Topic: Single Axis Accelerometer Breakout Board - ADXL193 +/-250g (Read 2401 times) previous topic - next topic
Anish142
I need some help with this sensor. I can't seem to find any sample code and also am not an experienced programmer. If anyone has some sample code for this sensor your help would be appreciated.
knut_ny
#1
Feb 16, 2014, 08:00 pm Last Edit: Feb 16, 2014, 08:31 pm by knut_ny Reason: 1
Sensor output goes to an anlog input.
Read the datasheet..: It says ouput is 8mV/g
Code: [Select]
float a;
a = (analogRead(A0)-511) * 4.8875855 ; //millivolt
// 5/1023=0,0048875855 V/step
a = a / 8; // 8mV/g
// all calc can be done in one calculation
Serial.println(a,2); // G-value
// shoud be 0 when not moving
// expect small values when 'shaking'
Ny
Anish142
knut_ny
Read datasheet to find if ST shoud be wired hi og low.
Data out to A0 to match example..
Ny
Anish142
Thanks, I am still getting negative values. Im not sure as to why this is happening
knut_ny
small nes is OK .
Change the numer 511 up/down a litte till you get 0 out when still.
Ny
Anish142
thanks it works now. It moves about 1-2 everytime I shake it. Is this expected? thanks for your help.
knut_ny
OK... you mangage to shake it with 2G..
Tap it on the table.. you'll reach 10G+ (if program reads at the right momemt)
This sensor is best used to measure akseleration in rockets at launch..
..or inn collision tests
Ny
