Topic: Arduino Uno R3 With Mac OS X 10.9 Mavericks Not Detected/ No Serial USB (Read 7743 times) previous topic - next topic
granosx
Hello, I am posting in the hopes of getting some help with arduino.
I have used arduino for about 1.5 years already on 10.8, and had no problems.
However today I tried to use it on Mavericks (10.9.1) and no matter what I do I cannot get the arduino uno to show on the computer.  The IDE ONLY shows the following:
/dev/tty.Bluetooth-Incoming-Port
/dev/cu.Bluetooth-Incoming-Port
/dev/tty.Bluetooth-Modem
/dev/cu.Bluetooth-Modem
Furthermore, I deleted and tried to reinstall arduino following the sites instructions, and nothing prompts me about it being a network device either, nor is it listed in the network panel.
When I plug in with USB, it does power on (green LED is on, and the light near pin 13 blinks when first plugged in then shuts off shortly after).
I have been trying to fix this for 3 hours now with no luck and have tried everything I found online, including disabling the apple driver and installing the latest FTDI drivers.
All help appreciated as this is extremely important.
Thank you.
daveray
I am trying to confirm a bug that may be related to yours. I'm using Mavericks and FTDI drivers are installed.
My Arduino Nano is getting power from USB and is powered up when booting up the computer. It will not show up in the list of serial devices unless I remove and reconnect the device from the USB port. I think the problem has something to do with the FTDI driver being loaded while the Arduino is still in its boot up sequence, but not sure.
Could you confirm that your device shows up after removing and reconnecting it to USB/power.
I'm hoping there's a way to re-initialize the FTDI driver and recognize the Arduino without having to physically detach and reattach it.
Flying_David
I got the same problem, how did it work out with yours?
what did you do to let it work?
david
cmiyc
Does the Arduino show up in "System Information" under USB?
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
mudem
Same issue for me. The board does not show up under system information either.
OscarEspinosa95
Hi, I have the same problem.
I checked the Disk Utility and (In Spanish it calls Informacion del Sistema, I don't know the name in english)I think is  System Profiler. Mac doesn't recognized the USB Wire.
In the DU, you only can see the FTDI, and thats all.
I hope somebody had a answer.
Oscar Espinosa
Pd: I bought the Arduino UNO, first of all y plug in the USB port of the Mac, the Arduino works by 2 days.
The third day, in the evening it just stop working.
Grumpy_Mike
Just to say that I have no problem using the Arduino with Mavericks, and that includes using the Due, Uno, Galileo, Leonardo and Tiny.
Sorry no insight on how to cure it I just know I have no problem.
Geoffroy_docq
I have the same problem and i have mac os 10.9.3
I tested on mac book air and mac book pro without success.
The Arduino receive power through the usb port but i cannot detect and connect to it.
Did you solved the issue ?
thx
Sinelc
I have the same problem :/
i have mac os 10.9.4
it's very strange because sometimes in my /dev/ ( when i restart, running naked in the street, when i claps three times in my hands )
Arduino is detected... :
/dev/cu.usbserial-xxxxxxxx
/dev/tty.usbserial-xxxxxxxx
but it's very random  :smiley-eek-blue:
so if any person found a solution please, no ... PLEASE!  Say me u_u ( [font=Verdana][/font]i will go crazy ! ) :smiley-sweat:
sorry for my english i'm french :)
huertanix
I'm having the same problem with the Freeduino v1.22. I only get bluetooth devices under Tools > Port. I tried removing the Mavericks drivers as per these instructions:
    cd /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns
    sudo mv AppleUSBFTDI.kext AppleUSBFTDI.disabled
    sudo touch /System/Library/Extensions
    reboot
After rebooting I tried installing the FTDI drivers as over 9000 people on the Internet said to do: http://www.ftdichip.com/Drivers/VCP.htm.
Despite what some Google result said that this would work, this did not work for me.
Official Arduinos work, unfortunately I teach a workshop with Freeduinos and my students are 95% OS X. I hate Oracle. I hate Apple but I can't tell everyone in my class to run Linux.
This is the error I get from the IDE when the board is plugged in:
Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: Bounds out of range: -1,76 [128]
   at processing.app.syntax.JEditTextArea.select(JEditTextArea.java:1178)
   at processing.app.syntax.JEditTextArea$MouseHandler.doDoubleClick(JEditTextArea.java:2353)
   at processing.app.syntax.JEditTextArea$MouseHandler.mousePressed(JEditTextArea.java:2305)
   at java.awt.AWTEventMulticaster.mousePressed(AWTEventMulticaster.java:280)
   at java.awt.Component.processMouseEvent(Component.java:6524)
   at javax.swing.JComponent.processMouseEvent(JComponent.java:3321)
   at java.awt.Component.processEvent(Component.java:6292)
   at java.awt.Container.processEvent(Container.java:2234)
   at java.awt.Component.dispatchEventImpl(Component.java:4883)
   at java.awt.Container.dispatchEventImpl(Container.java:2292)
   at java.awt.Component.dispatchEvent(Component.java:4705)
   at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4898)
   at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4530)
   at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4462)
   at java.awt.Container.dispatchEventImpl(Container.java:2278)
   at java.awt.Window.dispatchEventImpl(Window.java:2739)
   at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:746)
   at java.awt.EventQueue.access$400(EventQueue.java:97)
   at java.awt.EventQueue$3.run(EventQueue.java:697)
   at java.awt.EventQueue$3.run(EventQueue.java:691)
   at java.security.AccessController.doPrivileged(Native Method)
   at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75)
   at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:86)
   at java.awt.EventQueue$4.run(EventQueue.java:719)
   at java.awt.EventQueue$4.run(EventQueue.java:717)
   at java.awt.EventQueue.dispatchEvent(EventQueue.java:716)
   at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
   at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
   at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
   at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
nickull
Hi. I am having the same issue too.  To be more specific, my Mac can see an Arduino UNO however the nano only let's me see the following:
If I plug in the Uno, I see the same but augmented with the USB choices (correct).
I have tried all the common problems solutions (new cable, plugging in again etc) but nothing works.
Did anyone ever see a solution for this?
dbyvr
OK. I *just* got my Uno R3 (authentic Arduino out of box) working. I, like you, spent truckloads of time on this.
I'm running 10.10.2 Yosemite. Java 1.8.0_31-b13 (aka Java 8). Arduino IDE 1.6.
First, ignore all that FTDI driver stuff. The Uno R3 (Arduino branded) does not use this chipset. There are NO drivers required to get this board working. It loads drivers from firmware when you connect it.
Next, if you check your version of Java in Terminal, it won't respond to > Java -version. It will just keep prompting you to install Java unless you have an old version of Java (like Java SE 6) installed. If you want to know if it's installed correctly, a tip-off is that you should see a Java icon in your System Preferences pane.
What mystified me is I bought two Uno R3 boards, and two USB 2.0 A to B cables. I have two Macbook Pros and one Macbook Air in the house and an HP laptop. Nothing worked. Not even recognized by the OSes, let alone the Arduino IDE.
I wanted this to work on the Mac because my son and I are both experimenting with the boards. Finally (as I mentioned above), I broke down and used my HP laptop from work to try and get it working. Nothing.
So I went and bought a different USB cable from a different place.
It worked. It shows up as USB Modem - Not Configured in the Network pane under System Preferences. It shows up as /dev/cu.usbmodemfd131 (Arduino Uno) under the Arduino IDE Tools>>Port menu.
I suspect some USB cables are sh*t (I'm shocked!). I'm not sure if the hardware is just sensitive or whether someone managed to botch a simple USB cable run, but this was my experience. I hope this helps you.
d.
raulm21
I'm also having this same issue.
I purchased my Arduino UNO Rev3 three days ago.
I needed three attempts to get my mac recognising it as a modem port. Later everithing worked fine for two days until I wrote a sketch for my DHT11 and tried to upload it.
My Arduino stopped connecting to my mac. The last sketch I uploaded was working fine.
This morning, after hours and hours trying everything I got it working by shorting between reset&GND + Tx&Rx.
Now, tried to upload a DHT11 sketch again (different) and my Arduino is like a brick again.
I've tried 5 different cables with no success.
DFU mode doesn't works.
What can I do? Thank you
jrickard
Twelve messages.  Fifteen months with the same problem.  NO useful replies.
By all means, check the forums....
Mac users are orphans in Arduino land....
AndDogsHavearDuinos
Hello, I find myself newly in this same situation.
Config:OSX Yosemite 10.10.3, Java 8 Update 45, Arduino IDE 1.6.3.
I updated to all of these as of last week.  I can no longer upload to my Uno R.3 (official) through the IDE.  Getting the error message:
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
Yes, power-on LED is lit and LED next to pin 13 blinks rapidly on power-up or reset.
I can see the board in the USB tree of the System profiler.  I get a port in the IDE, but I'm pretty sure it is not right.  The only non-Bluetooth option is /dev/cu.usbmodem121 (Arduino Uno).  Pretty sure it should be /dev/tty.*** but that is not available in the port menu.
Interesting, I can still upload to my Gen. 1 Galileo board.
Any new insights in to fixing this problem?  Thank you, all.
