Topic: arduino voyager suggestions (Read 2293 times) previous topic - next topic
macsimski
for the next arduino formfactor, i would suggest to stick to the .1 raster with the connectors. now h have to have two separate connectors to the binary in/out pins, because the connectors on the arduino are not both on a .1 raster.
otherwise is the "Voyager" of course a perfect name for the bluetooth version... :)
"We're all in this together..."
admin
Hello
thanks for the feedback.
the reason they are not aligned is because we made a mistake in the first board that we carried on because of compatibility with the "shield" extensions.
changing it might require quite a bit of extra documentation :) but it's something we should consider for the next batch of 10000 we are making now..
As far as names are concerned I tend to prefer italian names because Arduino was born in italy (the board... also the king but it's another story..) and it's still manufactured in Ivrea.
In a globalised world where everything tends to become the same it's nice not to use an english name for arduino:)
btw NG means Nuova Generazione
massimo
macsimski
of course i was hinting at the Star trek series. i bet they could use some Arduino's in the making of the decors...
nice to know where the connector glitch came from.
admin
nice reference :)
The actual arduino history should be told it's full of nice little stories....
starting from the fact that the name comes from a bar....
massimo
macsimski
Of course you could choose names from the infinite choices of coffee you can get at a bar in Italy:
macciato Latte
espresso
cappuchino
etc..
or whines. as long as its a type of food...
BTW, nice picture from you on the Mediamatic site after the workshop there:
http://www.mediamatic.net/article-12980-en.html
macsimski
And?
what will be the name of the bluetooth arduino?
admin
In the end I think it will be arduino BT ....
We don't have to be creative all the time :)
The next Arduino Board which will be made in 2007 will be called Arduino Diecimila
diecimila = Ten Thousands... so you can figure out why it's called like that :)
massimo
CrashingDutchman
#7
Jan 16, 2007, 02:26 pm Last Edit: Jan 16, 2007, 02:30 pm by jds Reason: 1
Why not: Arduino DaVinci
Bluetooth gives you freedom (no wires anymore), Leonardo Da Vinci (http://en.wikipedia.org/wiki/Leonardo_Da_Vinci), amongst other things, designed one of the first flying machines (http://www.visi.com/~reuteler/leonardo/fly1.jpg) that lead to the airplanes we use nowadays and gives us much freedom too.
