Topic: Problem with my lis3lv02dq (Read 929 times) previous topic - next topic
trank
Jan 19, 2011, 08:51 pm Last Edit: Jan 19, 2011, 10:35 pm by trank Reason: 1
Hello everybody,
I have a problem with my sensor lis3lv02dq.
I want to do a function that when you press a button, set to 0 the values of the 3-axis sensor to start from a point of reference.
I'm playing with several values in CTRL_REG2, but I can not reset using the boot.
I leave part of the code of my accelerometer
void Sensor_Init(void)
unsigned int xx = 0;
unsigned int yy = 0;
unsigned int zz = 0;
xx= Sensor_RX(WHO_AM_I);
yy= Sensor_RX(CTRL_REG1);
zz= Sensor_RX(CTRL_REG3);
printf(" W: %x 1: %x  2: %x \n", xx, yy, zz);
// war: Sensor_TX(CTRL_REG1, 0x87); // Power on device, enable all axis, and turn off self test
// war: Sensor_TX(CTRL_REG2, 0x45);
//Axel: REG2: 0x65, REG1: 0x47
//Sensor_TX(CTRL_REG2, 0x14);
Sensor_TX(CTRL_REG2, 0x44);
  if ((B1) == 0 && b1_flag == 0)          //if B1 pressed
      draw_array32_to_lcd("Calibrate  ");
      b1_flag = 1;
  if ((B1) != 0 && b1_flag != 0)          //if B1 released
      b1_flag = 0;
robtillaart
Do you have a website or URL that points to the datasheet of the sensor, that would be a great help.
Furthermore posting the whole code helps also, please use the # butto so the code appears between the [ code] and [/code] tags
Rob Tillaart
AWOL
What does that mean?
As well as your code, it would be useful to see your debug print output.
MarkT
You say you are trying to set the values to zero somehow - yet your code seems to simply reboot the chip.
So what exactly are you trying to do and what makes you think its not happening?
trank
#5
Jan 20, 2011, 08:21 am Last Edit: Jan 20, 2011, 08:23 am by trank Reason: 1
My idea is, when you press B1, display counters are in 0 to start measuring from a reference point.
It is a very simple idea, but I can not.
My problem is, when I press B1, donĀ“t get to set 0
