Topic: Mounting of Arduino boards?? (Read 20082 times) previous topic - next topic
jeffjohnson14
I'm still kind of new to the Arduino world, so I may just be a little off but . . .
Does anybody actually finish a project with an Arduino? I haven't seem any really mounted in a project box.
Everyone just has the board laying on their desk with all the wires hanging around.
Shouldn't someone be selling an enclosure for all these projects?
Maybe a single decker, double decker and a triple decker? For 1, 2, or 3 shields?
I have tried searching for Arduino mounted enclosures, but have had no luck.
If anyone knows where to purchase such a product, please let me know.
jeffjohnson14 at gmail dot com
thanks!!
mem
I think we may be too busy building stuff to document what we finish. Here is one of my first Arduino projects, a device for testing radio control servos. It was a tight squeeze getting everything in.
The box was one that had been sitting in my junk drawer for years but 'Project Box 1' from Futurlec is the same size and a good fit for the Arduino. http://www.futurlec.com/ProjectBoxes.shtml
The Arduino is under the home made shield
jeffjohnson14
Looks nice.
Did you just use two of the holes in the main board?
What size standoffs did you use?
Did the box have matching places to screw into?
Most of the smaller boards we make here at work, have a hole in each corner for mounting.
While we are designing the board we also take into consideration the mounting in a box.
It seems like the Arduino design doesn't care about mounting.
Don't get me wrong, it is a great development board, and very educational.
But using double sided tape to put it in a project box, just seems wrong to me.
lilpunk1302
Quote
Looks nice.
Would using a longer single sided piece make you feel better?
Maybe take come plastic standoff-like pieces(does anybody sell these?) and superglue them under the mounting holes where the board is?
I'm really not sure how to mount it, I haven't received mine, let alone built a project, let alone mounted it.
mem
#4
Jun 11, 2008, 09:25 am Last Edit: Jun 11, 2008, 09:28 am by mem Reason: 1
Quote
Sorry for the delayed response, didn't see yr post
I used all three holes
three small squares of 1/8 inch thick plastic with holes drilled for the mounting bolts
The box was drilled to match the holes in the board and countersunk so the bolts are flush.
box underside
jeffjohnson14
ah!
That looks really really cool.
Now it makes sense.
Drill and countersink, that is a good idea.
Thanks, for the picture!
kg4wsv
I haven't done this with an Arduino, but a mounting shortcut I sometimes take is to mount the board to the standoffs, so that the board has 4 (or N) legs.  Instead of drilling/countersinking/screwing, I just mix some epoxy, blob it inside the box roughly where the mounts should be, and stick the board's little feet into the epoxy.  Let it cure, and presto - that mistake you made drilling the hole in one corner is completely hidden from the world once the lid is screwed on. (:
Just make sure that the legs are long enough and epoxy is shallow enough that you don't epoxy the board to the box.
-j
gradbert
Here is a project I did that is mounted in a box.  This is a 3 meter analog clock.  The box is a wooden box my wife found at a craft store.  It looks nice enough that my wife let me put in in the front hallway :)
Here is whole thing in its box
A view of the inside
A closeup of the meters
lilpunk1302
#8
Jun 12, 2008, 06:44 am Last Edit: Jun 12, 2008, 06:44 am by lilpunk1302 Reason: 1
That looks so cool, any chance you could get a video of it in action?
It isn't much of a mounting though, it seems as if you just have a breadboard and arduino floating around in there.
jeffjohnson14
That's kinda where I was going.
Most pictures of the Arduino doing cool stuff, don't show the board mounting.
The board is just dangling and there are wires hanging everywhere.
I love all the things people have done with it, but it seems like the projects are not really finished.
It's nice you can close the lid and hide the mess, but can you shake the box without breaking things?
If you can't gently shake the box the project is not completely finished.
My wife is already on my a$$ for all the network and video cables around the house. I can't just leave a board and wires laying around and call it a finished project!
I also like the idea of epoxy and plastic standoffs.
Thanks for the pictures.
lilpunk1302
I think people don't bother mounting it because the Arduino is technically a Development board, you develop your circuit, watch it run for 5 minutes, if it's cool enough, get a custom PCB ordered, burn a "real" processor and make it complete, unplug your Arduino and move on.
In the rare instance that your project is Really cool, then yeah, some may bother to mount it.
I probably would, but then again...
It all comes down to what the project is, what it was intended for, and whether you have the $$ for either another Arduino to continue tinkering or to get it built professionally.
optique
gradbert,
I like the retro look of analog meters! Good project! I can imagine the questions you get from guests who see that thing. Then the blank look on their faces. Then the "Why?" but we understand!
You know you can get some double sided tape and secure the stuff on the side of the box. I am sure you knew that!
What I would like to get my hands some analog meters from the 1940's-1950's. Or, switches from the same vintage. The switches we have now on electronic gear is so puny and fragile. People expect to see the high tech 7 seg displays / LCD stuff, but nobody expects analog!
Take it easy.
Steve.
Oracle
I've never mounted an Arduino board.  I'd rather just solder the chip and barest support to a piece of perfboard.  If I needed the serial connection though, I'd probably permanently mount the Arduino board just to make things easier.
Still...I cringe when I see finished projects with breadboard mounted and holding everything together.  It's just not meant for reliable long-term connections.
lilpunk1302
Quote
Yeah, at the very least get a solderable "breadboard" (Pref board?) From Radio Shack and solder a set of headers to that for the arduino.
Oracle
Quote
Except avoid radio shack.  Their boards are very poor quality and the pads are easy to lift if you're not very careful.  One thing I can actually get near here is good perfboard from a store called Sayal: http://www.sayal.com/.  They use FR4 material and have similar layouts to radio shack at similar prices but much higher quality and a bigger selection.
There's plenty of good online source for perfboard.
Oh, and never, ever use a radio shack soldering iron.  All they're good for is turning people off soldering.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
