Loading...
Pages: [1]   Go Down
Author Topic: Program not startin on external power input?  (Read 2445 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hey guys.
Basically, I'm running the Arduino board off of a 12V power supply, receiving MIDI and turning lights on and off.  The midi adapter is connected to RX.  The circuit works perfectly when the Arduino is powered off USB, but nothing happens when it's powered by the 12V adapter.
I thought I read that this was due to RX have a floating value, so I put a 10K resistor between RX and ground - this made no difference.
Thanks,
Drew
Logged
Connecticut
Offline Offline
Edison Member
RTFD (Datasheet in our case)
View Profile
Why does it have to be Serial? Just plug the midi adapter into a digital pin and pull it to ground. Activate the lights when the pin is pulled high. Unless the midi adapter is outputting true serial data at your baud rate, you may have some problems.
Logged
I'm not kidding. If I am asking a question whose answer is found within the concerned product's datasheet, shame on me. If I am answering a similar question, shame on you!
United States (Texas)
Offline Offline
God Member
Arduino socks
View Profile
did you connect the ground from the midi adapter to the ground of the arduino? the signal may be using the ground from usb as a common ground, and when you take away the computer you disconnect the ground.
Logged
Pages: [1]   Go Up
Print
Jump to:
