Topic: SPI Interface: Wifi Shield and Arduino Robot (Read 5808 times) previous topic - next topic
stefanmarggraff
Changed them back as they were:
Code: [Select]
#define DATAOUT 11 // MOSI
#define DATAIN  12 // MISO
#define SPICLOCK  13  // sck
#define SLAVESELECT TKD3 // ss (was pin 10; changed to pin TKD3)
#define SLAVEREADY TKD5  // handshake pin (was pin 7; changed to pin TKD5)
#define WIFILED TKD4  // led on wifi shield (was pin 9; changed to pin TKD4)
and still the same error message: "Wifi shield not present"
SurferTim
If you have the wifi library back the way it was, then you have interference from the robot SPI interface. Which pin does it use for the SPI slave select?
stefanmarggraff
Sorry, but I don't quite understand your question.  The slave select is connected to pin 10 on the Wifi Shield, and pin TDK3 on the Robot Control Board.  Is that what you were asking?
SurferTim
#18
Feb 16, 2014, 12:53 pm Last Edit: Feb 16, 2014, 01:01 pm by SurferTim Reason: 1
Yes. You can't use D10 for both slave select pins. The wifi shield uses D10 as the slave select, and the wifi library expects that pin to be the slave select. It appears the robot also uses D10. That is why you can't get the wifi shield to initialize, or even respond to the "shield not present" function call.
edit: If you want to try changing the wifi slave select, you had the right file, but you changed too many pins. The only one you needed to change was this one.
Code: [Select]
#define SLAVESELECT 10 // ss
Change that to another pin and bend D10 on the wifi shield so it doesn't insert into the Arduino, then jumper D10 on the shield to the new pin. Insert the robot's slave select into D10 on the Arduino.
FYI: You can't use D7 for the robot either. It is the wifi shield handshake pin.
stefanmarggraff
So, just to clarify, this change is correct:
Code: [Select]
and all the other pins remain unchanged?
I assume I can also remove the other two physical connections I made?
SurferTim
Which pin is TKD3? Which Arduino board are you using?
stefanmarggraff
TKD3 is an open I/O pin, as are TKD4 and TKD5.  I am using the Robot Control Board; i.e. the top board of the two, of the Arduino Robot.
SurferTim
Post a link to that robot control board please, just to insure I am  looking at the right one.
stefanmarggraff
The respective pins are discussed in the section "Inputs and Outputs" on the following page: http://arduino.cc/en/Main/Robot
I have attached a detailed layout.
SurferTim
All the pins are different. The SPI data pins are not the same. It would take major editing in the wifi library to get it to work. Maybe someone else has a solution for you. I don't have the robot board to experiment with.
BTW, TKD3 is D22 according to the pin map. Use 22 as the ss.
stefanmarggraff
Could I not get it to work by means of changing it to SS=pin22 and the others as I had them?
stefanmarggraff
karl67
anyone get this to work? Im having exactly the same issue
stefanmarggraff
Karl67 please let me know if you manage to do this! I am urgently looking for advice!
Regards
Stefan
stefanmarggraff
Hi, I solved this issue. Check here how: http://arduinorobothelp.wordpress.com/
