Topic: mjkdz I2C - modify lcd constructor (Read 7956 times) previous topic - next topic
psycho22
Yes, I can make the pixels dissapear.
Paul__B
Yes, I can make the pixels disappear.
Following the procedure bperrybap detailed, so does anything show up on the "guesser" sketch then?
jasit
I just checked mine, and with only power and not the SDA SCL connected i get the top row with just squares, i know you took a picture but it didn't show the full trace between the pins on the arduino and the i2c on the lcd, is it possible those two cables are backwards?  A4 to SDA and A5 to scl
Paul__B
Is it possible those two cables are backwards?  A4 to SDA and A5 to scl
The i2cscanner and "guesser" scripts are finding the I2C address and activating the backlight.
