Topic: 8MB Ramdisk (external RAM) for Arduino.. (Read 31276 times) previous topic - next topic
Andreas1984
Hello Pito,
thx for this great work!
I have ordered two of those 8MB Ram devices... This is exactly what I need!  :)
Kind Regards,
Andreas
pito
#16
Apr 05, 2014, 05:01 pm Last Edit: Apr 07, 2014, 11:00 am by pito Reason: 1
With DUE this is an Example how to proceed with 8MB Ramdisk on the DUE's External Memory Bus (just fragments of a code here, needs to be put into your code):
Code: [Select]
// DUE timing settings and Examples for 8MB Ramdisk
// Pito 4/2014
// Examples only, not tested
// Library used: https://github.com/delsauce/ArduinoDueParallel
// DUE at 84MHz (12ns clock)
// No warranties of any kind
// Wiring:
RDisk DUE (EMB signal names)
D0-D7 D0-D7
/WR NWE
/RD NRD
/DATA A0
// Configure parallel bus for 8bits, no CS, A0, and NRD and NWE
Parallel.begin(PARALLEL_BUS_WIDTH_8, 0, 1, 1, 1);
// Configure bus timings.. EXPERIMENTAL (assumption: WR pulse could be shorter than RD pulse)
// Otherwise WR=RD timing
// We do not use any real addressing
Parallel.setAddressSetupTiming(0,0,0,0);
// NWE, NCSWE, NRD, NCSRD  - we do not use NCSs
Parallel.setPulseTiming(5,0,8,0); // or (4,0,7,0) or (6,0,9,0)
// better read datasheet for CycleTiming:
Parallel.setCycleTiming(6,9);  // or (5,8) or (7,10)
// Setting of the starting Address (8MB max)
set_address(uint32 Address){
// below sequence could be shorter when setting only some upper nibbles
MAKE NIBBLES OF Address SOMEHOW - ie. with union as above or with >>
Parallel.write(0x01, nibb6);  // addr[23..20]
Parallel.write(0x01, nibb5);
Parallel.write(0x01, nibb4);
Parallel.write(0x01, nibb3);
Parallel.write(0x01, nibb2);
Parallel.write(0x01, nibb1);  // addr[3..0]
//Parallel.write(0x01, CONTROL);  // 0x00 default, 0x01-autodecrement, 0x02-wrprotect, 0x03-both
// Write 1MB of data=0xAA from Address=0x2FFFFF
set_address(0x2FFFFF);
for(uint32 i=0; i<1MB; i++){
Parallel.write(0x00, 0xAA);
// Read and sum 1MB of data from Address=0x2FFFFF
uint32 sum = 0;
sum = sum + Parallel.read(0x00);
// Fast reset of the Address to 0x000000
reset_address(){
Parallel.read(0x01);
// Example: addressing of a 65kB large Block
// Max 128 Blocks of 65KB each with 8MB Ramdisk, a pity
set_block_address(uint8 BlockNumber){
Parallel.write(0x01, BlockNumber>>4);  // addr[23..20]
Parallel.write(0x01, BlockNumber);  // addr[19..16]
// set the Address at the beginning of the Block N.6
reset_address();  // Address is 0x000000 now
set_block_address(0x06); // set 2 highest nibbles only - the Block number
// Write 65kB of data=0xAA into the block N.6
for(uint32 i=0; i<65kB; i++){
// read and sum 65kB worth of data from the block N.6
uint32 sum = 0;
pito
#17
Apr 24, 2014, 05:50 pm Last Edit: Apr 24, 2014, 05:56 pm by pito Reason: 1
In case you can change the EMB timing parameters on-the-fly with Due (most probable) you can speed up the setting of the Address significantly. The Address is written into the CPLD controller, thus it must not comply with the psram timings.
A 15-20ns long /WR pulse works fine while writing the Address.
Code: [Select]
// below sequence could be shorter when setting up only some of the nibbles
       SET WRITE PULSE TO 15-20ns WIDTH
       SET WRITE PULSE BACK
dlloyd
#18
Apr 24, 2014, 06:35 pm Last Edit: Apr 24, 2014, 06:39 pm by dlloyd Reason: 1
pito, very impressive work you've done!
Your hardware setup looks quite similar to a mini-board I've been reviewing. Its only 1"x2", has 32 MByte SDRAM, 8 Mbit Flash, 600,000-gate FPGA, its completely open source and costs $69. What I like is that the FPGA communicates with the SDRAM as if its standard RAM. They explain how the code can be modified for dual-port, tri-port or quad port memory access. The Flash card could be buffered at such a high level that even the slowest cards shouldn't cause any hiccups.
They have excellent documentation and training manuals published.
I've been "dreaming" about a mini-card like this with a SAM3X on it.
graynomad
#19
Apr 25, 2014, 01:48 am Last Edit: Apr 25, 2014, 01:50 am by Graynomad Reason: 1
Quote
There's a current thread about one being made, I can't find it now though.
EDIT: Found it, http://forum.arduino.cc/index.php?topic=233091.0
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
dlloyd
Thanks Graynomad - yes, nice board ... all the pieces are coming together, but the one that still eludes me (for now) is "time".
graynomad
Join the club, too many projects and too few years :)
______
Rob
pito
#22
May 10, 2014, 10:36 am Last Edit: May 10, 2014, 12:50 pm by pito Reason: 1
Quote
This would be great for very fast data loggers.
Cheers!
These are simplified schematics of a datalogger and a pattern/signal generator talented hackers may try out.. ;)
1. Waveform/pattern generator
i. you write the required pattern into the ramdisk (EN=0) in a standard way
ii.  you read the pattern out of the ramdisk with /RD used as the "clock" (EN=1)
iii.  you may use an external clock generator, or you may generate the clock from the mcu (ie. via PRG_OSC pin)
iv.  the address rolls over to zero after reaching 8MB, so the pattern will repeat itself
v.  mind the 74273 (or an another type) is a "register", not a "latch"
vi.  you may generate 10million patterns per second max.
2. Datalogger
i.  you write the starting address (ADCEN=0) in a standard way
ii.  by "clocking" the /WR signal you may write the ADC data (or "any" data) into the ramdisk (ADCEN=1)
iii. you have to organize the ADC conversion based on the ADC chip you use (CONV rising edge writes ADC to the latch)
iv.  you may read the data in a standard way out of the ramdisk
v.  you may sample 15million samples per second max.
3. Below you may see how to connect two 8MB Ramdisk modules - 8bit and 16bit data bus versions.
PS:  With 16bit data bus version you may enhance the datalogger/pattern/waveform examples to 16bit width easily..
PS1:  The minimal number of data bits used is 4 (D0-D3), ie. you want to generate 4bit patterns only
PS2:  Provided as-is, no warranties of any kind :)
pito
#23
May 11, 2014, 11:26 pm Last Edit: May 22, 2014, 02:41 pm by pito Reason: 1
Andreas,
the wiring - read this topic first: http://forum.arduino.cc/index.php?topic=152644.0
I recommend to connect the ramdisk to the DUE's External Memory Bus (and to use the existing driver, ie.
https://github.com/delsauce/ArduinoDueParallel ). Later on you may access the EMB registers directly to avoid the C++ overheads (in order to speed up the transfers).
See this link for wiring details (you have to find the proper header pins for the specific EMB function).
http://forum.arduino.cc/index.php?topic=152644.msg1146753#msg1146753
Code: [Select]
Ramdisk DUE EMB (Function)
D0-D7 D0-D7
/RD NRD
/WR NWE
/DATA A0
/MS             GND
3.3V 3.3V
GND GND
PS:
D0-D7 does not mean digital pins D0-D7 on DUE, but the data signals D0-D7 on the DUE's EMB bus.
A0 means Address line A0 on the DUE's EMB bus.
NRD, NWE means NRD and NWE on DUE's EMB bus.
See: http://forum.arduino.cc/index.php?topic=220918.msg1661887#msg1661887 - the picture says "EMB signals D0-D7"
PS1:
Do not use the bitbanging example for arduino - that is just an example for people with 3.3V 8bitters.
You may use the code snippets for DUE there in my above posts - mind that code is not a sketch which will compile, it is an example how to use the DUE's EMB library functions (see above topics) with the ramdisk, you have to add all necessary stuff around (based on your actual requirements).
PS2:
Do it step by step. First learn how to use the DUE's EMB with the ramdisk. Write a small sketch where you write/read data into/from the ramdisk, do experiments with the timing settings.. (I can assist you in a separate topic or offline).
PS3: (!!!)
Pls mind the wire length is important while chasing the nanoseconds :)
I've been running 2 modules in parallel on the same solderless breadboard with ~5cm long data lines and 10-15cm long NRD,NWE,A0,A1 (fubarino @120MHz) - see the first picture of this topic.
Use as short as possible wires when connecting a memory device.
PS4:
This is an example code which runs fine on DUE (UPDATED 22.5.2014):
Code: [Select]
// A DUE EMB Example for 8MB Ramdisk v.1.1
// IDE 1.5.6r2
// Wiring: 11cm long jump wires and solderless breadboard
// Provided as-is, no warranties of any kind
// Pito 5/2014
/* Wiring:
RDisk   DUE's header    DUE's EMB signal name
D0-D7   PIN34-PIN41     D0-D7
/WR     PIN45           NWE
/RD     PWM4            NRD
/DATA   PWM9            A0 (A0=0 wr/rd Data, A0=1 wr Addresses)
/MS     GND             GND
3.3V    3.3V
GND     GND
DUE's EMB signal name    MCU I/O line
D0                       PC2
D1                       PC3
D2                       PC4
D3                       PC5
D4                       PC6
D5                       PC7
D6                       PC8
D7                       PC9
NWE                      PC18
NRD                      PA29
A0                       PC21
#include <Parallel.h>
typedef union {
unsigned long value;
struct {
unsigned char nib1: 4;  // lowest nibble
unsigned char nib2: 4;
unsigned char nib3: 4;
unsigned char nib4: 4;
unsigned char nib5: 4;
unsigned char nib6: 4;
unsigned char nib7: 4;
unsigned char nib8: 4;  // highest nibble
} nibbles;
// Setting up the rd/wr starting Address (8388607 max)
int set_address(unsigned long address){
nibbles temp;
temp.value = address;
Parallel.write(1, temp.nib6);  // addr[23..20]
Parallel.write(1, temp.nib5);
Parallel.write(1, temp.nib4);
Parallel.write(1, temp.nib3);
Parallel.write(1, temp.nib2);
Parallel.write(1, temp.nib1);  // addr[3..0]
Parallel.begin(PARALLEL_BUS_WIDTH_8, PARALLEL_CS_1, 1, 1, 1);
Parallel.setAddressSetupTiming(1,1,1,1);
Parallel.setPulseTiming(7,1,7,1);
// CycleTiming = PulseTiming + AddressSetupTiming + 1
Parallel.setCycleTiming(9,9);
// make a dummy read
Parallel.read(0);
// set the Serial
unsigned long i, elapsedw, elapsedr;
Serial.println("START OF THE TEST");
Serial.println("WRITING BYTES TO RAMDISK");
// Write 1 million data = 234 from Address=4444444
elapsedw = millis();
set_address(4444444L);
for(i=0; i<1000000; i++){
Parallel.write(0, 234);
elapsedw = millis() - elapsedw;
Serial.println("READING BYTES FROM RAMDISK");
// Read and sum 1 million of data from Address=4444444
elapsedr = millis();
unsigned long sum = 0;
sum = sum + Parallel.read(0);
elapsedr = millis() - elapsedr;
Serial.print("SUM = ");
Serial.println(sum);
Serial.print("ELAPSED WRITE = ");
Serial.print(elapsedw);
Serial.println(" msec");
Serial.print("ELAPSED READ = ");
Serial.print(elapsedr);
Serial.println("TEST STOP");
while(1);
Code: [Select]
START OF THE TEST
SUM = 234000000
ELAPSED WRITE = 680 msec
ELAPSED READ = 846 msec
TEST STOP
pito
There is an undocumented feature with the Parallel driver - the PARALLEL_CS_NONE parameter sets NRD/NWE timing to 12ns regardless of the timing settings. As a workaround use PARALLEL_CS_1, even we do not use any CS.
Above sketch updated.
Andreas1984
Pito, the updated sketch works perfectly!  :D
Thx so much for your patience and support!  :)  :)  :)
Andreas
pito
#26
May 21, 2014, 11:15 am Last Edit: May 23, 2014, 02:05 pm by pito Reason: 1
Great!
I've been messing a little bit with the Parallel driver, as it seemed to me the driver is slow.
I did following:
Comment out in Parallel.cpp:
Code: [Select]
//__attribute__((optimize("O0"))) void ParallelClass::write(uint32_t offset, uint8_t data)
// *((volatile uint8_t *)(_addr + (offset&0x00FFFFFF))) = data;
//__attribute__((optimize("O0"))) uint8_t ParallelClass::read(uint32_t offset)
// return *((volatile uint8_t *)(_addr + (offset&0x00FFFFFF)));
And replace in Parallel.h :
Code: [Select]
void write(uint32_t offset, uint8_t data) ;
uint8_t read(uint32_t offset);
with:
Code: [Select]
*((volatile uint8_t *)(_addr+offset)) = data;
return *((volatile uint8_t *)(_addr+offset));
Then I get following elapsed time for the above example sketch:
Code: [Select]
START OF THE TEST
SUM = 234000000
ELAPSED WRITE = 321 msec
ELAPSED READ = 262 msec
TEST STOP
There is still an issue as the NWE timing does not react to timing parameter changes properly. The NRD timing works fine, it seems.
pito
#27
May 22, 2014, 02:32 pm Last Edit: May 22, 2014, 07:09 pm by pito Reason: 1
I've added a delay(500) before the "for loop" measurements (to eliminate the potential influence of print) and the result of above example sketch is:
Code: [Select]
START OF THE TEST
SUM = 234000000
ELAPSED WRITE = 226 msec
TEST STOP
That means one write cycle (inclusive "for loop") takes 226ns (or 4.4MBytes/sec).
Moreover, I did a measurement of the actual NWE signal High/Low durations during the 1mil "for loop" vs. the NWE timing parameters settings (the resolution of my LA is 5ns):
Code: [Select]
A, P, C L H L+H MBytes/sec
1, 2, 4 25 205 230 4.35
1, 4, 6 45 180 225 4.44
1, 8,10 95 135 230 4.35
1,16,18 185 40 225 4.44
1,32,34 380 25 405 2.47
where
A - NWE setAddressSetupTiming
P - NWE setPulseTiming
C - NWE setCycleTiming
L[ns] - NWE Low - active low pulse (write pulse)
H[ns] - NWE High - the overhead of the for..loop
How to decipher that results?? Any hint?
PS: the "NWE Low" copies the setPulseTiming well (NWE Low = 12ns * P), but why the L+H is constant or "framed" or "limited"??
pito
We found out that for experimenting with DUE's EMB bus timings it is better to fill in the memory with random numbers. Below find the sketch.
Code: [Select]
// DUE EMB Example for 8MB Ramdisk v.1.1
// 1M BYTES RANDOM WRITE/READ
// Pito 7/2014
/* Wiring:
/WR     PIN45           NWE
/RD     PWM4            NRD
/DATA   PWM9            A0 (A0=0 wr/rd data, A0=1 wr addresses)
/MS     GND             GND
Parallel.write(1, address >> 20);  // addr[23..20]
Parallel.write(1, address >> 16);
Parallel.write(1, address >> 12);
Parallel.write(1, address >> 8);
Parallel.write(1, address >> 4);
Parallel.write(1, address);  // addr[3..0]
Parallel.setPulseTiming(5,1,7,1);
Parallel.setCycleTiming(7,9);
Parallel.read(0);
// set the Serial
unsigned i;
unsigned sumr, sumw, elapsedw, elapsedr;
unsigned char data;
randomSeed(micros());
Serial.println("WRITING 1Mil RANDOM BYTES TO RAMDISK");
// Write 1 million random data
sumw = 0;
set_address(0L);
data = random(256);
Parallel.write(0, data);
sumw = sumw + data;
Serial.println("READING AND SUM 1Mil RANDOM BYTES FROM RAMDISK");
// Read and sum 1million of data from Address=0L
sumr = 0;
set_address(0L);
sumr = sumr + Parallel.read(0);
Serial.print("SUM_W = ");
Serial.println(sumw);
Serial.print("SUM_R = ");
Serial.println(sumr);
Serial.println(" ");
//while(1);
kiiid
I've got a similar one (but 16Mb serial). Might be of interest to someone. http://dimitech.com/products.php - look for DTX2-5055C
