Loading...
Pages: 1 ... 7 8 [9] 10 11   Go Down
Author Topic: works: MIDI-IN: code + schematics  (Read 17626 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Well I got it to work using this code.
Code:
byte incomingByte;
byte note;
byte velocity;
byte check;
int statusLed = 13;
  //start serial with midi baudrate 31250 or 38400 for debugging
  Serial.begin(31250);
  digitalWrite(statusLed, HIGH);
void loop ()
  if (Serial.available() > 0)
    incomingByte = Serial.read();
    delayMicroseconds(400);
    if (incomingByte== 144)
      note = Serial.read();
      velocity = Serial.read();
      while (check!= 128 )
        check = Serial.read();
        freqout(note);
    check=0;
void freqout(int freq)
  int hperiod;
  hperiod = (500000 / (freq*2));
  analogWrite(12, 255);
  delayMicroseconds(hperiod);
  digitalWrite(12, LOW);
  delayMicroseconds(hperiod-1);
But it only works if I send midi from live on my computer.  If i try to use my keyboard controller it will triger a note and the just hold it on forever *shrug*
Also I had to use the micro second delays to read the serial info, but now if I have 2 note trigger right next to the other it will miss the second one, I assume due to the delay.
« Last Edit: November 20, 2009, 08:45:00 am by Starfire » Logged
France
Offline Offline
Sr. Member
View Profile
If you have and LCD, this could be a way to know what's exactly happening. Some keyboard are strange sometimes.
But note that often keyboards send a note on with velocity instead on note off.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Yeah that's what I'm thinking is going on.  I wish I could get rid of those delays but when I do it quits working.
Logged
France
Offline Offline
Sr. Member
View Profile
Yes, it should be possible, I didn't use some in my controller.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
I just can't get it to work without the delays, is it just blowing by the data in the serial stream with no delays?
I rigged up a LCD and when there is no delays both the note and velocity are read as 255 all the time, no idea!
« Last Edit: November 21, 2009, 01:16:01 am by Starfire » Logged
France
Offline Offline
Sr. Member
View Profile
You perhaps modified it now, but that is a bit strange...
Code:
        freqout(note);
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hey guys,
I've managed to get a small instrument working using this code, but I've also encountered the same problem as Captain Credible (reply #41 on page 3), in that through some MIDI interfaces I can't play more than one note.
If I connect the instrument directly to my MIDI keyboard, I can play polyphonically, but if I play through my keyboard into MIDI-OX and out through a separate MIDI interface (a MOTU MIDI Express XT) I can only play monophonically.
Does anyone have an idea as to why this might be happening?
At first I thought it was because of the note-off differences, between actually specifying a note-off message (128) and a note-on with velocity = 0, but as far as I can tell they both do the note-on, vel=0 thing.
I've been racking my brain all day over this, but I'm truly stumped. Any help would be very gratefully received.
MIDI portion of code below:
Code:
 if (Serial.available() > 0) {
    blink();
    if (incomingByte == 144) {
      action = 1;
    }else if (incomingByte == 128) {
      action = 0;
    }else if ((action == 0) && (note == 0)) {
      note = incomingByte;
      playNote(note, 0);
      note = 0;
      velocity = 0;
      action = 2;
    }else if ((action == 1) && (note == 0)) {
    }else if ((action == 1) && (note != 0)) {
      velocity = incomingByte;
      playNote(note, velocity);
      note = 0;
      velocity = 0;
      action = 0;
    }else{
Logged
0
Offline Offline
Sr. Member
I'm 15. I like making things. I like breaking things better.
View Profile
Hi All.
I am new to the arduino, but i am fairly handy with electronics. i built my setup according to the schematic, except with a 4 channel opto from sparkfun which i had lying around. I connected everything to the correct corresponding pins, and now all that happens when everything is connected is a stream of serial gibberish that doesnt change when i do something on the piano. Any ideas?
Thank you!
Logged
Alice asked the Chesire Cat, who was sitting in a tree, "What road do I take?"
The cat asked, "Where do you want to go?"
"I don't know," Alice answered.
"Then," said the cat," it really doesn't matter, does it?"
-Lewis Carrol
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Hi everyone,
Ive been trying to get this to work for a while,but no luck.  It seems that the arduino is not recieving any data through RX.   Like others, many posts back,  I get a LED to flicker when connected to +5v and pin 5 of the optoisolator( when the RX is not connected).  I measure about 5.2 v on the pin and a 10th of a volt difference corresponding to keystrokes.
I get nothing  coming in on the serial monitor and even the simplest, one led sketches dont work.  I am using a microkorg but have also tried a sci prohet 600.  I tried changing the baud. I checked for loose connections, cold soldered joint, and my diecimila is fine other wise.
Any suggestions?    It seems a few others had this problem but there were no real solutions posted.  Id really appreciate any  help.  Thanks
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
ok, I got it to work briefly but then I unhooked the RX input and when i put it back it no longer works.  I used this:
Code:
//variables setup
byte incomingByte;
int statusLed = 13;   // select the pin for the LED
//setup: declaring iputs and outputs and begin serial
  pinMode(statusLed,OUTPUT);   // declare the LED's pin as output
  Serial.begin(31250);        //start serial with midi baudrate 31250 or 38400 for debugging
  digitalWrite(statusLed,LOW);
void loop () {
    // wait for as status-byte, channel 1, note on or off
    if (incomingByte==144){ // 144 is note on ch1
      delay(20);
      digitalWrite(statusLed, LOW);
      delay(1);
This is how I got it to work ... uploaded this sketch (for like the 20th time)  and it didnt work...no surprise.
then I took the lead from pin 5 of the opto and directly touch pin 2 on the atmega( the rx pin)  then I stuck a 1k resistor between therx and tx sockets, removed it  and then put the lead from pin 5 of the opto back into the rx socket.  Ta-DA  that did it  ...worked fine!   However... After I removed the input lead and put it back it stoped working and now nothing.   I checked continuity.... I think everything is good.  I get a strong beep when the probes are directly on the opto's output and the atmega RX pin 2.  I am pretty sure the hardware is ok. I think somehow my arduino doesnt want to read incoming data, though it loads sketches fine.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Ok,  I got it to work, but not with a 4n28.  I tried 10 of them, with every resistor combo imaginable.  I could get a led flicker (between +5v and pin 5,with the rx disconnected ), but it did nothing for the arduino.  Nothing was being read.  Finally i tried another opto, a cny 17-4.  It has a similar pinout as the 4n28 and I substituted the 100k for a 220k and the 3.3k for 2.2k. works perfectly(for me).
It seems that there were/are a few others who had trouble with this circuit and the  arduino seemingly not being able to read any data.
Perhaps for some, there is a problem with using the 4n28.  i dont know what, though.   It makes no sense to me.    A circuit this simple and that has  been repeatedly verified by so many, shouldnt be this contrary.
Anyone have any ideas?
Logged
France
Offline Offline
Sr. Member
View Profile
As I said a few pages before, for me the solution was not to connect the OptoPin6-100k-GND part, all the rest of the circuit like described on the first post. I built this circuit a few times.
In case of a standalone setup without FTDI the 3,3k resistor has to be 1k.
« Last Edit: February 22, 2010, 05:10:22 pm by tep » Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
All of the  4n28s that I tried,  wouldnt even make a  LED flicker with ANY resistor value between ground and pin 5.
Logged
France
Offline Offline
Sr. Member
View Profile
A resistor between Ground and Pin 5 ? You mean 6 or +5V I think.
Anyway I didn't test the flicker think on my side but it worked...
If you have time, rebuild it with my schema ?
You're using MIDI on the same serial as a FTDI right ? If it is a Mega I  guess it is 1k instead of 3,3k but all the rest the same.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Oops, I meant...a resistor between pin 6 and ground.  Also my  arduino doesnt read midi data when the jack is connected to the arduino.  (midi 4>rx, midi 5> ground)  I thought that using the optoisolator was just a precaution.??
Logged
Pages: 1 ... 7 8 [9] 10 11   Go Up
Print
Jump to:
