Topic: Restarting Sketch on 32U4 from Linino (Read 890 times) previous topic - next topic
whisprer
A previous post led me on to this question, of which I believe the answer would be useful to many.
Is there a way to restart the Arduino sketch from Linino? This could then be setup as a startup script to reboot the 32U4 whenever Linino reboots. Thanks for any ideas.
wayoda
There is a litte bash-script  /usr/bin/reset-mcu
You can call it from the commandline or from a script that runs at startup.
I guess the original use case for the script is to reset the Arduino before uploading a new sketch.
Eberhard
whisprer
#2
Mar 21, 2014, 06:09 pm Last Edit: Mar 25, 2014, 02:31 pm by whisprer Reason: 1
Eberhard
Thank you, this is exactly what I needed.
I would recommend anyone using the Bridge in their sketch to add this to 'Local Startup' in Luci:
# Put your custom commands here that should be executed once
# the system init finished. By default this file does nothing.
wifi-live-or-reset
/usr/bin/reset-mcu
exit 0
