Loading...
Pages: [1]   Go Down
Author Topic: connecting 100 RGB Led´s  (Read 4532 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi forum
I'm a retard when it comes to interfacing. I'm pretty much on top of things when it comes to coding.
I need to connect 100 RGB LED´s to my arduino.
The good thing is that they shall show same color. What will I need in order to do this? Some power transistor I guess.
I have not ordered the LED´s yet. So common anode/Cathode is not an issue yet.
I'm thinking of powering the whole thing from a 12V switch mode power supply since that is what I already have.
Any recommendations?
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
You just want all 100 to turn on/off together?
Wire them up in series in strings of 5 with a current limit resistor (~150 ohm), from +12 V to the drain of an N-channel mosfet . You maybe be able to get away with 6 in series, depends on the forward voltage drop of the LED. Adjust the current limit R accordingly.
The gate will be connected to an arduino output pin thru a 100 ohm resister, and a 1K resistor to ground if you find it is not turning off satisfactorily.
The source will be connected to ground.
You will have 20 strings of 5+resister wired in parallel.
Choose a logic level MOSFET with low Rds. It will have about 400ma going thru it.
Here is an example but with a 20V source
You could also use a part like ULN2803 if you are not comfortable with discrete transistors.
« Last Edit: January 24, 2011, 02:21:06 am by CrossRoads » Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Pages: [1]   Go Up
Print
Jump to:
