Topic: TCS3200 with Arduino Uno (Read 15233 times) previous topic - next topic
marco_c
Karma points always welcome :)
Quote
Do I need to connect the outer inputs to the digital pins instead of connecting to 5V?
I don't know what this means. What are the 'outer inputs'?
Quote
Do you think I will be able to have the exact color temperature of a light?
No idea on this one. My use of the sensor is for detecting color, not color temperature. The sensors work by reading the level of reflected light rather than a light source directly. This may not be compatible with reading a color emitted from a colored source. However, assuming that you can read such a source, then there should be formulas that allow you to convert from one to the other. Color space and its attributes is an interesting topic but I am not at all an expert.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
Arduino++ blog https://arduinoplusplus.wordpress.com
carolx
#16
Jul 27, 2014, 03:57 am Last Edit: Jul 27, 2014, 07:03 am by carolx Reason: 1
Hello,
I am a web programmer trying to learn a bit of Arduino.
I installed marco_c 's library (thank you!) to use with a TCS230 sensor. The vendor said it's TCS3200, but it looks like this, so I'm guessing it's the TCS230.
I used the Calibration example and it worked, but rgb values on serial monitor translate to colors much darker than the objects sensed. I tried different libraries with the same problem, colors are too dark. For example, a green color that should be something around R=172 G=204 B=60  is being recognized as R=160 G=154 B=63.
My ultimate goal is to detect skin color, so some level of accuracy would be important.
Could this be caused by some problem with my settings or could it be sensor malfunction?
I changed pin definitions in the Calibration example to these:
Code: [Select]
#define  S0 13
#define  S1  12
#define  S2  11
#define  S3  10
And I'm calling the class like this:
Code: [Select]
MD_TCS230 CS(S2, S3, S0, S1);
OUT is set to D5
OE is set to GND
Can anyone help me?
I have little to no knowledge on hardware/electronics, but I may try to check the sensor if you have some tips.
Thank you in advance!
marco_c
When you are using the sensor, are you shielding it from externally reflected light? If you are using the sensor as-is in the picture you linked to, you will get different results depending on the light level and other objects in the room.
If you see in my documentation, I built a black cardboard shielding around the LEDs and the sensor. Then when I want to sense, I lock out all the external light from the sensor by putting the shroud in contact with the material to be identified. this stops the external light from influencing the reading and I get the same every time.
I would also say that the colours on the screen will look different from colours in real life because they are produced differently.
carolx
Hi, thank you for such a quick response.
Well, I improvised a shield using thin cardboard, but it is not black and it still lets some external light pass through. For some colors the results are a lot different... A pale skin is read as dark brown.
I'll try to make a better shielding and post the results.
carolx
#19
Jul 27, 2014, 06:59 am Last Edit: Jul 27, 2014, 07:05 am by carolx Reason: 1
Well, I've built a pretty decent shield around the sensor in black cardboard, and the results changed minimally. On human skin, results are the worst, I guess skin has bad reflectance (I found some studies on the subject, like this one).
I put the colors generated from the rgb values on an image to illustrate what's happening (image attached)
jazzlee37
Dear marco_c sir, I'm also trying the TCS3200 color sensor to recognize the color of paper which was printed by ink printer. I used your library to calibrate and test it. I also made a quick shield to prevent the external light by your recommandation. I tried two kind paper. One is normal paper for copy machine, the other is for photo printing. Below is my color sample which I assigned the specific windows RGB number to each color. But the result is a little bit far from windows RGB number. My question is if the material of paper couldn't be changed. how should I change the setting to let the result from sensor to match the color sample I printed?
Arduino UNO + Tcs3200 color sensor
marco_c
I notice that your sensor shroud is made from the same white plastic material as the rest of the sensor holder. Have you tried to make the sensor shroud black. The surrounding ambient will influence what the sensor reads so if you have a color (ie, anything with RGB values greater than 0) you will find that the shroud will contribute to the color reading from the sensor. Black is RGB (0,0,0), so the contribution will be minimal.
jazzlee37
Thanks for your information. I will try and revert back the result to you soon.
stellanhaglund
is there any way to save the calibration so that it doesn't need to be done every time?
marco_c
The sensor needs to be calibrated for the situation/environment in which you are using it. Once this is done, you can either build the calibration parameters into your code or save them to EEPROM (you need to write this code).
If you change the environment around the sensor (background, shroud, voltage, etc) then you should recalibrate.
stellanhaglund
Thanks!
Building the calibration parameters into the code seems like the best option for me.
How would I go about to retrieve them from the calibration example?
marco_c
You can print them out using Serial.print
Also look at the colour recognition example as that one produces a header file to include with the code, printed to the serial monitor. That may be quicker for you.
stellanhaglund
That was really nice I will try it out! thank you!!
