Topic: LED DOT MATRIX 64x16 (Read 54888 times) previous topic - next topic
other_format
I'm having a nightmare with these boards. I've got two boards linked together and using the code for the 128x16 matrix posted earlier in this thread. Issue I'm having is that setting inverse to either true or false has the reverse effect for each board. So if I set inverse to 'false' board one will be black text on red background while board two will have red text on black background.
SO my question is - is it possible to switch the boolean statement for inverse after the last column on the first board (columns 0 - 64 inverse true / columns 65 - 128 inverse false) so that both boards will display the same? If so can anyone give me any advice as to which part of the code I should look at. I'm happy to tinker with it, not expecting anyone to do it for me, just need some help getting started.
Many thanks!
BramVibe
#61
Mar 16, 2017, 06:59 am Last Edit: Mar 16, 2017, 07:10 am by BramVibe
Hello,
Im using this panel, 64x16 with promini+hc05 to change the character displayed.
How can i extend it to 128x16?
Thanks
BramVibe
Somehow just figure it out for 128x16.
Here's the video.. thankyou..
https://youtu.be/8kLitvf3KfE
https://youtu.be/z-gLVKAcIGQ
Igor64
Salve a tutti,
Cosa bisogna modificare al codice 128x16 per far funzionare tre display 64x16 collegate in serie.
Chiedo aiuto
kaziewip mi può dare qualche suggerimento?
ingaguirrel
Hi , I made it!
Thanks to this tutorial, it works perfectly: http://www.sunspot.co.uk/Projects/displays/LEDmatrix16x64/LEDmatrix16x64.html
I also made a custom case with acrylic.
Thank you for the help
manshuriyusuf
I've been playing around with this display a bit and I agree that the code supplied has limited functionality.
However I've created an interrupt driven version of the code that constantly scans an 8x32 byte array to address each pixel on the board with ease.  Please use any part of this code you guys like.
Thanks, it's work using Arduino Uno, but can't work using Arduino Mega. Can help me?
nadaanas1988
Hi limel
I want to ask you where I have to change to make this code for 128X16 display
your reply will be highly appreciated.
Thank you
Nada
umeshwalkar
Hello everyone,
i tried Kaziewicz code in the post #18 for 128x16. it works well. many thanks to him.
but can anyone guide me how to drive more LEDs. where in the code i need to make changes to make it work for 192x16 or 256x16... changing #define COLUMN to 24 and increasing buffer[384] size is not working.
also i noticed that while scrolling the texts, it characters looks like shaking. i can noticed the scanning of rows from 0 to 15. how can i avoid it to smooth scrolling.
thanks.
gourish
hello everyone
This code help[ed me lot, i completed almost everything what i needed top do with 128*16 using this code.
i have only one issue,if i try to display this data with such long spaces half the data is not printing at all.
Quote
Global                                     variables                           use                       1589              bytes (77%) of dynamic memory, leaving 459 bytes for local variables. Maximum is 2048 bytes.
plz can anyone help me with this?
Darshit115
Hi EveryOne
Many Many thanks to Kaziewicz code of 128x16. it works perfect for me.
Can anyone help me to drive more LEDs in series. can anyone suggest me or guide me to what change in code that make it work for 192x16 or 256x16.
please help.
Dancopy
Hi Kaziewicz! Taking advantage of the subject, this code: https://pastebin.com/MjPD047h in PASTEBIN it is certainly yours, but you are calling this library: sriftas.h; where to find it?
Another thing: does this code refer to a clock? Does it work on Arduino 1.8.5? Thanks
Fran6
Please how much current does the module draw?
Can it be powered with rechargeable li-ion batteries?
PaulRB
I don't know the current draw, I don't have a module to measure, but I would estimate between 1.3A and 2.6A. Yes, it could be powered by Li-ion batteries. If a Tesla Model X can be powered by Li-ion batteries, then so can this display. The question really is would a step-up voltage converter be needed. The size/capacity of the batteries would depend on how long you need the display to run between charges.
gunaone
#73
Oct 08, 2018, 04:04 pm Last Edit: Dec 11, 2018, 10:22 am by gunaone
i get hard to displaying "string" n "int"..
Code: [Select]
// Author: Phil Kaziewicz 19th July 2014
// 64x32 LED display matrix test code
// based upon original code from canton-electonics
// Arduino 1.0.5 UNO R3
#include <avr/pgmspace.h>
#define COLUMNS 16
#define HEIGHT 32
// Connections to board
const byte latchPin = 8;
const byte clockPin = 12;
const byte data_R1 = 11;
const byte data_R2 = 10;
const byte en_74138 = 2;
const byte la_74138 = 3;
const byte lb_74138 = 4;
const byte lc_74138 = 5;
const byte ld_74138 = 6;
byte ScanRow = 0;
unsigned long counter;
const char message[] = " DISPLAY  Characters  TWO ROWS    ";
  pinMode(en_74138, OUTPUT);
  pinMode(la_74138, OUTPUT);  pinMode(lb_74138, OUTPUT);
  pinMode(lc_74138, OUTPUT);  pinMode(ld_74138, OUTPUT);
  digitalWrite(en_74138, LOW);
  digitalWrite(data_R1, HIGH); digitalWrite(data_R2, HIGH);
  counter = millis();
  sei(); //allow interrupts
// Note that there's no need to do anything with the screen in the main loop.
// Whatever's in "buffer" is constantly scanned out.
  unsigned long clock;
  static int count = 0;
  byte seconds, colour;
  clock = 100000000 - ((millis() - counter) / 1000);
  // display clock
  //drawChar(0,0,(clock/10000000)%10,0,false);
  //drawChar(8,0,(clock/1000000)%10,0,false);
  //drawChar(16,0,(clock/100000)%10,0,false);
  //drawChar(24,0,',',0,false);
  //drawChar(32,0,(clock/10000)%10,0,false);
  //drawChar(40,0,(clock/1000)%10,0,false);
  //drawChar(48,0,(clock/100)%10,0,false);
  //drawChar(56,0,(clock/10)%10,0,false);
  // seconds = (clock/10)%10;
  // colour = (clock/200)&1;
  // draw a rectangle
  // drawRect(72+seconds*5,0,72+seconds*5+3,7,colour);
  // drawRect(72+seconds*5+1,2,72+seconds*5+3,3,!colour);
  // draw a blob
  // setPixel(80,6,colour); setPixel(126,6,colour); setPixel(127,6,colour);
  // setPixel(126,5,colour); setPixel(126,7,colour);
  // display next character of message
  drawChar(120, 1, message[count % (sizeof(message) - 1)], 1, false);
  count = (count + 1);
  // DISPLAY SCROLL Rate set at delay
  // move the text 7 pixels (not 8 because it looks better) to the left
  for (byte i = 0; i < 10; i++) { // character spacing
    delay(50);              // delay between scrolls
    moveLeft(1, 2, 15);      // column spacing,?,?
any idea....
PaulRB
#74
Oct 08, 2018, 09:03 pm Last Edit: Oct 08, 2018, 09:08 pm by PaulRB
Quote
any idea....
No, sorry, you must be much more detailed and specific in your question. I would guess you have some problem converting int to string. There are several ways to achieve this but without context I do not know which way to recommend. Which line of your sketch?
Quote
I get hard to...
Please be careful with your English. I am certain you did not intended it, but you were close to "obscene" language there which could cause offence.
