Topic: Connecting Arduino to USB Joystick (Read 2517 times) previous topic - next topic
huntermc
I am  trying to connect a Thrustmaster T. Flight Stick x, a joystick to the Arduino. The joystick says it is able to connect with ps3 and pcs. I want to take the signals from the joystick and convert the outputs into voltages that will be sent to run solenoids turning them on or off.
Does anyone know how to have the arduino read the joystick signals?
Magician
Have you seen an USB shield for arduino?
zoomkat
Quote
You would probably need to hack the joystick to get the analog output of the pots in the joystick.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
Lucailvec
or use a ftdi converter to take the control of the comunications by the serial port...by the way you must done a serious decoding of the recieved data
AlphaCentari
Bought the shield USB host 2.0. I loaded the libraries (PS3) was one of them. I had the shield plugged onto the Arduino. The serial monitor showed the text display message 'PS3 library working' after I uploaded the example (in the library for the PS3). Moving the thrust master did nothing. Nothing was read from the serial port...Not even gibberish to trouble shoot. The thrust master is PS3 and PC compatible as mentioned before. Can anyone help? I thought the shield would be plug and play?
Thanks very much,
PaulS
Quote
Why would you expect anything to read from the serial port? "Written to" is a completely different story.
Your code is missing!
