Topic: Clamp current sensor AC 220v household (Read 2126 times) previous topic - next topic
JaJa
Dear Scholars
I'v been searching the boards just to get even more confused regarding a simple way to measure Current in a non intrusive way (Hall Effect) of a 220v cable (can be even the main cable entering the household)
I am looking for a clamp that is suitable for this job, preferably with a nice 5v output to an Arduino pin, and preferably available in Europe.
The emphasis should also be the quickest, simplest sensor, If there is something that can be used "out of the box" it will be nice.
Thank you kindly.
AltairLabs
something like  http://assets.fluke.com/manuals/i30s_i30iseng0000.pdf  works right out of the box, analog 5v = 50 amp.  Other current scales are available to suit your needs, DigiKey can have it on your doorstep in 3 days.
Note the high cost is why most folks here try to "roll their own".
pluggy
#2
Jan 20, 2011, 04:41 pm Last Edit: Jan 20, 2011, 04:42 pm by stephen_t Reason: 1
If its to measure power consumption of the household, the easy / cheap way is to hook some kind of optical sensor to the meter, most meters have have some form of indication of the present power consumption, either a flashing LED or a spinning disk.  A phototransistor or maybe a line follower sensor, measure the time in milliseconds and do some maths to find the watts.....
http://pluggy.is-a-geek.com/index.html
JaJa
Dear AltairLabs, thank you for the comment, the clamp looks perfect but it is way too expensive as you said yourself.
as for the DigiKey - looks great but what about the clamp itself? do i need to get a coil separately ?
pluggy: thank you for the reply and I agree that the idea is cool, but I rather go with a "hall effect" sensor.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
