Topic: [SOLVED] Help with "dynamic" statement with string and pin state (Read 789 times) previous topic - next topic
bule
Here is my code:
else if (txtmsg.compareTo("status") == 0)
    String statustxt = "";
    pinstate = digitalRead(pin);
    if (pinstate == 1){
    sms.remoteNumber(remoteNumber, 10);
    sms.beginSMS(remoteNumber);
    sms.print(statustxt);
    sms.endSMS();
I need to complete the code to do next (my pseudo code)
if txt message is status do next:
if pinstatus == 1
    sting is: relay 'pin' is on
string is: relay 'pin' is off
    sms.print(string);
    sms.endSMS();
My brain is stuck, I mean I am stuck at how to create one string with two states.
PaulS
Probably because that isn't what you want to do. You want to create a string (or String) with one of two different states.
char stg[32];
if(i == 27)
   strcpy(stg, "The value really is 27");
   strcpy(stg, "The value is not 27");
Random
                      indenting
         even in
      psuedo code
                    really isn't
        a good
               idea.
bule
Ok. Thanks for the tip. But when I enter the line
sms.print(stg);
What is going to print?
PaulS
Ok. Thanks for the tip. But when I enter the line ... What is going to print?
Whatever is in stg.
Do not post snippets here and expect much other than smart-assed answers.
bule
Solved.
    char stg[32];
    if (digitalRead(pin) == HIGH){
      strcpy(stg, "Relej je ukljucen.");
    else {
      strcpy(stg, "Relej je iskljucen.");
    Serial.println(stg);
    sms.print(stg);
    sms.endSMS();
