Topic: Does SerialPort library work with the Atmel Studio VisualMicro plug in? (Read 6164 times) previous topic - next topic
millerrt
Post continued....
So what I would like to do is get the TxFile and RxFile names stored into the global character arrays.  I was trying to use the strncpy() function but I keep getting the following errors.
Quote
Compiling 'SerialLoggerWithMega' for 'Arduino Mega 2560 or Mega ADK'
SerialLoggerWithMega.ino:In function 'void setup()'
SerialLoggerWithMega.ino:98: error: cannot convert 'char**' to 'char*' for argument '1' to 'char* strncpy(char*, const char*, size_t)'
SerialLoggerWithMega.ino:In function 'void loop()'
SerialLoggerWithMega.ino:235: error: no matching function for call to 'SdFile::open(char* [13], const uint8_t&)'
SdBaseFile.h:open(SdBaseFile*, uint16_t, uint8_t)
SdBaseFile.h:open(SdBaseFile*, const char*, uint8_t)
SdBaseFile.h:open(const char*, uint8_t)
SdBaseFile.h:open(SdBaseFile*, const uint8_t*, uint8_t)
SerialLoggerWithMega.ino:282: error: no matching function for call to 'SdFile::open(char* [13], const uint8_t&)'
Error compiling
Not having a strong programming foundation, pointers are like black magic to me.  I get that they reference addresses and stuff but how to use them effectively is confusing for me.  I see that when I try to open the file that was created in the Setup function that it isn't done correctly so the program bombs.  I am just not sure on how to get that newly created file from setup to the loop.  Thanks
PaulS
Quote
No problem.
All you need to do is define these correctly:
Code: [Select]
char* TxFileName[13];
char* RxFileName[13];
These are NOT arrays of chars. They are arrays of pointers. They are NOT what you want.
Don't make this ANY more complicated than it needs to be:
Code: [Select]
char TxFileName[13];
char RxFileName[13];
millerrt
I have a tendency to over think things.  Thanks for the help.  The code now complies which is great but I am still having issues opening the file off the SD card after it is created to add the data to it. At first I thought it was because the name of the file was longer than 11 characters and changed the name to be 11 but I am still not able to open the file.  I have closed the previous file before trying to open another one.  I am not sure what makes the .open() fail.  I have tried all I can think of after looking at the implementation and am at a loss. Here is the code as of now:
Code: [Select]
// Serial data logger example.
// Maximum baud rate for a 328 Arduino is 57600.
// Maximum baud rate for a Mega Arduino is 115200.
const uint32_t BAUD_RATE = 115200;
// Maximum time between sync() calls in milliseconds.  If Serial is always
// active, you must provide a way to stop the program and close the file.
const uint32_t MAX_TXSYNC_TIME_MSEC = 1000;
const uint32_t MAX_RXSYNC_TIME_MSEC = 2000;
// Pin number for error blink LED.
// Set ERROR_LED_PIN to -1 for no error LED.
const int8_t ERROR_LED_PIN = 22;
const int8_t CHIP_SELECT = 53;  // Set to 53 cause using with a Mega
// File names to save files on the SD card
char TxFileName[11];
char RxFileName[11];
#include <SPI.h>
#include <SdFat.h>
#include <Sd2Card.h>
#include <SerialPort.h>
#include <Wire.h>
#include "RTClib.h"
#if defined(__AVR_ATmega1280__)\
|| defined(__AVR_ATmega2560__)
// Mega, use 4096 byte RX buffer
SerialPort<0, 2048, 0> NewSerial;
SerialPort<1, 2048, 0> NewSerial1;
SerialPort<2, 2048, 0> NewSerial2;
#else // Mega
// not a Mega, use 1024 RX byte buffer
SerialPort<0, 1024, 0> NewSerial;
#endif
SdFat sd;
SdFile logfile;
RTC_DS1307 RTC;
// Error codes repeat as errno short blinks with a delay between codes.
const uint8_t ERROR_INIT   = 1;  // SD init error
const uint8_t ERROR_OPEN   = 2;  // file open error
const uint8_t ERROR_SERIAL = 3;  // serial error
const uint8_t ERROR_TXWRITE  = 4;  // SD write or sync error
const uint8_t ERROR_RTC    = 5;  // DTC did not begin
const uint8_t ERROR_RXOPEN = 6;  // Rx File open error
const uint8_t ERROR_RXWRITE = 7; // Can't write or sync the RX file
const uint8_t ERROR_LOOP_OPEN = 8; // Cant open file in the loop
void errorBlink(uint8_t errno) {
uint8_t i;
while (ERROR_LED_PIN < 0);
while (1) {
for (i = 0; i < errno; i++) {
digitalWrite(ERROR_LED_PIN, HIGH);
delay(200);
digitalWrite(ERROR_LED_PIN, LOW);
delay(200);
NewSerial.println(errno);
delay(1600);
pinMode(ERROR_LED_PIN, OUTPUT);
pinMode(CHIP_SELECT, OUTPUT);
NewSerial.begin(BAUD_RATE);
NewSerial1.begin(BAUD_RATE);
NewSerial2.begin(BAUD_RATE);
if (!sd.begin(CHIP_SELECT)) {
errorBlink(ERROR_INIT);
// Create new TX file on SD card
char TxFile[] = "GR_TX00.csv";
for (uint8_t i = 0; i <100; i++){
TxFile[5] = i/10 + '0';
TxFile[6] = i%10 + '0';
if (! sd.exists(TxFile)){
// Only open new file if it doesn't exist
if (!logfile.open(TxFile, O_WRITE | O_CREAT | O_AT_END)){
errorBlink(ERROR_OPEN);}
strncpy(TxFileName,TxFile,sizeof(TxFile));
break;  //leave loop
if (logfile.fileSize() == 0) {
// Make sure first cluster is allocated.
logfile.write((uint8_t)0);
logfile.rewind();
logfile.sync();
// Create new RX file on SD card
// Close the TX file first
logfile.close();
char RxFile[] = "GR_RX00.csv";
RxFile[5] = i/10 + '0';
RxFile[6] = i%10 + '0';
if (! sd.exists(RxFile)){
if (!logfile.open(RxFile, O_WRITE | O_CREAT | O_AT_END)){
errorBlink(ERROR_RXOPEN);}
break;  //leave loop
logfile.rewind();
logfile.sync();
// Close the Rx file
logfile.close();
// Connect to the RTC
Wire.begin();
if (!RTC.begin()){
// Save to Tx file
logfile.open(TxFile, O_WRITE);
logfile.println("RTC Failed");
logfile.close();
errorBlink(ERROR_RTC);
// Save to Rx file
logfile.open(RxFile, O_WRITE);
logfile.close();
// Get RTC time at start up
DateTime now;
// Fetch the current time
now = RTC.now();
// Log the time
//logfile.print(now.secondstime()); // seconds since 2000
//logfile.print(",");
logfile.print(now.year(), DEC);
logfile.print("/");
logfile.print(now.month(), DEC);
logfile.print("/");
logfile.print(now.day(), DEC);
logfile.print(" ");
logfile.print(now.hour(), DEC);
logfile.print(":");
logfile.print(now.minute(), DEC);
logfile.print(":");
logfile.print(now.second(), DEC);
logfile.println("");
logfile.close();
// Other File
logfile.print("/");
logfile.print("/");
logfile.print(" ");
logfile.print(":");
logfile.print(":");
logfile.close();
// DEBUGGING: Print out to the serial port to see what is going the time is.
//NewSerial.print(now.year(), DEC);
//NewSerial.print("/");
//NewSerial.print(now.month(), DEC);
//NewSerial.print(now.day(), DEC);
//NewSerial.print(" ");
//NewSerial.print(now.hour(), DEC);
//NewSerial.print(":");
//NewSerial.print(now.minute(), DEC);
//NewSerial.print(now.second(), DEC);
//NewSerial.println("");
// Time of last sync call.
uint32_t txSyncTime = 0;
uint32_t rxSyncTime = 0;
uint8_t buf[32];
DateTime now;
uint8_t n=0;
uint8_t m=0;
// Get the Garmin TX traffic
if (NewSerial1.getRxError()) {
errorBlink(ERROR_SERIAL);
n = NewSerial1.read(buf, sizeof(buf));
if (n > 0) { // If there is something in the buffer
// Need to open the Ts file to write out the data
//logfile.open(TxFileName, O_WRITE);
[b] if (!logfile.open(TxFileName, O_WRITE)){
NewSerial.println(TxFileName);
errorBlink(ERROR_LOOP_OPEN);}[/b]
// Attempt to log the correct time stamp to file
now = RTC.now();
logfile.timestamp(T_WRITE, now.year(), now.month(), now.day(), now.hour(), now.minute(), now.second());
// Commented this out 3/13/14 to try to get the HEX values saved to the file.
//if (logfile.write(buf, n) != n) {
//errorBlink(ERROR_WRITE);
for (int i=0; i<sizeof(buf); i++){
if (buf[i]<0x10) {logfile.print("0");
logfile.print(buf[i],HEX);
logfile.print(" ");
// Get the current micros time
logfile.print(",");
logfile.println(micros());
// Don't sync if active.
return;
if ((millis() - txSyncTime) < MAX_TXSYNC_TIME_MSEC) return;
if (!logfile.sync()) {
//NewSerial.println(TxFileName);
NewSerial.println("can't sync to the Tx file");
errorBlink(ERROR_TXWRITE);
txSyncTime = millis();
logfile.close();
// Log the RX side *****************************************************************
// Get the Garmin RX traffic
if (NewSerial2.getRxError()) {
m = NewSerial2.read(buf, sizeof(buf));
if (m > 0) { // If there is something in the buffer
logfile.open(RxFileName, O_WRITE);
now = RTC.now();
logfile.print(" ");
logfile.print(",");
return;
if ((millis() - rxSyncTime) < MAX_RXSYNC_TIME_MSEC) return;
NewSerial.println("can't sync to the Rx file");
errorBlink(ERROR_RXWRITE);
rxSyncTime = millis();
logfile.close();
The Serial output looks like:
Quote
Opening port
Port open
GR_TX07.csv
8
8
8
8
8
Port closed
I looked at the file name to be sure that was being saved out to the global variable like it should be and it is.  So if I am looking at the SD card and trying to open a specific file name why would it fail?
