Topic: Correction to PROGMEM tutorial (Read 943 times) previous topic - next topic
Hans de Ruiter
the PROGMEM tutorial has an error in it (or maybe it's due to a compiler bug.
Basically, this line:
PGM_P PROGMEM string_table[] =
needs to be changed to:
PGM_P string_table[] PROGMEM =
It won't work unless progmem comes after the array variable declaration the same way that the strings are declared in the preceeding lines. This wasted most of a morning before I discovered why it didn't work, so fixing it will prevent someone else from being stuck on the same problem.
Hans
mellis
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
