Topic: Transistor, MOSFET (Read 1 time) previous topic - next topic
Dawiinci
I have the Arduino Yun. The goal is to control a remote control by emulating the button press. The button switches GND. I will use the 5 V of the USB that powers the Yun to power the remote (over a 3V regulator of course) and use the GND to switch the buttons on using a transistor or MOSFET.
The MOSFET I tried was not able to be triggered by the Yun (BS170).
So I found some NPN Transistors I could hopefully use:
S8050
S9013
S9014
S9018
2N3904
2N5551
A42
C1815
C945
What do you think?
mirith
Look for logic level MOSFETs if you want to use them.  Either way, you are assuming an open-collector (or Open-drain) circuit.  If that is the case, great!  If not, then you'll need to revisit your plans.
Dawiinci
So my transistors wouldn't work?
I am not sure about the circuit. The buttons simply shortcut GND to the board. Therefore I assumed to do this with a transistor.
bjarne
A transistor should work just fine.  The only one I recognize off the top of my head is the 2n3904, and it should suffice for what you want.  Just remember that while a MOSFET is voltage driven, a transistor is current driven, so you need the appropriate resistor in series with the base to supply the correct base current.
I am also assuming you will be using an open collector circuit.
mirith
They might work!  What you need to check is how the rest of the circuit connects to the button.  Most likely you will be able to replace it with a transistor.  I'd recommend the standard 2n3904 or 2n7000, though the BS170 should work as well.  Make sure you have it hooked up right.
Docedison
The C945 (2SC945) that you have is a nice choice as it is a very high gain (Beta) GP NPN Silicon transistor... Any of them are more than suitable but you already have the C945 transistor..
Doc
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
MarkT
First you need to find out the max current draw of your remote - then decide on a
transistor, since it needs to be able to handle that current level.  If the current
draw is small it will make the choice easier of course.
Dawiinci
Thanks, the draw is very minimal. I took a B675A - oversized but works. ;)
