Topic: works: MIDI-IN: code + schematics (Read 115194 times) previous topic - next topic
Iteo
Thank you for your help! I guess if that doesn't work, i might just have to get a professional interface.
tep
What's your interface? Are you sure that you plug it correctly?
(out interface>in keyboard, out keyboard>in interface,
check MIDI thru if it exist on it.)
Iteo
#107
Oct 28, 2009, 07:43 pm Last Edit: Oct 28, 2009, 07:49 pm by Iteo Reason: 1
Midi out port from keyboard to midi in schematic which connects to RX which connects to S2MIDI, which forwards it as a midi out. It also has options for parity, data bits, and stop bits. Parity is set to None. Data Bits is set to 8. Stop Bits is set to 1.
Oh I noticed that the Com port relating to arduino is set in device manager to have a 9600 Baud rate. Should I change this?
tep
I meant without using the Arduino but your interface. (because as I explained above you had a baudrate problem in the software)
Iteo
#109
Oct 28, 2009, 07:55 pm Last Edit: Oct 28, 2009, 10:47 pm by Iteo Reason: 1
oh well i received data from the interface that i purchased, but it reversed the note on and note off commands, so a note would play until I played the next note
tep
How did you reverse that? I'm sorry but you're not very clear...
...and we're off topic. You should perhaps look at the bar...
Iteo
When I plugged in the midi interface that I bought it was already dysfunctional. I would play a note on the keyboard, and the computer would play a note only after I released a key. When I checked the midi commends that were being received by the purchased interface, it was giving a note off command when I pressed a key. I was never able to fix that. Well it doesn't seem like there is anything to try other then play with the baud rate. But thank you very much for all of you help. I appreciate it.
tep
I think you should look at the settings of your keyboard instead of the interface. The keyboard sends commands, the interface is just a translator, not an interpreter.
Starfire
So I got this working and now modified the code to play a sound of the arduino, but I only get a quick beep and that's it.
If I hold a key down on my controller I don't get a continuos sound.  I've   simply changed the code to have a playsound routine that is played when a 'note on' command arrives.  I assume midi doesn't keep sending a 'note on' command so it only makes it though that part of the if statement once, no matter how long I hold down the key.
I've tried a while loop with a statement to keep playing unless a 'note off' (128) is received with a serial.read inside the loop but then it never kick out off it
Suggestions? or am I missing something stupid because it was late at night?
tep
Starfire
#115
Nov 19, 2009, 01:15 am Last Edit: Nov 19, 2009, 01:18 am by Starfire Reason: 1
This is what I have right now, I know it's ridiculously simple, just trying to get out a square wave.
It's hacked out of some other code I have.
With this code it'll sound one note and then just stick on it
Code: [Select]
//variables setup
byte incomingByte;
byte note;
byte velocity;
int statusLed = 13;   // select the pin for the LED
int action=2; //0 =note off ; 1=note on ; 2= nada
//setup: declaring iputs and outputs and begin serial
 pinMode(statusLed,OUTPUT);   // declare the LED's pin as output
 //start serial with midi baudrate 31250 or 38400 for debugging
 Serial.begin(31250);
 digitalWrite(statusLed,HIGH);
//loop: wait for serial data, and interpret the message
void loop () {
 if (Serial.available() > 0) {
   // read the incoming byte:
   incomingByte = Serial.read();
   // wait for as status-byte, channel 1, note on or off
   if (incomingByte== 144){ // note on message starting starting
     action=1;
   else if (incomingByte== 128){ // note off message starting
     action=0;
   else if ( (action==0)&&(note==0) ){ // if we received a "note off", we wait for which note (databyte)
     note=incomingByte;
     note=0;
     velocity=0;
     action=2;
   else if ( (action==1)&&(note==0) ){ // if we received a "note on", we wait for the note (databyte)
     note=incomingByte;
   else if ( (action==1)&&(note!=0) ){ // ...and then the velocity
     velocity=incomingByte;
     while (incomingByte!=128)
       freqout(note);
     note=0;
     //velocity=0;
     action=0;
   else{
     //nada
void freqout(int freq)
 int hperiod;
 hperiod = (500000 / freq);
 analogWrite(12, (255));
 delayMicroseconds(hperiod);
 digitalWrite(12,LOW);
 delayMicroseconds(hperiod - 1);
tep
Code: [Select]
     note=incomingByte;
Here, you do not read the new incoming byte, you have to put
somewhere again to have to new incoming byte in incomingByte. Do you get it ?
Idem for the velocity.
I think you should rater have a
Code: [Select]
status = Serial.read();
command = Serial.read();
value = Serial.read();
after the Serial.available(), it would be clearer ;)
Tell me if I'm not clear enough!
Starfire
I think I understand.  separating each byte into a different variable?  Does MIDI commands always come in 3 byte chunks?  That would make it easer to break up the commands then having to use the if statement.
tep
Yes, most MIDI commands are in 3 bytes.
To be sure, just in case, read the status byte to know if it is in 3 bytes by type.
I suggest you to look here to better understand how all the protocol works and the possibilities: http://www.blitter.com/~russtopia/MIDI/~jglatt/tech/midispec.htm  ;)
Starfire
I can get it to play a note, but I can't get it to hold a note when I hold a key down.  I only get a quick note when I first press and then again when I release the key.
