Loading...
Pages: [1]   Go Down
Author Topic: Dim LED Matrix  (Read 372 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi. Im using a 8x8 matrix with the Arduino RowColumnScanning example sketch (with slight modification). Its working "fine," but the LED's are MUCH dimmer than they are when they are manually set. Anybody know what's causing this?
Code:
const int col[8] = {
  [glow]2,3,4,5,6,7,8,9[/glow] };
const int row[8] = {
  [glow]10,11,12,13,16,17,18,19[/glow]  };
int pixels[8][8];
int x = 5;
int y = 5;
  for (int thisPin = 0; thisPin < 8; thisPin++) {
    pinMode(col[thisPin], OUTPUT);
    pinMode(row[thisPin], OUTPUT);
    digitalWrite(col[thisPin], HIGH);
  for (int x = 0; x < 8; x++) {
    for (int y = 0; y < 8; y++) {
      pixels[x][y] = HIGH;
  readSensors();
  refreshScreen();
void readSensors() {
  x = map(analogRead(A0), 0, 1023, 0, 7);
  y =7- map(analogRead(A1), 0, 1023, 0, 7);
  pixels[x][y] = LOW;
void refreshScreen() {
  for (int thisRow = 0; thisRow < 8; thisRow++) {
    digitalWrite(row[thisRow], HIGH);
    for (int thisCol = 0; thisCol < 8; thisCol++) {
      int thisPixel = pixels[thisRow][thisCol];
      digitalWrite(col[thisCol], thisPixel);
      if (thisPixel == LOW) {
        digitalWrite(col[thisCol], HIGH);
    digitalWrite(row[thisRow], LOW);
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
You forgot to delay after switching the LEDs so you're switching them off again really fast.  Try something like 1ms delay in first instance.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks for the reply but Im not sure what you mean by first instance
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
You want the lights to stay on for a some amount of time before you shut them back off again.  Your eyes are much (much) slower than the arduino.  You'll be surprised what a small delay like 1ms will do.
Before you turn the ROW off, delay for some amount of time.  Play with this delay to strike a balance between brightness and responsiveness.
Logged
www.cmiyc.com - A guide to being an Enginerd
Pages: [1]   Go Up
Print
Jump to:
