Topic: RF Module interfacing with Arduino leonardo (Read 6602 times) previous topic - next topic
neeraj786
i am interfacing RF(433Mhz) module with Arduino and facing a problem when Tx is not turned On then Rx receiving  garbage Value that are showing on Serial terminal of arduino. how can we avoid these Garbage Value when Tx is not turned ON Help plz..
Nishant_Sood
your Rx is floating get it balanced. check the connections!
"Real Men can Accomplish  Anything"
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
krishnapatil
If all your connections are right and still you get garbage values then , you may have pair these modules with HT12E and HT12D. Because 433 Mhz ASK receiver has very wide bandwidth of 2MHz which will pick up lot of noise .
