Topic: My Arduino documentation to share with others (Read 65957 times) previous topic - next topic
cif40
Well done, Erick.
You are inspired me and help many hobbies, student and child to go into embedded world. Try your best. Thanks
terryking228
One regret: you indicate Imax = 40 mA per pin
Hi, Please feel free to use this page from http://ArduinoInfo.Info in your document. It covers these questions about Arduino Pin limits:
http://arduino-info.wikispaces.com/ArduinoPinCurrent
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
Evekites
About two weeks ago, I've published a new version of my documentation. A total of 641 pages.
Feel free to use it, as long as you don't make any money with it and as long as you keep my name in the document!!!
Version 1.18
Below is a list of the items I've added after version 1.15.
http://bit.ly/eve_arduino
And in case, you don't trust bit.ly, tinyurl etc:
https://www.dropbox.com/s/tfrm06f0tt8fdik/Arduino%20documentation.pdf
1.16 was not published
1.17
• Added 6DOF MPU-6050 3 Axis Gyro With Accelerometer Sensor Module
• Added separate sketches for working with switches: o External pulldown resistor
o External pullup resistor
o Intern pullup resistor
• Added Logic Level Convertor bidirectional
• Added Adafruit SPI/I2C save 5-3.3V level shifter
• Added 74LVC245 5-3.3 level shifter
• Added "3 Arduino Mega 2560 R3"
• Added "11 LoRa: Sodaq One" in the Arduino Boards section
• Added "65 PIR/Motion Sensor HC-SR501"
• Added "72 GPS XM37-1612 (GY-NEO6Mv2?)"
• Added "73 MQ-3 alcohol gas sensor board"
• Added "74 MQ-6 LPG, iso-butane and propane gas sensor"
• Changed stepper motor wire colors used in sample at "82
Adafruit TB6612 Stepper/motor driver"
• Added "82 Adafruit TB6612 Stepper/motor driver"
• Added "83 Stepper motor NEMA-17"
• Added "97 Bluetooth 4.0 BLE CC41A (CC2541) module"
• Added "98 Keyes Bluetooth 4.0 BLE"
• Added "100 GSM/GPRS SIM800L module"
• Adding "160 ESP-module: ESP8266 ESP-01"
• Added "186 Single Channel Gateway on ESP8266"
• Added "195 LoRa: Sodaq One as a TTN node" in The Things
Network Nodes section.
• Rearranged IOT section in three new sections
o TheThingsNetwork
o The Things Network Nodes
o The Things Network Data Handling
1.18
• Added "6 Sparkfun Pro Micro - 5V/16MHz"
• Added "60 RGB and Gesture sensor APDS-9960 "
• Added "107 Arduino Mega Sensor Shield v 2.0"
• Added "136 YuRobot breadboard power regulator"
• Added "162 Module: USB to ESP-01"
• Added "163 Module: USB to ESP-01 flash hack"
• Added "164 Module: USB to ESP-01 flash hack v2"
• Added "165 Module: USB to ESP-01 with flash switch"
• Added "166 Module: ESP-01 5V-3.3V adapter"
• Added "167 Module: Open Smart ESP-01 to DIP"
• Added "168 Module: Open Smart ESP-01 to DIP Hack"
• Replaced Photo from shield with Hope RF board, because
orientation was not correct: "190 LoRa: Shield for HopeRF
board"
• Corrected Breakout pin-numbers in "193 LoRa: RN2483
Enschede Nano breakout board"
• Changed order of the Section about ESP8266. Moved
background chapters in front of description of ESP Modules.
