Topic: 8MB Ramdisk (external RAM) for Arduino.. (Read 28202 times) previous topic - next topic
pito
Feb 24, 2014, 02:48 pm Last Edit: May 15, 2014, 09:12 pm by pito Reason: 1
Hi, I've been toying with these modules for a while. Not designed as a arduino shield, but maybe an interesting gadget for arduino folk as well. It is an 8Mx8 ramdisk (external ram), based on a single 8MB 70ns psram and Xilinx cpld as the controller.
You need 11 wires to write/read it (8 data and 3 controls), it includes an address auto-in(de)crement feature. Easy to bit-bang.
Quote
. Zero write/read latencies and unlimited endurance
. 11 signals only
. Data bus width 4bit .. 8bit (min 4)
. Up to 12MB/sec Read and 15MB/sec Write throughput
. Supports standard memory bus signaling (PMP, EMB, FSMC, atc.)
. Byte access as well as block access with Address auto-increment or auto-decrement
. Fast Address reset, WR protect
. More modules in parallel with /MS (Module Select)
. For 3V3 platforms (3V3 328p, 1284p, Arduino Zero)
. Ideal for DUE and its External Memory Bus (as an 8bit static memory device)
. Proven as the Ramdisk for swap and filesystem (Fubarino w/ pic32MX@120MHz) at retrobsd.org
. Provided in form of a plug and play component, 2.54mm header pitch for easy breadboarding
:smiley-surprise:
kowalski
That module would be interesting to rewrite the SD driver for. Also with some hardware the interface could be SPI and I guess that 16 MHz would not be a problem. With this size of device a file system is more or less necessary. With a SD driver interface the FAT16 library could be used (though a "format" function will be needed).
Do you have any numbers? What kind of access time? Byte/Block etc.
This would be great for very fast data loggers.
Cheers!
pito
#2
Feb 24, 2014, 04:39 pm Last Edit: Apr 07, 2014, 11:12 am by pito Reason: 1
Quote
You may try to toy with the below sketch (you do not need the module for running it) in order to judge on the numbers. You may see how the "driver" works as well.
Note: the results are for 'raw' access times only (loops exclusive) except the block rd/wr test. You may elaborate the code to fit your actual purposes and to see how it will perform, the numbers might be lower, however..
Note1: A feature with atmega is an read from a port (ie. the input read by "data = PINC") - it is delayed because of the input "synchroniser" (see the ref manual).
Update:
Code: [Select]
// RAMDISK v.1.1 - 8Mbytes - testing with arduino compatible platforms
// RAMDISK module requires 3.3Volt signal levels and power supply!
// Tested with 3.3V atmega1284p @16MHz and bit-banging
// UPDATE: March 31 2014
// Provided as-is, no warranties of any kind
// c 2014 by Pito
RAMDISK MODULE PINS:
DATA0    --- D0                       L  |
DATA1    --- D1                     @ E  |
DATA2    --- D2                       D  |
DATA3    --- D3                          |
Ground   --- GND                         |
DATA4    --- D4     RAMDISK v1.1         |
DATA5    --- D5                          |
DATA6    --- D6                          |
DATA7    --- D7                          |
NMS      --- /MS Module Select (optional)|
NRD      --- /RD Read signal, 85ns min   |
NWR      --- /WR Write signal, 48ns min  |
NDATA    --- /DATA  (A0 with PMP bus)    |
3V3      --- 3.3Volts power              |
LED - indicates rd/wr memory accesses
* NRD - read signal active low, min 85ns, mind the delayed input on atmega mcu
* NWR - write signal active low, min 48ns, max 8us
* NDATA - access to sram data - low, access to controller  - high
* NMS - module select - active low (must be hardwired to low with single module)
#include <DigitalIO.h>
// HW interface to the RAMDISK module (an example only, do assign yours control pins):
DigitalPin<12> NRD(OUTPUT);     //    /RD active LOW
DigitalPin<13> NWR(OUTPUT);     //    /WR active LOW
DigitalPin<14> NDATA(OUTPUT);   //    /Data active LOW
// PORTC is the Data bus D0-D7 (an example only)
typedef union {
unsigned long value;
struct {
unsigned char nib1: 4;  // lowest nibble
unsigned char nib2: 4;
unsigned char nib3: 4;
unsigned char nib4: 4;
unsigned char nib5: 4;
unsigned char nib6: 4;
unsigned char nib7: 4;
unsigned char nib8: 4;  // highest nibble
nybbles ;
typedef union {
struct {
unsigned char byte1: 8;  // lowest bytes
unsigned char byte2: 8;
unsigned char byte3: 8;
unsigned char byte4: 8;  // highest byte
bytes ;
// init the RAMDISK
ramdisk_init ();
Serial.println("START");
// init the RAMDISK
inline void ramdisk_init (void){
delay(1);
NRD = 1;  // Idle
NWR = 1;  // Idle
NDATA = 0;  // Idle = data mode
DDRC = 0x00; // sets DATA PORT as the input
// make a dummy read
NRD = 0;
NRD = 1;
// load the 24bit address into
inline void loadadr (unsigned long addr)
nybbles temp;
temp.value = addr;
NDATA = 1;  // address mode
DDRC = 0xFF; // sets Data output
PORTC = (temp.nib6); // 6th nibble of the address - the highest
NWR = 0; NWR = 1;    // write the nibble into the RAMDISK address counter
PORTC = (temp.nib5); // 5th nibble of the address
NWR = 0; NWR = 1;
PORTC = (temp.nib4); // 4th nibble of the address
NWR = 0; NWR = 1;
PORTC = (temp.nib3); // 3rd nibble of the address
NWR = 0; NWR = 1;
PORTC = (temp.nib2); // 2nd nibble of the address
NWR = 0; NWR = 1;
PORTC = (temp.nib1); // 1st nibble of the address - the lowest
NWR = 0; NWR = 1;
NDATA = 0;  // data mode
DDRC = 0x00; // sets Data input
// random read - reads a byte from the addr
inline unsigned char rd_data(unsigned long addr)
unsigned char d;
loadadr(addr);
NRD = 0; NRD = 0; NRD = 1; d = PINC;  // atmega reads the port ahead!
return d;
// random write - writes a byte at the addr
inline void wr_data(unsigned long addr, unsigned char data)
loadadr(addr);
PORTC = data; NWR = 0; NWR = 1;
// for block read - reads a byte (w/ addr autoincrement)
inline unsigned char rd_databk()
unsigned char d;
NRD = 0; NRD = 0; NRD = 1; d = PINC;  // atmega reads the port ahead !
return d;
// for block write - writes a byte (w/ addr autoincrement)
inline void wr_databk(unsigned char data)
// random read - reads a long from the addr
inline unsigned long rd_datalong(unsigned long addr)
bytes temp;
loadadr(addr);
NRD = 0; NRD = 0; NRD = 1; temp.byte1 = PINC;
NRD = 0; NRD = 0; NRD = 1; temp.byte2 = PINC;
NRD = 0; NRD = 0; NRD = 1; temp.byte3 = PINC;
NRD = 0; NRD = 0; NRD = 1; temp.byte4 = PINC;
return temp.value;
// random write - writes a long at the addr
inline void wr_datalong(unsigned long addr, unsigned long data)
bytes temp;
temp.value = data;
loadadr(addr);
PORTC = temp.byte1; NWR = 0; NWR = 1;
PORTC = temp.byte2; NWR = 0; NWR = 1;
PORTC = temp.byte3; NWR = 0; NWR = 1;
PORTC = temp.byte4; NWR = 0; NWR = 1;
// block write - writes nbytes of data from addr
inline void wr_block(unsigned long addr, unsigned long nbytes, unsigned char *data){
loadadr(addr);
while (nbytes--) wr_databk(*data++);
// block write from external data source - writes nbytes of data from addr
inline void wr_block_ext(unsigned long addr, unsigned long nbytes){
loadadr(addr);
DDRC = 0x00; // sets Data input - feed data from an external source
while (nbytes--){
// example: clocking by /WR from atmega
NWR = 0;  NWR = 1;  // writes data in on rising edge of /WR
// above could be clocked by external /WR clock source as well
// writing speed up to 12MB/sec possible
// block read - reads nbytes from addr to data
inline void rd_block(unsigned long addr, unsigned long nbytes, unsigned char *data){
loadadr(addr);
while (nbytes--) *data++ = rd_databk();
unsigned char di, d;
unsigned long int timestart, elapsed, elapsedloop, errors, N;
volatile unsigned long int i;
#define Nblock 1024
unsigned char data[Nblock];
// fill in the data block
for (i=0; i<Nblock; i++) {
data[i] = 0xCC;
N = 500000; // = 8388608;  //number of bytes to be written/read
// empty loop timing
timestart = millis();
for (i=0; i<N; i++) {
elapsedloop = millis() - timestart;
Serial.println("RAMDISK: RANDOM BYTE ACCESS RD/WR TEST");
wr_data(i,0xAA);
elapsed = millis() - timestart - elapsedloop;
Serial.print("N. of Byte WRITEs: ");
Serial.println(N);
Serial.print(N/elapsed);
Serial.println(" kB/sec");
errors = 0;
di = rd_data(i);
//if (di != 0xAA ) errors++;
Serial.print("N. of Byte READs: ");
Serial.println(N);
//Serial.print("Errors: ");
//Serial.println(errors);
Serial.println("RAMDISK: RANDOM LONG ACCESS RD/WR TEST");
N = 1000000;
// empty loop timing - longs
for (i=0; i<N; i=i+4) {
DDRC = 0xFF; //sets Data output
wr_datalong(i,d);
DDRC = 0x00; //sets Data input
Serial.print("N. of LONG WRITEs: ");
Serial.println(N/4);
d = rd_datalong(i);
Serial.print("N. of LONG READs: ");
Serial.println("RAMDISK: 1024B BLOCK ACCESS RD/WR TEST");
// write a block 1024 bytes large from address 0x55555
timestart = micros();
wr_block(0x55555, Nblock, data);
elapsed = micros() - timestart;
Serial.print("N. of Block Byte WRITEs: ");
Serial.println(Nblock);
Serial.print(Nblock*1000L/elapsed);
errors = 0;
// read a block 1024 bytes large from address 0x55555
rd_block(0x55555, Nblock, data);
//for (i=0; i<Nblock; i++) {
// if (data[i] != 0xCC) errors++;
Serial.print("N. of Block Byte READs: ");
Serial.println("STOP");
while(1);
pito
I've updated the above code including the "driver" - faster read by utilizing the "read ahead" feature of the atmega's reading port.
Here is an another link to the module:
http://www.rlx.sk/sk/storage-boards-memorystorage-boards-memory/2559-ramdisk-8mb-8mx8-8mbytes-with-8bit-parallel-access.html
robtillaart
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
pito
Updated with rd_block() and wr_block() functions and related test results (now the real times inclusive loops). Interesting for someone ho might think about porting fat to it :)
ralphnev
would have liked to try it but no method of shipping to Canada ....
pito
#7
Mar 10, 2014, 04:41 pm Last Edit: Mar 10, 2014, 04:47 pm by pito Reason: 1
Quote
They ship world-wide, afaik - outside EU they charge for an insured letter 4.90Euro VAT exclusive.
pito
#8
Mar 12, 2014, 10:53 am Last Edit: Apr 02, 2014, 05:51 pm by pito Reason: 1
I've added an example for writing the external memory from other sources as the atmega portC output in above examples.
The input could be an ADC, VGA camera module, etc. The ramdisk reads in the data on rising edge of the /WR signal, the /WR signal could be clocked by an external source as well. The below example writes 614kB of data (640x480x2), while clocking with atmega /WR signal (a slow way to do it). You may clock up to 12MB/sec with an external /WR clock (ie the camera's chip rd signal).
Code: [Select]
// RAMDISK MODULE requires 3.3Volt signal levels and power supply!
// Not tested with VGA camera chip
// UPDATE: March 12 2014
// c 2014 by Pito
DATA0    --- D0                       L  |
DATA1    --- D1                     @ E  |
DATA2    --- D2                       D  |
DATA3    --- D3                          |
Ground   --- GND                         |
DATA5    --- D5                          |
DATA6    --- D6                          |
DATA7    --- D7                          |
NWR      --- /WR Write signal, 85ns min  |
* NWR - write signal active low, min 85ns, max 8us
typedef union {
struct {
nybbles ;
// init the RAMDISK
ramdisk_init ();
// init the RAMDISK
delay(1);
NRD = 1;  // Idle
NWR = 1;  // Idle
NRD = 0;
NRD = 1;
nybbles temp;
temp.value = addr;
NDATA = 1;  // adress mode
NWR = 0; NWR = 1;
NWR = 0; NWR = 1;
NWR = 0; NWR = 1;
NWR = 0; NWR = 1;
NWR = 0; NWR = 1;
loadadr(addr);
while (nbytes--){
Serial.println("RAMDISK: N-BLOCK EXT INPUT DATA WR TEST (ATMEGA's /WR CLOCKING)");
// writes a block of N-bytes from address 0x11111
// the data are fed in via ramdisk's data bus, bypassing atmega port
// possible inputs - flash ADC, VGA video chip, etc.
// the /WR works as a clock, it clocks in data on /WR rising edge
// you may clock  /WR with atmega (this example) or via an external source
wr_block_ext(0x11111, 614400L);
Serial.println(614400L);
Serial.print(614400*1000L/elapsed);
while(1);
Code: [Select]
N. of Block Byte WRITEs: 614400
1589 kB/sec
graynomad
I love the idea of using this module but would rather add the components to my own board. Are there any schematics? Or can you tell me the chip being used?
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
pito
#10
Mar 13, 2014, 09:58 am Last Edit: Mar 13, 2014, 10:13 am by pito Reason: 1
Rob, afaik the internals are quite complex and not intended for DIY domain. It is considered a cheap "as-is plug and play component" users with experience may utilize for their designs quickly.
graynomad
Yeah ok, there's a CPLD on there, not much chance of duplicating that.
______
Rob
pito
#12
Mar 30, 2014, 08:17 pm Last Edit: Apr 02, 2014, 05:53 pm by pito Reason: 1
Enclosed plz find the version 0.9 of the 8MB Ramdisk driver for the fat16lib's latest "RamDisk File System".
P.
graynomad
I have no immediate use for this but love the idea. Good work.
______
Rob
pito
#14
Apr 02, 2014, 10:56 am Last Edit: Apr 07, 2014, 11:09 am by pito Reason: 1
When you need to set the Address to 0 (for example when always writing/reading a buffer from ramdisk's zero Address) you may use this shortcut:
Code: [Select]
// reset the Address to 0x000000L
inline void resetadr (){
NRD = 0;  NRD = 1;
Moreover, you can stop writing the Address nibbles after any nibble written  :P, thus  you may write in only "required" number of Address nibbles (1 or 2 or 3 or 4 or 5 or 6).
That allows to speed up with setting the Address, for example you work with 128 blocks 65kB each, so you must not set all 6 nibbles of the 8MB Address, but only top 2:
Code: [Select]
// Load the BLOCK Address into the RAMDISK
// a BLOCK is a 65kB large chunk of ram starting at 0x0000
inline void ldadr_block65k (unsigned char addr)
// the trick with zeroing the 24bit address
NRD = 0;  NRD = 1;
// now load the 2 nibbles of the BLOCK address
DDRA = 0xFF; // sets Data output
PORTA = (addr >> 4); // 6th nibble of the address - the highest
PORTA = (addr); // 5th nibble of the address
NWR = 0; NWR = 1;
// 4th, 3rd, 2nd, 1st nibble are zero - here we start to read/write
DDRA = 0x00; // sets Data input
With a standard external HW SRAM buses on DUE or PIC32 or others, you may simply write the 24bit Address with A0=1 (when for example you use A0 address line) and then you read/write all the Data bytes from A0=0. You must not mess with bit-banging the /RD and /WR signals, or with the setting of a 8bit Data port direction - that is done by the MCU's external memory bus for you (EMB on DUE, PMP on PIC32, FSMC on STM32, etc.). You have to set the timing of the /RD and /WR signals as required, however.
For example - a pseudo-code:
Code: [Select]
//write 24bit Address, A0=1
bus_write(1, 6th_nibble); //the highest
bus_write(1, 5th_nibble);
bus_write(1, 4th_nibble);
bus_write(1, 3rd_nibble);
bus_write(1, 2nd_nibble);
bus_write(1, 1st_nibble);
// write 100000 bytes of Data (w/ auto-increment)
for i=1 to 100000
bus_write(0, data[i]);
next i
or
// read 100000 bytes of Data (w/ auto-increment)
for i=1 to 100000
data[i] = bus_read(0);
next i
When working with blocks (see above):
Code: [Select]
//write 8bit BLOCK Address (up to 128 BLOCKS each BLOCK 65kB large)
dummy = bus_read(1);  //resets Address to zero (0L)
// write 65kBytes of Data (w/ auto-increment)
for i=1 to 65536
next i
or
// read 65kBytes of Data (w/ auto-increment)
for i=1 to 65536
next i
You may connect the 8MB Ramdisk to your DUE via DUE's External Memory Bus easily:
Code: [Select]
With Ax = 1 you write in the 24bit starting "Address"
With Ax = 0 you write/read the Data bytes sequentially from the "Address"
You may use any DUE address line.
