Topic: connecting 5v 1ch relay module to pin 3 (Read 3206 times) previous topic - next topic
adalarasu
hi everyone,
i have a doubt to get clarified please help me.
iam trying to connect a 5v 1ch relay module to arduino uno digital pin 3, do i have to introduce any sort of resistance or other component between the 'pin3'  &  the module's 'signal in'  pin or directly.
regards,
adal.
knut_ny
What relay?
Picture/link/more info needed
Ny
adalarasu
hi,
its a 5v single channel relay module
the relay module which iam using is not optocoupled,
there are three inputs for this module
1. +5v dc, which i have connected to the uno's 5v
2. gnd, which i have connected to uno's gnd
3. line, which i have connected to uno's pin no 3.
i have uploaded the sketch and its working finely without any load connected to the relay,
when i tried to connect a load (a 220 V AC Water solenoid valve) between the relay's NO contact, the 16 X 2 lcd display's 1st row displays various symbols.
if i disconnect the load and run the sketch, the lcd displays exactly what i have entered.
pls help me.
regards,
adal.
spycatcher2k
Add Capacitors to smooth out the interference & an 'Flyback' Diode (Search google for both) - it's interference from the relay or the load you are switching.
http://www.uk-pcb.co.uk - UK Based PCB Fab Company
I will code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
adalarasu
hi,
even after connecting a decoupling capacitor and fly back diode, the problem not yet solved,
i have posted a new thread details my problem with the image, kindly help me
regards,
adal.
RudiAhlers
hi,
regards,
adal.
Why didn't you post it here?
Or link from here to the new post?
