Topic: Need help programming a photocell/relay shield (Read 17619 times) previous topic - next topic
Riva
I kind of know what it is but I dont know what its used for on this shield.
The DIP switch is S1 in the schematic you supplied and connects to pins 4 & 5 on the UNO. They do not turn on/off any of the circuits they are just for you to use as configuration/control signals as you need. As an example you could alter your code so if a switch is closed it disables the relay or they could be used to adjust the delay time to some preset values like...
00 = 5 seconds delay
01 = 10 seconds
10 = 20 seconds
11 = 40 seconds
Don't PM me for help as I will ignore it.
irishluck
Sorry I havent been back on here in a little bit. I started a new job and has been busy.
Can someone tell me what exactly COM stands for on the diagram for the relay?
UKHeliBob
COM = Common.
It is the connection that is switched between the Normally Open and Normally Closed connections
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
irishluck
Do i absolutely have to have power going to the COM for the relay to trip?
I ask this cause id like to test it but dpnt have another power source to use right now
polymorph
No, you don't need power to the relay contacts in order to test this. Although you'll want something to check that the relay contacts are moving. A meter set to Continuity or Ohms on COM and NO will show low resistance when the relay is activated. Just don't have anything else connected to COM, NC, or NO.
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - tinyurl.com/q7uqnvn
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
irishluck
Alright ill do that tonight. Tried to test yestersay with no meter. Figured uou could hear the relay switch but maybe its just a quite one.
irishluck
So i tried this and the relay isnt working or something.
Im getting power to my shield but the relay isnt switching when I cover up the photocell or let the light hit it.
polymorph
Can you put your meter on the output pin on the Arduino?
UKHeliBob
Or change the output to pin 13 so that you can see if the output is working.
Riva
#24
Mar 28, 2014, 09:08 am Last Edit: Mar 28, 2014, 09:15 am by Riva Reason: 1
This simple sketch should toggle the relay on/off every 2 seconds assuming it is relay 1 and the shield matches the schematic you posted. It will also toggle pin 13 (inbuilt LED) at the same time.
Code: [Select]
#define relayPin 2
#define ledPin 13
void setup(){
 pinMode(relayPin,OUTPUT);
 pinMode(ledPin,OUTPUT);
void loop(){
 digitalWrite(relayPin,HIGH);
 digitalWrite(ledPin,HIGH);
 delay(2000);
 digitalWrite(relayPin,LOW);
 digitalWrite(ledPin,LOW);
 delay(2000);
EDIT:
To find out if the LDR is working as expected and get an idea what the threshold value should be try the below sketch that prints out the LDR reading about twice per second.
Code: [Select]
#define ldrPin A0
void setup(){
void loop(){
  Serial.print("A0 = ");
  Serial.println(analogRead(ldrPin));
irishluck
#25
Mar 29, 2014, 07:16 pm Last Edit: Mar 29, 2014, 07:30 pm by irishluck Reason: 1
Ya the first sketch isnt working. Everything has power to it. The LED on the arduino comes on but no lights on the shield come on.
When I cover up the photocell, nothing happens. Used the ohm meter on the relay and nothing happens. But the board has the 12v going to it and that's all I can read.
This is whats on arduino now:
Code: [Select]
/*Program for Photocell/ Relay configuration*/
#define ldrPin A0                 // Pin the light dependent resistor is connected to
#define relayPin 2                // Pin relay is connected to
#define ledPin 13                 // Pin LED is connected to
#define triggerLevel 512          // Levels below this threshold will trigger relay
#define relayDelay 20UL           // Relay delay time in seconds
unsigned long relayOffTime = 0;   // Time to turn off relay
void setup(){
 //Serial.begin(115200);
 digitalWrite(ledPin,LOW);       // Turn relay off
 digitalWrite(ledPin,LOW);       // Turn LED off
void loop(){
 if (analogRead(ldrPin) < triggerLevel){
   if (relayOffTime == 0) {      // Relay off time zero so relay is off and we need to turn it on
     digitalWrite(ledPin,HIGH);  // Turn relay on
     digitalWrite(ledPin,HIGH);  // Turn LED on
     relayOffTime = (relayDelay * 1000UL) + millis();  // Set off time
     //Serial.println("Relay On");
 if (relayOffTime != 0) {        // Relay off time not zero so relay is on and we need to check if it's time to turn it off
   if (millis() > relayOffTime){ // Time expired?
     relayOffTime = 0;           // Clear off time
     //Serial.println("Relay Off");
Also I uploaded that LED code that you mentioned in ya last post. That one did work. the LED on the shield is blinking every 2 seconds. But the main code has no LED's come on.
And I tried uploading the second part of that code you mentioned that will print something? Yea it uploaded but dont know what to do after that.
UKHeliBob
Try
Code: [Select]
at the start of loop()
What value do you get and does it vary when you cover the ldr ?
You will need to uncomment the Serial.begin() in setup and make sure that the baud rate matches that of the serial monitor.
Riva
#27
Mar 30, 2014, 12:12 pm Last Edit: Mar 30, 2014, 12:14 pm by Riva Reason: 1
But was the relay also clicking on and off?
You need to open the serial monitor window (see below image) and you should get loads of numbers rolling by that should change by a lot when you cover the LDR. If they are not changing by much then try changing A0 to A1 in the sketch and upload again.
Can you upload a picture of the shield your using and we can see what components and where they are.
irishluck
#28
Mar 31, 2014, 06:37 am Last Edit: Mar 31, 2014, 06:39 am by irishluck Reason: 1
okay i got that window opened.
its showing A0 = and then numbers.
WIth the light, its showing from 880 to 910 give or take.
when I cover the sensor its 1017-1018
and im not sure what baud is but in the lower right hang corner it shows 9600 baud
Riva
Okay, it looks like the LDR is working but the range between light & covered is not great and it's logic is opposite to what the code was expecting.
I have altered the last program you posted to suit the info you supplied and after uploading it you should open the Serial monitor again. When you cover the LDR a 'Relay On' message should print and about 20 seconds later a 'Relay Off' will be printed. All we need to do now is figure out why the relay does not appear to be working.
Code: [Select]
#define triggerLevel 950          // Levels above this threshold will trigger relay
void setup(){
  digitalWrite(relayPin,LOW);       // Turn relay off
void loop(){
  if (analogRead(ldrPin) > triggerLevel){
      digitalWrite(relayPin,HIGH);  // Turn relay on
