Topic: Serial.print and Serial.println are different ... (Read 1 time) previous topic - next topic
wiikii
Serial - print handles byte and unsigned int, not so does println.
I think a function like the following is missing. Isn't it?
void HardwareSerial::println(unsigned int n)
 print(n);
 println();
But there is an declaration for uint8_t.
By the way ... How can I recompile or use changes in the libraries in Ardunio 0010?
thanks for answering.
regards
mellis
The function:
will be in Arduino 0011.
To change things in hardware/cores/arduino, just edit the files.  Next time you compile or upload your program, it should use the new source.  To change things in hardware/libraries, you either need to delete the .o files or switch boards (in the Tools > Boards menu).
