Topic: passing argument to a function (Read 4051 times) previous topic - next topic
Nicotiere
I tried to write a simple function reading temperature with a single argument as the probe address:
static byte sonde_Ballon[8] = {0x28 , 0xA5 , 0xDD , 0x5A ,  0x03 , 0x00 , 0x00 , 0x3C } ;
function:
void getTemperature( byte Sonde) {
call:
getTemperature(*sonde_Ballon) ;
   I got these errors I don't really understand:
Monitor_Chaudiere.cpp: In function 'void getTemperature(byte)':
Monitor_Chaudiere.cpp:721:29: error: invalid conversion from 'byte' to 'const uint8_t*'
Monitor_Chaudiere.cpp:721:29: error:   initializing argument 1 of 'static uint8_t OneWire::crc8(const uint8_t*, uint8_t)'
Monitor_Chaudiere.cpp:721:41: error: invalid types 'byte[int]' for array subscript
Monitor_Chaudiere.cpp:722:12: error: return-statement with a value, in function returning 'void'
Monitor_Chaudiere.cpp:732:18: error: invalid conversion from 'byte' to 'const uint8_t*'
Monitor_Chaudiere.cpp:732:18: error:   initializing argument 1 of 'void OneWire::select(const uint8_t*)'
Monitor_Chaudiere.cpp:738:18: error: invalid conversion from 'byte' to 'const uint8_t*'
Monitor_Chaudiere.cpp:738:18: error:   initializing argument 1 of 'void OneWire::select(const uint8_t*)'
Monitor_Chaudiere.cpp:745:4: error: invalid type argument of unary '*'
Monitor_Chaudiere.cpp: At global scope:
Monitor_Chaudiere.cpp:841:1: error: expected declaration before '}' token
Is there a problem with the byte variable. I don't find good example on the web.
Thanks for your help
pYro_65
Make sure Arduino.h is included if this code isn't in the main sketch file, byte is declared in that header.
Those errors are from the code inside your function it looks like.
Post the code!
Forum Mod anyone?
https://arduino.land/Moduino/
robtillaart
from the snippet you posted I assume you are using the Dallas Temperature Control Library
use getTemperature(sonde_Ballon);  // without the *
as getTemperature expects a pointer to the address array.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Nicotiere
#3
Feb 16, 2014, 02:31 pm Last Edit: Feb 16, 2014, 06:29 pm by robtillaart Reason: 1
with Arduino.h included and without the * pointer I got these same  errors messages: Yes, I use DS18B20.
Monitor_Chaudiere.cpp:722:29: error: invalid conversion from 'byte' to 'const uint8_t*'
Monitor_Chaudiere.cpp:722:29: error:   initializing argument 1 of 'static uint8_t OneWire::crc8(const uint8_t*, uint8_t)'
Monitor_Chaudiere.cpp:722:41: error: invalid types 'byte[int]' for array subscript
Monitor_Chaudiere.cpp:723:12: error: return-statement with a value, in function returning 'void'
Monitor_Chaudiere.cpp:733:18: error: invalid conversion from 'byte' to 'const uint8_t*'
Monitor_Chaudiere.cpp:733:18: error:   initializing argument 1 of 'void OneWire::select(const uint8_t*)'
Monitor_Chaudiere.cpp:739:18: error: invalid conversion from 'byte' to 'const uint8_t*'
Monitor_Chaudiere.cpp:739:18: error:   initializing argument 1 of 'void OneWire::select(const uint8_t*)'
Monitor_Chaudiere.cpp:746:4: error: invalid type argument of unary '*'
Monitor_Chaudiere.cpp: In function 'void loop()':
Monitor_Chaudiere.cpp:814:33: error: invalid conversion from 'byte*' to 'byte'
Monitor_Chaudiere.cpp:814:33: error:   initializing argument 1 of 'void getTemperature(byte)'
Monitor_Chaudiere.cpp:842:1: error: expected declaration before '}' token
the complete subroutine is there:
Code: [Select]
// boolean getTemperature(float *temp)
 byte data[9], addr[8];
 // data : Données lues depuis le scratchpad
 // addr : adresse du module 1-Wire détecté
 if (OneWire::crc8(Sonde, 7) != Sonde[7]) // Vérifie que l'adresse a été correctement reçue
   return false;                        // Si le message est corrompu on retourne une erreur
 /* if (Sonde[0] != DS18B20) // Vérifie qu'il s'agit bien d'un DS18B20
   return false;         // Si ce n'est pas le cas on retourne une erreur
  // Serial.print("0x");
       for (int i=0; i<8; i++) {
         if (Sonde[i]<0x10) {Serial.print("0");}
         Serial.print(Sonde[i],HEX);
         Serial.print(" "); } */
 ds.reset();             // On reset le bus 1-Wire
 ds.select(Sonde);        // On sélectionne le DS18B20
 ds.write(0x44, 1);      // On lance une prise de mesure de température
 delay(800);             // Et on attend la fin de la mesure
 ds.write(0xBE);         // On envoie une demande de lecture du scratchpad
 for (byte i = 0; i < 9; i++) // On lit le scratchpad
   data[i] = ds.read();       // Et on stock les octets reçus
 // Calcul de la température en degré Celsius
 *temp = ((data[1] << 8) | data[0]) * 0.0625;
 // Pas d'erreur
 // return true;
this routine work perfectly without argument and  a  ds.select(address);  anyone ds18B20 plugged.
Thanks
Dominique
update moderator: added code tags
UKHeliBob
That code looks really pretty mostly in italics and the cool smiley makes a change from normal boring looking code too..
Please post it again in code tags as suggested in the stickies at the top of this forum.  That will stop it being mangled when it comes across
Code: [Select]
[i]in the code which turns on italics, and will prevent
Code: [Select]
8) turning into a smiley.
Once we can read the code we may be able to give some help.
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
Nicotiere
here is the example which works, followed bythe example which works:
Code: [Select]
#include <OneWire.h> // Inclusion de la librairie OneWire
#define DS18B20 0x28     // Adresse 1-Wire du DS18B20
#define BROCHE_ONEWIRE 10 // Broche utilisée pour le bus 1-Wire
OneWire ds(BROCHE_ONEWIRE); // Création de l'objet OneWire ds
// Fonction récupérant la température depuis le DS18B20
// Retourne true si tout va bien, ou false en cas d'erreur
boolean getTemperature(float *temp){
  if (!ds.search(sonde_Ballon)) {
    // Serial.println("pas trouvee") ;
   // if (!ds.search(addr)) { // Recherche un module 1-Wire
    ds.reset_search();    // Réinitialise la recherche de module
    return false;         // Retourne une erreur
  if (OneWire::crc8(sonde_Ballon, 7) != sonde_Ballon[7]) // Vérifie que l'adresse a été correctement reçue
  if (sonde_Ballon[0] != DS18B20) // Vérifie qu'il s'agit bien d'un DS18B20
          if (sonde_Ballon[i]<0x10) {Serial.print("0");}
          Serial.print(sonde_Ballon[i],HEX);
  ds.select(sonde_Ballon);        // On sélectionne le DS18B20
  // Pas d'erreur
  return true;
// setup()
  Serial.begin(9600); // Initialisation du port série
// loop()
  float temp;
  // Lit la température ambiante à ~1Hz
  if(getTemperature(&temp)) {
and the exemple which works:
    // Affiche la température
    Serial.print("Temperature : ");
    Serial.print(temp);
    Serial.write(176); // caractère °
    Serial.write('C');
and my routine, I just want to pass the id of DS18B20 as an argument:
[code]void getTemperature( byte Sonde) {
  // Pas d'erreur
  // return true;
: [/code]
wildbill
Rather than:
Code: [Select]
try:
Code: [Select]
void getTemperature( byte *Sonde)
Nicotiere
nothing new with *Sonde:
Monitor_Chaudiere.cpp: In function 'void getTemperature(byte*)':
Monitor_Chaudiere.cpp:813:34: error: invalid conversion from 'byte' to 'byte*'
Monitor_Chaudiere.cpp:813:34: error:   initializing argument 1 of 'void getTemperature(byte*)'
wildbill
That's because you have unrelated errors. The first of them refers to trying to return a boolean from a function you've declared to be void rather than bool.
Nicotiere
sorry in the code I attached I mixed the example followed by my routine. In the example there is a return boolean but in my code there is not I comment.
wildbill
If you're still having trouble, probably best if you post your latest code.
PaulS
Quote
All of it, and NOTHING else.
Nicotiere
code too big (>9500) I try to attach the  file .ino
wildbill
Still the same issue (among others):
Code: [Select]
void getTemperature( byte *Sonde) {
robtillaart
if you remove these 2 lines
Code: [Select]
does it return a meaningful temperature?.
Rob Tillaart
