Topic: New TFT Extension Library (Read 54845 times) previous topic - next topic
gromgsxr
ok im pulling data from a megasquirt ecu via serial, i trying to make a display to show various information from the engine sensors connected to that, for instance using the slider like a bar graph to display throttle the throttle.
HazardsMind
Oh ok, so the other way around, instead of being a slider, you want a bar graph. Yea I can do that.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
gromgsxr
Ah that would rock, just tried your update and its working good tried with 4 gauges on the screen, had them all reading from a 10k pot  all working good thanks. i did try it before with just one gauge and it worked on pulling the data via serial and displaying it on the gauge as well
HazardsMind
#48
May 18, 2014, 02:08 am Last Edit: May 18, 2014, 02:31 am by HazardsMind Reason: 1
Library is updated with new functions, HorBarGraph and VertBarGraph. Go back to previous post and re-download.
Look at Horizontal_BarGraph example to see how it is used.
I also added your username to the .h file.
My GitHub:
gromgsxr
oh got it that rocks, with those additions gives me just what i need to continue with my project.
gromgsxr
been playing about with this some more, i'm using a switch case from a push button input to change between 3 different pages i want it to draw that works, first page just basic prints to the screen of the sensor readings, push button then page 2 so far i'm using drawgauge to draw 2 gauges one for engine rpm and the second for throttle 0-100% they work its a bit slow drawing them at  first but the needle movements are quick enough after the back ground has drawn to the screen not to much of a biggie, then page3 will be some bar graphs ect not got that far yet though. the issue im having if you cycle from page 1,2,3 back to 1 then the second time on to page 2 the backgrounds don't get drawn only the needles part of the gauges.
cyclegadget
Gromgsxr,
Would you mind sharing some of your switch case code? I am wanting to learn how to put the buttons and gauges to use but, I haven't figured it out yet.
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
HazardsMind
#52
May 19, 2014, 01:55 pm Last Edit: May 19, 2014, 01:58 pm by HazardsMind Reason: 1
Ok, I can make a quick function to allow you to repaint the gauge.
Added:
Function: ResetGauge( byte _ID ), This should go in the next and previous pages of the gauge. So if your gauges are on page 2, then this function needs to be in pages 1 and 3. So when you go back to page 2, the gauge will be repainted.
Library added below.
My GitHub:
gromgsxr
wicked il give that a go and report back thanks again, this is a basic striped down version of how i'm drawing the pages.
Code: [Select]
  #include <UTFT.h>
#include <UTouch.h>
#include <memsaving.h>
#include <TFT_Extension.h>
extern uint8_t BigFont[];
UTFT myGLCD(SSD1289,38,39,40,41);
UTouch        myTouch(6,5,4,3,2);
TFT_Extension myTFT(&myGLCD, &myTouch, LANDSCAPE);
const int  buttonPin = A1;    // the pin that the pushbutton is attached to
int buttonPushCounter = 0;   // counter for the number of button presses
int ButtonState = 0;         // current state of the button
int lastState = 0;     // previous state of the button
void page1(){
  myGLCD.setFont(BigFont);
  myGLCD.setColor(255, 0, 0);
  myGLCD.print(" page 1 ",CENTER, 80);
void page2(){
  myGLCD.setColor(0, 255, 0);
  myGLCD.print(" page 2 ",CENTER, 120);
void page3(){
  myGLCD.setColor(0, 0, 255);
  myGLCD.print(" page 3 ",CENTER, 150);
  pinMode(buttonPin, INPUT);
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.print(" TEST ",CENTER, 1);
  myGLCD.clrScr();
  ButtonState = digitalRead(buttonPin);
  if(ButtonState && ButtonState != lastState)  // button latch, no debounce needed.
    if(buttonPushCounter < 2) // This will check to see if the count is within a range of 0 - 2, and anything over that, it will reset count back to 0. Of course, this will happen anyways because count is a BYTE, and not an int or any other type.
      buttonPushCounter += 1; // same as count = count + 1;
    myGLCD.clrScr();
  lastState = ButtonState;
  switch (buttonPushCounter) {
  case 0:
    page1();
  case 1:
    page2();
  case 2:
    page3();
HazardsMind
You could put the reset functions inside the case statements before you load the pages. Or you can put them inside the pages themselves, whichever is easier for you.
My GitHub:
gromgsxr
i put them in the case statements  for case 0 and 2 and now they re draw   :D :D
gromgsxr
i was having a play with this again and run in to a problem the gauges were taking a long time to draw a couple of seconds maybe and this was sometimes causing me to loose sync  with the data form the ecu so i made a small edit to the library...
Code: [Select]
_Disp->setColor(WHITE);
_Disp->fillCircle(pos_x, pos_y, rad);
//drawArc(pos_x, pos_y, rad, rad, start, stop, WHITE);
//drawArc(pos_x, pos_y, rad, 0, start, stop, BLACK);
does not look quite as cool but draws and re-draws super quick and you can still set the sweep angle for the gauge, hope you don't mind.
HazardsMind
#57
May 21, 2014, 01:41 am Last Edit: May 21, 2014, 08:12 pm by HazardsMind Reason: 1
If it helps you then that's fine. I will try to make it faster if I can.
My GitHub:
robtillaart
Code: [Select]
  gauge[_ID].x = pos_x + sin((value-90) * deg_to_rad) * (rad-2);
  gauge[_ID].y = pos_y + cos((value-90) * deg_to_rad) * (rad-2);
you could remove the -90 from the formulas
Code: [Select]
sin(value -90)  =>  -cos(value)
cos(value-90)  => sin(value)
you might want to speed up the sin and cos like discussed here
- http://forum.arduino.cc/index.php?topic=69723.0 -
and
- http://forum.arduino.cc//index.php?topic=196625.msg1453433#msg1453433 -
make wrappers around  a (PROGMEM) lookup table that works in degrees
the code would become faster but longer.
(there are 31 places in your lib where you use sin( x * degtorad)  + 30 cos()  == 60 places to speed up.
so the extra bytes might be worth the performance  gain
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
HazardsMind
If I have time, I will look into it, thanks robtillaart
My GitHub:
