Topic: Servo Control with three buttons. (resolved and working!!!) (Read 6215 times) previous topic - next topic
icecats
Feb 16, 2014, 04:32 pm Last Edit: Feb 16, 2014, 06:12 pm by icecats Reason: 1
Hello Arduino community,
      I am building a project that includes 3 buttons, lets say "buttonA", "buttonB", and "buttonC." My circuit will also include a servo.
I am attempting to write some code that says that "if buttonA is pressed, and if buttonB is pressed, than turn the servo in a specific pattern." However, "if buttonA is pressed, and if buttonC is pressed, than turn the servo in a different pattern.
      Obviously, I don't want to have to press both buttons "A and B" or "A and C" at the same time, simultaneosly. I want to be able to press one button(A) and then press either of the other buttons (B or C) a few seconds later.
How could I go about being able to press button(A) and then press either of the other buttons (B or C) a few seconds later without having to press them simultaneouly?
Here is my code...
Code: [Select]
#include <Servo.h>
Servo myservo; // creating myservo object
int buttonA = 2; // one side of buttonA attached to pin 2 and 10K resistor to ground, while other is on +5V
int buttonB = 3; // one side of buttonB attached to pin 3 and 10K resistor to ground, while other is on +5V
int buttonC = 4;  // one side of buttonC attached to pin 4 and 10K resistor to ground, while other is on +5V
int servoPin = 11;  //servo attached to pin 11
int AState = 0; // set AState
int BState = 0; // set BState
int CState = 0; // set CState
myservo.attach(servoPin);
pinMode(buttonA, INPUT);
pinMode(buttonB, INPUT);
pinMode(buttonC, INPUT);
{AState = digitalRead(buttonA); // read and save to the variable "AState" the actual state of button
{BState = digitalRead(buttonB); // read and save to the variable "BState" the actual state of button
{CState = digitalRead(buttonC); // read and save to the variable "CState" the actual state of button
if (AState == HIGH){
 if (BState == HIGH){
   myservo.write(50);
   myservo.write(111);
myservo.write(90);
 if(CState == HIGH){
   myservo.write(130);
   myservo.write(70);
myservo.write(90);
JimboZA
Quote
Here is my code...
..... but where is your question?
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
PaulS
Make some changes to your code. Put every { on a new line. Put NOTHING else after the {. Use Tools +Auto Format. Then, explain WHY your code looks like this:
Code: [Select]
      if (AState == HIGH)
        if (BState == HIGH)
          myservo.write(50);
          myservo.write(111);
        myservo.write(90);
Why does moving myservo depend on the state of both switches?
icecats
Here is the auto formatted code...
Code: [Select]
#include <Servo.h>
          myservo.write(50);
          myservo.write(111);
        myservo.write(90);
        if(CState == HIGH){
          myservo.write(130);
          myservo.write(70);
        myservo.write(90);
JimboZA
Quote
.... but you still haven't posed a question. So what do you expect members to do?
icecats
Here is the question... I have also edited my original post. Thank you for pointing out this error!
How could I go about being able to press button(A) and then press either of the other buttons (B or C) a few seconds later without having to press them simultaneouly? Currently, with the code that I am running, this is what I have to do.
JimboZA
I think you're on the right track with the state idea, but you have a lot of extra {} pairs in there and I'm not personally sure what effect that's having. See <<<<<< below.
Code: [Select]
{    // this one is needed since it starts lopp() <<<<<<<<
  {     // this and its closing partner are a bit weird <<<<<<<<<<<
      CState = digitalRe
As I said, I'm not sure what effect those have but I'm pretty sure you can lose them.
You might add Serial.print() in strategic places with a message to show where the logic is taking you.
You also need to reset the states to low once the moving is finished.
PaulS
You seem to have a different interpretation of EVERY than the rest of us.
Quote
You should separate detecting that the switches have been pressed from the code that takes action based on which switches are pressed.
You need to note when each switch is pressed. Make your decisions based on timing.
Of course, the real problem seems to be your difficulty in defining exactly what you want to do. "A few seconds later" is not something that you can write a program to deal with. If switch B or switch C is pressed within 5000 milliseconds of switch A being pressed, do..." is something that CAN be translated into a program.
Another thing to consider is that switches can be pressed and released. Do you want to take one action if switch 2 is pressed while switch 1 is pressed? Or, do you want to take action is switch 2 is pressed and released after switch 1 is pressed and released?
JimboZA
@PaulS... what's the effect of those extra {....} pairs?
PaulS
It depends on what is inside of them. By themselves, extra { and } cause no problems.
JimboZA
Thanks... was just wondering they somehow might bundle some lines together. (In a way similar to the {} after an if, where without them, only the first xyz; gets recognised.)
icecats
#11
Feb 16, 2014, 05:12 pm Last Edit: Feb 16, 2014, 05:14 pm by icecats Reason: 1
In order to clear up what I am trying to do...
Just to make it clear what I am trying to do.
In the end I am going to build a coin operated salt and pepper dispenser. When a coin is put in the slot, it will trigger a momentary button (buttonA). After that, I want the customer to have the option to choose between salt and pepper (buttonB and buttonC). The problem is that the current code states that if the coin button (buttonA) is pressed, then the user needs to select their seasoning (buttonB or buttonC) simultaneously in order for the servo to turn. I would like to allow the user to insert a coin, and then take their own sweet time to choose from salt or pepper, similar to modern day pop machines. How could I do this?
Hopefully this clears it up. Thanks for your help.
JimboZA
Make the B and C buttons interrupts maybe?
(I can't help but wonder why we're going to have to pay for salt and pepper when most places have those annoying, but free, little packets  8) )
icecats
How would I implement interrupts? At our Junior High cafeteria, they give us utterly tasteless food, and don't supply any seasoning. I was hoping to make some cash off my peers by selling a dash of salt or pepper for a quarter. I am also building this project just to have some fun.
PaulS
Quote
They can do that. That's why I wanted OP to fix his code, to see where that might be happening.
