Loading...
Pages: [1]   Go Down
Author Topic: math.h bug  (Read 641 times)
0
Offline Offline
Sr. Member
dinosaur cork
View Profile
WWW
When I try and use a sin function in a program (with  "#include <math.h>) I get these compile errors:
/Applications/*Development Apps./arduino-0007/tools/avr/bin/../lib/gcc/avr/4.0.2/../../../../avr/lib/libc.a(fixsfsi.o): In function `__fixsfsi':
../../../libm/fplib/fixsfsi.S:57: multiple definition of `__fixsfsi'
/Applications/*Development Apps./arduino-0007/tools/avr/bin/../lib/gcc/avr/4.0.2/avr5/libgcc.a(_sf_to_si.o):/Users/nick/Documents/Electronics/Software/avr-gcc/4.0.2/build/gcc/fp-bit.c:1404: first defined here
Couldn't determine program size: tools/avr/bin/avr-size: '/tmp/build23472.tmp/test.hex': No such file
Any ideas? And any idea who nick is? I don't have a user by that name on my machine.
Also interestingly the sqrt function compiles fine - just not sin or cos.
I tried commenting out some of the offending libraries with no success, it just complained about a missing library.
Paul Badger
Logged
Forum Administrator
Cambridge, MA
Offline Offline
Faraday Member
View Profile
WWW
Apparently it's a bug in avr-gcc (the compiler that Arduino uses to transform your code into a program that can run on the microcontroller): http://savannah.nongnu.org/bugs/?18169
According to that page, the solution is to link with -lm, which you would need to recompile the Arduino environment to do.  I'm going to try to add more flexibility into the compilation process used by Arduino to allow this sort of thing, but unless other people are having similar problems, it probably won't be a high priority.
What are you trying to do?  Maybe we can help you find another way to work around the problem.
Logged
0
Offline Offline
Sr. Member
dinosaur cork
View Profile
WWW
Well I was going to use a sine function to generate a lookup table at runtime. But I guess I can generate the data then just put it into the program.
I like the pow function for conditioning sensor data too but haven't tried to see if that one works. It just seems wierd to me that sqrt should work but the trig functions don't.
Logged
0
Offline Offline
Newbie
View Profile
Hi!
I also needed to use the sin function, and didn't suceed because the sin function expects degrees in radians and putting the radians function returned the following error:
DEG_TO_RAD was not declared in this scope
also the sin function always returned a zero value, maybe because I was using an integer instead of a float. By the way what's the status on floats, is it supported by Arduino? the reference webpage lacks information on it.
Thanks!
Logged
Forum Administrator
Cambridge, MA
Offline Offline
Faraday Member
View Profile
WWW
It's starting to sound like there are enough people trying to use floats and do math on the Arduino that we need to support it better.
Yes, floats should work, they just make your sketch take up a lot more program space on the Arduino board.  You can't print them with the Serial commands however.
To convert degrees to radians, multiply by pi (3.14159) and divide by 180:
float rad = deg * 3.14159 / 180;
Logged
0
Offline Offline
Newbie
View Profile
I just came across this trying to convert a serial input to double using atof
Am keen to get a fix, so registering my interest smiley
Output
/cygdrive/d/apps/arduino-0007/tools/avr/bin/../lib/gcc/avr/4.0.2/../../../../avr/lib/avr5/libc.a(floatsisf.o): In function `__floatunssisf':
../../../libm/fplib/floatsisf.S:65: multiple definition of `__floatsisf'
/cygdrive/d/apps/arduino-0007/tools/avr/bin/../lib/gcc/avr/4.0.2/avr5/libgcc.a(_si_to_sf.o):/home/hbarragan/t/gcc/gcc/fp-bit.c:1334: first defined here
/cygdrive/d/apps/arduino-0007/tools/avr/bin/../lib/gcc/avr/4.0.2/../../../../avr/lib/avr5/libc.a(fixsfsi.o): In function `__fixsfsi':
/cygdrive/d/apps/arduino-0007/tools/avr/bin/../lib/gcc/avr/4.0.2/avr5/libgcc.a(_sf_to_si.o):/home/hbarragan/t/gcc/gcc/fp-bit.c:1404: first defined here
Logged
0
Offline Offline
Full Member
View Profile
Wait, so what you are saying is that math.h does not work at all?
That's bad news! I was planning to use sqrt and sine and cosine to compute some GPS stuff!
When will this be fixed?
-Z-
« Last Edit: July 09, 2007, 04:23:15 am by zitron » Logged
Forum Administrator
Cambridge, MA
Offline Offline
Faraday Member
View Profile
WWW
Actually, I think I fixed this for Arduino 0008.  At least, I can compile a sketch that uses atof() and sin(), which I think didn't work before.
Logged
0
Offline Offline
Full Member
View Profile
Ah, that does seem to work alright, and including a sin() didn't increase the sketch size as much as I thought it would! Sorry I didn't realize I was reading an old thread.
Thanks, and keep up the great work!
-Z-
Logged
Pages: [1]   Go Up
Print
Jump to:
