Topic: J204A LCD - Unusual Symbols Being Displayed (Read 992 times) previous topic - next topic
redz06vette
Greetings to All,
I am having an issue with displaying proper values when writing to an lcd within a loop; I am only able to get "chinese" type symbols out.  I have noticed that there exists a pattern to the unusual symbols; for example, if attempting to display "TTTTT", I get the same symbols.  Any help would be GREATLY appreciated.  I have spent countless hours researching this and trying to correct this issue.  Also, note I am using a Leonardo.  As you will notice, I am very new to this, so bear with me...
Regards
Code: [Select]
/*Based largely on code by  Jim Lindblom
Get pressure and temperature from the BMP085.
Serial.print it out at 9600 baud to serial monitor.
#include <Wire.h>
#define BMP085_ADDRESS 0x77  // I2C address of BMP085
const unsigned char OSS = 0;  // Oversampling Setting
// Calibration values
int ac1;
int ac2;
int ac3;
unsigned int ac4;
unsigned int ac5;
unsigned int ac6;
int b1;
int b2;
int mb;
int mc;
int md;
// b5 is calculated in bmp085GetTemperature(...), this variable is also used in bmp085GetPressure(...)
// so ...Temperature(...) must be called before ...Pressure(...).
long b5;
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int backlight=13;
void setup(){
  pinMode(backlight, OUTPUT);
  analogWrite(backlight, 25);
  // set up the LCD's number of columns and rows:
  lcd.begin(20, 4);
    while(!Serial);
  Wire.begin();
  bmp085Calibration();
  float temperature = (((bmp085GetTemperature(bmp085ReadUT())*9) / 5) +32); //MUST be called first
  float pressure = ((bmp085GetPressure(bmp085ReadUP())) / 3386.38816);
  lcd.print("Temperature: ");
  lcd.print(temperature, 2); //display 2 decimal places
  lcd.println("deg F");
  lcd.print("Pressure: ");
  lcd.print(pressure, 2); //whole number only.
  lcd.println(" in Hg");
  lcd.println();//line break
  delay(1000); //wait a second and get values again.
// Stores all of the bmp085's calibration values into global variables
// Calibration values are required to calculate temp and pressure
// This function should be called at the beginning of the program
void bmp085Calibration()
  ac1 = bmp085ReadInt(0xAA);
  ac2 = bmp085ReadInt(0xAC);
  ac3 = bmp085ReadInt(0xAE);
  ac4 = bmp085ReadInt(0xB0);
  ac5 = bmp085ReadInt(0xB2);
  ac6 = bmp085ReadInt(0xB4);
  b1 = bmp085ReadInt(0xB6);
  b2 = bmp085ReadInt(0xB8);
  mb = bmp085ReadInt(0xBA);
  mc = bmp085ReadInt(0xBC);
  md = bmp085ReadInt(0xBE);
// Calculate temperature in deg C
float bmp085GetTemperature(unsigned int ut){
  long x1, x2;
  x1 = (((long)ut - (long)ac6)*(long)ac5) >> 15;
  x2 = ((long)mc << 11)/(x1 + md);
  b5 = x1 + x2;
  float temp = ((b5 + 8)>>4);
  temp = temp /10;
  return temp;
// Calculate pressure given up
// calibration values must be known
// b5 is also required so bmp085GetTemperature(...) must be called first.
// Value returned will be pressure in units of Pa.
long bmp085GetPressure(unsigned long up){
  long x1, x2, x3, b3, b6, p;
  unsigned long b4, b7;
  b6 = b5 - 4000;
  // Calculate B3
  x1 = (b2 * (b6 * b6)>>12)>>11;
  x2 = (ac2 * b6)>>11;
  x3 = x1 + x2;
  b3 = (((((long)ac1)*4 + x3)<<OSS) + 2)>>2;
  // Calculate B4
  x1 = (ac3 * b6)>>13;
  x2 = (b1 * ((b6 * b6)>>12))>>16;
  x3 = ((x1 + x2) + 2)>>2;
  b4 = (ac4 * (unsigned long)(x3 + 32768))>>15;
  b7 = ((unsigned long)(up - b3) * (50000>>OSS));
  if (b7 < 0x80000000)
    p = (b7<<1)/b4;
    p = (b7/b4)<<1;
  x1 = (p>>8) * (p>>8);
  x1 = (x1 * 3038)>>16;
  x2 = (-7357 * p)>>16;
  p += (x1 + x2 + 3791)>>4;
  long temp = p;
  return temp;
// Read 1 byte from the BMP085 at 'address'
char bmp085Read(unsigned char address)
  unsigned char data;
  Wire.beginTransmission(BMP085_ADDRESS);
  Wire.write(address);
  Wire.endTransmission();
  Wire.requestFrom(BMP085_ADDRESS, 1);
  while(!Wire.available())
  return Wire.read();
// Read 2 bytes from the BMP085
// First byte will be from 'address'
// Second byte will be from 'address'+1
int bmp085ReadInt(unsigned char address)
  unsigned char msb, lsb;
  Wire.requestFrom(BMP085_ADDRESS, 2);
  while(Wire.available()<2)
  msb = Wire.read();
  lsb = Wire.read();
  return (int) msb<<8 | lsb;
// Read the uncompensated temperature value
unsigned int bmp085ReadUT(){
  unsigned int ut;
  // Write 0x2E into Register 0xF4
  // This requests a temperature reading
  Wire.write(0xF4);
  Wire.write(0x2E);
  // Wait at least 4.5ms
  delay(5);
  // Read two bytes from registers 0xF6 and 0xF7
  ut = bmp085ReadInt(0xF6);
  return ut;
// Read the uncompensated pressure value
unsigned long bmp085ReadUP(){
  unsigned char msb, lsb, xlsb;
  unsigned long up = 0;
  // Write 0x34+(OSS<<6) into register 0xF4
  // Request a pressure reading w/ oversampling setting
  Wire.write(0xF4);
  Wire.write(0x34 + (OSS<<6));
  // Wait for conversion, delay time dependent on OSS
  delay(2 + (3<<OSS));
  // Read register 0xF6 (MSB), 0xF7 (LSB), and 0xF8 (XLSB)
  msb = bmp085Read(0xF6);
  lsb = bmp085Read(0xF7);
  xlsb = bmp085Read(0xF8);
  up = (((unsigned long) msb << 16) | ((unsigned long) lsb << 8) | (unsigned long) xlsb) >> (8-OSS);
  return up;
void writeRegister(int deviceAddress, byte address, byte val) {
  Wire.beginTransmission(deviceAddress); // start transmission to device
  Wire.write(address);       // send register address
  Wire.write(val);         // send value to write
  Wire.endTransmission();     // end transmission
int readRegister(int deviceAddress, byte address){
  int v;
  Wire.write(address); // register to read
  Wire.requestFrom(deviceAddress, 1); // read a byte
  while(!Wire.available()) {
    // waiting
  v = Wire.read();
  return v;
redz06vette
#1
Mar 13, 2014, 02:04 am Last Edit: Mar 13, 2014, 02:11 am by redz06vette Reason: 1
Just to clarify, when code is placed within the setup function, the text diplays on the LCD just fine.  It is only when 'lcp.print' is used within the loop that I get bad data displayed.
Very important to note, data displayed on the serial monitor is absolutely perfect, even with the code residing within the loop function.  Again, I am truly appreciative of any help with this issue!
floresta
Start by getting rid of all of your lcd.println() statements.
Don
redz06vette
Thank you Don for your quick response.  I have tried to remove everything within the loop except for:
Code: [Select]
delay(2000);
At this point, nothing is populating the LCD.  Any ideas??
redz06vette
This also may help with determining the root cause.  I have been using a simple example program and have noticed that I get bizzare characters/symbols on the LCD until I remove the Wire.begin().  At that point, I get clear text. Here is the example that I used:
Code: [Select]
#include <Wire.h>
  lcd.begin(20, 4);
Wire.begin();
lcd.print("HELP");
redz06vette
GOT IT!!!!!!!!!! XD
I moved my LCD pins from '5, 4, 3, 2' to '7, 6, 5, 4' and it works!  I did read somewhere that the Leonardo's SCL and SDA pins are hardwired/tied to pins 2 & 3.  Perhaps this had something to do with it (as I am communicating with a BMP085, barometer/temp sensor).  Please comment as necessary.  I am hoping that moving my pins to these locations will not interfere with projects in the future.  Again, thank you for your help and time!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
