Topic: NewSoftSerial  & Interrupts (Read 887 times) previous topic - next topic
RandyMan
Reading the form for info but I have a quick question...or two.
I have downloaded the NewSoftSerial 10 which I assume has the support for Mega (Specific pins for RX)
I don't want to keep polling for data for Duemilanove and Mega.
Can I use "attachInterrupt()"?  NewSoftSerial does not use Interrupts?
Thanks
Randy
Coding Badly
Quote
About a month ago the answer would have been "no".  If version 10 has been released recently then the Mega may be supported.  There is a topic somewhere in the forum about Mega support.  Included are instructions to get it working.
Quote
You are certainly welcome to use attachInterrupt but it will have no effect on NewSoftSerial.
Quote
It uses "pin change interrupts".
gardner
If you have a mega, you have four separate hardware UARTs to work with.  Why are you messing with software serial?
NewSoftSerial does use interrupts, although only for receiving so you would have to look out for conflicts there.
RandyMan
My understanding is that attachInterrupt () uses the hardware interrupt.
Perhaps I don't I understand but...
If I use for example attachInterrupt (Interrupt, function, Change) in  void setup() then it will run the function when the pin changes for that interupt. Interrupts are tied to 4 pins.
Instead of polling inthe program for data.
I have not seen any examples of NewSoftSerial using this aproach.
I'm I clear as mud... :)
The goal is to pass data through serial from two maybe thress Duem or Uno to Mega.
I like to use serial TX and RX.
Thanks
Randy
Coding Badly
Quote
It does.
Quote
What approach?  Sending data in an interrupt service routine?  Receiving data in an interrupt service routine?
Quote
The goal is to pass data through serial from two maybe thress Duem or Uno to Mega.  I like to use serial TX and RX.
Seems reasonable to me.
