Loading...
Pages: [1]   Go Down
Author Topic: Can I use the Powerpins to power my Arduino?  (Read 4460 times)
netherlands
Offline Offline
Newbie
Arduino and Linux rock
View Profile
WWW
Hello, everybody
Can I use the VIN and GND powerpins on my Arduino Uno to power my Arduino (with a 6 AA batteryholder)? Otherwise I'll have to buy a 2.1x5.5 mm powerplug and solder this to my batteryholder.
Thanks for any help,
Superpelican  smiley
Logged
superpelican-online.tk
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Yes that will work. Just be sure to measure or careful inspection if no meter for correct polarity before wiring to the Vin and ground pins.
Lefty
Logged
netherlands
Offline Offline
Newbie
View Profile
WWW
So, that means that the Powerpins are connected to the Voltage Regulator, so I won't damage my Arduino?
Logged
Offline Offline
Brattain Member
View Profile
Quote
Yes, the Vin wires to the input of the on-board +5vdc voltage regulator, just like the external power connector does. Vin can be used as an output for voltage if using the external power connector, or as an input for voltage as you want to do. Vin must be around +8vdc or higher, but the closer to 8volts the less heat will be generated by the regulator.
Lefty
Logged
Washington
Online Online
God Member
Firefox & Arduino rocks
View Profile
Actually it works down to 6.8v until the 5v starts dropping.
Logged
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
0
Offline Offline
Newbie
Arduino rocks
View Profile
If you have a power source that delivers 6V or less you could connect that directly to the 5V pin of the arduino via a 1N400x diode. The diode has a voltage drop of .7V and the atmega can be safely driven with up to 5.5V
« Last Edit: January 19, 2011, 03:03:36 pm by pannen » Logged
netherlands
Offline Offline
Newbie
View Profile
WWW
So, @smeezekitty, I can safely power my Arduino with my 6 AA  batteryholder, wich delivers 7.2 V (as I am going to use 1.2 V NiMH rechargeable batteries)?
Thanks for all the help everyone,
Superpelican  smiley
Logged
Offline Offline
Brattain Member
View Profile
Quote
The issue isn't just the drop out voltage rating of the regulator. The arduino has a auto-voltage detector/selector circuit wired as a opamp comparator. The external voltage input has to be high enough to trigger this selector circuit to select external voltage over USB voltage. There is also a series polarity protection diode between the external voltage connector and the input of the regulator, which drops a little voltage.  There is a critical voltage value which if below that value the voltage selector circuit will not switch to external source.
Lefty
« Last Edit: January 21, 2011, 10:42:14 am by retrolefty » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
In a battery powered project I'd always go for a way to feed the arduino directly with regulated 5V. The voltage regulator has a pretty bad efficiency.
A switching regulator is the way to go when you don't want to use your precious battery power to heat your arduino.
[edit]
BTW: A cheap way to get a 5V power source are the USB power packs you can buy to charge your phone/mp3player on the go. They contain a lithium battery, a 5V step up regulator and a charging circuit. You can get them for about 10$
[/edit]
« Last Edit: January 21, 2011, 11:01:46 am by pannen » Logged
netherlands
Offline Offline
Newbie
View Profile
WWW
So I also can power my Arduino with a 9V battery+clip instead of the 6 AA the same way? Without blowing my Arduino of course!
Superpelican  smiley
Logged
Lancashire, UK
Offline Offline
Edison Member
View Profile
WWW
Yes but be aware a 9v battery has a very limited capacity and won't last very long.
Logged
Offline Offline
Brattain Member
View Profile
Quote
And they are the most expensive battery you could use from a mah capacity point of view. They go for around $2.50 each at my local drug stores.
Lefty
Logged
netherlands
Offline Offline
Newbie
View Profile
WWW
Yes, I already heard that when you feed your Arduino with a 9V they don't last long. But it is only until I have a 6 AA holder.
Thanks,
Superpelican  smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
