet shield needs those functions in "/libraries/SPI" or it will not function.
stefanmarggraff
stefanmarggraff
I did as you suggested and deleted the SPI header and cpp files.  It does compile now, however, nothing happens when uploaded.  Do you have any further suggestions for me, please?
stefanmarggraff
When I try the following code:
Code: [Select]
#include <SPI.h>
#include <WiFi.h>
//SSID of your network
char ssid[] = "yourNetwork";
//password of your WPA Network
char pass[] = "secretPassword";
  Robot.begin();
  Robot.beginTFT();
  Robot.beginSD();
  SPI.begin();
  WiFi.begin(ssid, pass);
  if (WiFi.status() != WL_CONNECTED) {
    while(true);
  // if you are connected, print out info about the connection:
  else {
   // print the received signal strength:
  long rssi = WiFi.RSSI();
  Robot.print("RSSI:");
  Robot.println(rssi);
void loop () {}
I get the error message that no WifiShield is connected and the red 'Error' LED on the shield is on.  Does this mean I made an error when connecting or is it a software problem?
SurferTim
This should be the way to connect. Put this code after SPI.begin(); This is from the example ConnectWithWPA example.
Code: [Select]
   // don't continue:
   while(true);
// attempt to connect to Wifi network:
 while ( status != WL_CONNECTED) {
   Serial.print("Attempting to connect to SSID: ");
   Serial.println(ssid);
   // Connect to WPA/WPA2 network:
   status = WiFi.begin(ssid, pass);
   // wait 10 seconds for connection:
   delay(10000);
 // you're connected now
 Serial.print("You're connected to the network");
stefanmarggraff
what should the variable status be defined as?
stefanmarggraff
Now I get the error message: "Wifi shield not present" and again, the red LED on the shield is on.
Any suggestions, please?
stefanmarggraff
I commented out the test for a Wifi Shield as can be seen in the code below; but it now gets stuck in the loop: "Attempting to connect...".  However, the "Error" LED is not on anymore, instead the green "Link" LED is now on.
Code: [Select]
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "SANO";
char pass[] = "NakedMexican";
int status = WL_IDLE_STATUS;     // the Wifi radio's status
Robot.begin();
Robot.beginTFT();
Robot.beginSD();
/* if (WiFi.status() == WL_NO_SHIELD) {
    Robot.println("WiFi shield not present");
    // don't continue:
    while(true);
    Robot.print("Attempting to connect to SSID: ");
    Robot.println(ssid);
    delay(10000);
  Robot.print("You're connected to the network");
    while(true);
  else {
void loop () {}
SurferTim
You can't just comment out the test for the shield and expect it to work. You must determine why it is not finding the shield.
Did you do this? These pins are the SPI bus. If you change them, it certainly won't work.
Quote
stefanmarggraff
I thought I'd give it a try...
Yes, I did that, because the pins for the SPI bus in the documentation did not match the definitions.  I will change them back and give it a try.
