Pages: [1] 2   Go Down
Author Topic: strtod() call causes arduino to reset  (Read 927 times)
Hello,
I'm having a problem converting a string to a double (or float),  whenever I call strtod() the arduino resets  I've also tried calling atof() with the same result.  I've posted my function below, if i hardcode it to return a float everything works fine.  I'm using ubuntu hardy heron if that matters.  Has anyone had this problem? Or how can I troubleshoot this?  Thanks
double search_string(char key, char instruction[], int string_size)
  char temp[10] = "";
  for (int i=0; i<string_size; i++)
      if (instruction[i] == key)
        i++;
        int k = 0;
        while (instruction[i] != (' '|NULL))
          temp[k] = instruction[i];
          i++; k++;
        return strtod(temp, NULL);
  return 0;
London
Have fun!
Serial.print(temp); just before the strtod(temp, NULL);
if temp is not what you expect then you can add some more printing to see how your parsing code is working
Thanks for the reply
Serial.print(temp); prints the string I expect.
Also I tried
return strtod("1.0", NULL);
which also reset the board.
London
Have fun!
The strtod function works on my arduino using verion 010
void loop(){
double d;
   Serial.print("hello ");
   d = strtod("1.0", NULL);
   int i = (int)d ;
   Serial.print(i);
   Serial.println(" world");
does print:
hello 1 world
Simplify your sketch to see if you are running out of memory or have some other problem elsewhere
« Last Edit: March 06, 2008, 03:29:04 pm by mem » Logged
USA
Freeduino rocks
Hello,
  char temp[10] = "";
        i++;
        int k = 0;
          i++; k++;
  return 0;
temp is not being properly terminated with 0 after the while loop.  You need to add temp[k] = 0;
shouldn't
work then?  It's resetting my board
USA
Freeduino rocks
shouldn't
return strtod("1.0", NULL); works just fine.  Maybe you have a faulty atmega168?
Post the complete code so I can try... all the examples posted so far work perfect... no reset.
Depending on the rest of your program, you may be simply using up the last bit of RAM with the strod() call. When you use too much RAM, it can wrap around to address 0 again and this has been known to cause resets.
-j
USA
Freeduino rocks
Yes, that is why adding the trailing '\0' is always a safe programming rule in C
  Serial.println("start");
That code causes my board to reset.  Is it possible the string.c libraries in Ubuntu Hardy Heron are bad?  I know it worked on gutsy, but then I didn't run this code for a while and I updated in the mean time.  To see if it is my compiler is there a hex file generated that I could attach here?  Thanks
Well, yeah, possible, but not relevant to this discussion - you're using the string functions that come with Arduino, not those that come with your OS.
-j
rats, in that case is there a hex file arduino creates I could upload here for someone to try to see if it is my board or something on the compiler side?
USA
Freeduino rocks
Please, what do you mean by "reset"?
Reset as in reseting the atmel, same result as pushing the reset button on the board.  If the code was
Serial.println("finished");
finished would never be print, and start would be printed over and over (sometimes truncated or with unprintable characters added on)
I can confirm theres a problem with the compiler that ships with hardy heron, I tried my code compiled with gutsy gibbon and it works fine.  I think I need to file a bug report for ubuntu, not sure for which package though.
Pages: [1] 2   Go Up
